Signal interruptions on digital TV set
I have a Samsung 22" LCD TV, several months old, which is set up to receive broadcast channels. It is not connected to cable or any other devices, except a Radio Shack HDTV antenna. Occasionally (sometimes frequently), the screen goes blank for a few seconds and a message appears" "Weak or no signal". I have tried making the recommended adjustments in the antenna and also rescanning the channels, but neither of those made a difference. I am not in a remote area. I am 12 miles from the center of Philadelphia.
    Top Expert:
  • Televison & ... Master
  • 77,544 Answers
Weak signal is a weak signal, so not sure what if anything you can do. Buy a satellite subscription???
Posted on May 18, 2017
tvtek
  • 1284 Answers
SOURCE: Weak Signal ..
Sounds like you have a bad tuner. The most likely cause on these RCA's is a loose RF antenna input connector. A bypass for now is if you have a VCR use it as the tuner and then connect it to the TV using the composite video inputs. If that faisl as well then you have a bad signal board.
Posted on Feb 12, 2007
  • 195 Answers
SOURCE: samsung hlr4667 dlp \ no hdmi connectivity
No, when I bought my new plazma tv, and unhooked my old DVR box, I had to go to my cable provider and inform them. they sent a signal and WHAM I was back in Biz.
Posted on Nov 10, 2008
SOURCE: weak or no signal message
  1. Since my problem (Samsung/Comcast) began with a channel selection button pushed on the TV remote when it should have been pushed on the cable remote, I figured the problem lay with the TV.  Although I was getting the "weak or no signal" msg., the actual signal strength bar graphic showed it to be strong. Disconnecting did no good. I surmised that the TV was simply not recognizing the box.
  2. I looked at the manual for my Samsung 750 model.
  3. Page 20 discussed "Selecting the source". I accessed the TV menu and selected "Input", then chose the "HD..." item from the highlighted list. Voila! My tv works again.
Posted on Nov 18, 2008
  • 38 Answers
SOURCE: Media Center can't find digital TV channels for TV Wonder HD 600
Just to make sure, you do have analog tuners setup right?  Media Center 2005 requires analog tuners be working before digital tuners are allowed.
Posted on Jan 31, 2009
  • 718 Answers
SOURCE: displays weak or no signal
To get any HDTV to work this is what you have to do;
CHANNEL section
1) Connect your antenna cable which you have done.
2) Go into the menu to the source option and select AIR/ANTENNA since you are using an antenna.
3) In the menu you will have to SCAN in the stations. This auto program will find all available stations.
Now you can watch tv by selecting the station you want.
The new generation of HDTV is different from the old analog sets. These have to be set up to work.
Exact information can be found in your Users Manual.
Posted on Feb 23, 2009
Why if my antena is hooked to my dvd player is it not getting channels but my tv is if dvd player is turned off
The reason probably is because all broadcast TV is digital, and the em-55 tuner is set for analog channels. It cannot receive today's broadcasts "thru the air" because channel 2 for example is not broadcast, rather channel 2.1, 2.2, etc.
You can use the signal with a new TV, but when you turn ON the em-55, it inserts channel 3.
Most all TV here has what I call sidebands, and some have as many as 11, so the tv can be set for 3.1, or 3.2 or 3.3.
Even if you have a digital-to-analog device, the em-55 will not receive any .1, .2, .3, .4 and so on. I verified this recently reconnecting my old antenna to the converter then to several VCR's and DVD players.
Turn off the em-55, and the dot channels pass through the RF connectors..
Some DISH, cable direct TV receivers convert the signal to ch 3.
Sep 25, 2014 | Panasonic DMR-E55 DVD Recorder
Why won't my new Vizio DTV work on an antenna without the digital box?
Do you have the antenna aimed correctly and the correct antenna for the distance between your location and the stations? Check antennaweb.org and tvfool.com for the directions to the stations you should be able to receive. Antennaweb assumes an external antenna and is very conservative in the station list. TVfool gives the stations you should get with various different types of antennas. Tall trees and buildings will block signal strength so consider the environment around you.
With digital signals, if you do not have enough signal strength for a given tuner, the channel will not come in. An amplifier may help you get the signal, particularly if the signal is shared to several devices. Failure of an amplifier or lightning surge protection can stop the signal from reaching the TV. A surge through the antenna can damage the tuner.
A damaged cable can also be a source of a problem. Check the outside portion of the wire as well as the interior wires. Replace any that have damaged insulation or ends.
For this TV, if you have done a channel scan with the TV set to the Input TV/DTV, and the Signal Source set to Antenna. Turn the antenna and then set the Additional Scan to On. (Menu > TV > Channels > Additional Scan.) Then do another channel scan.
If you need a copy of the manual, see: http://www.vizio.com/m220va.html#support .
Jan 22, 2011 | Vizio M220VA 22 in. LCD HDTV
I have a 32" flat panel. Am only receiving one local TV station channel at this time. All other channels show "No Signal". We hooked another TV to the cable and it works fine. What could the problem...
The tv is good,just some LCD tvs some models require a very strong broadcasting signal to get a picture.U getting a free DTV air broadcasting signal wright?Tries getting a roof antena or a digital design antena.Tries this tv out again,will get all the DTV free air broadcasting signal.Should not get anymore "No Signal" result.
Oct 13, 2010 | Polaroid FLM-3201 Television
Tv tuner will ot detect digital signal in windows media center, vista
All US TV signals are now digital, but most TV tuners are like our old TVs - analog. Are you sure your tuner is a DTV tuner? If not, you will need to replace it or get a DTV converter. A DTV converter will not let your computer pick the channel and time though.
But one footnote. Broadcast digital TV is often not the same a cable digital TV. If you get a cable digital signal it is encrypted to the actual serial number of the receiving box. No broadcast DTV converter can do this. This is how the cable company now controls the number of receivers and one has to pay for EVERY set.
Apr 23, 2010 | Sony VGC-LT16E VAIO 22" All-in-One Desktop...
47" Vizio Flat screen HD LCD freezes up and remote will not work.
could it be Ch 9's digital signal is not broadcasting right? what is your refresh rate on your tv? 60 or 120hz? if its 120hz, then its more then likely the digital broadcast, if its 60hz I think its your tv can't keep up with their signal that may be at 120hz. Make since??
Jun 16, 2009 | Vizio VO47L 47 in. LCD TV
Tv set just lost its ability to display digital channels
Your problem is definitely the input signal source to your tv. It is extremely rare where a new tv has a tuner signal sensitivity problem. The best thing to do is to replace your current set of rabbit ears with a different set of powered rabbit ears that have a higher gain rating with a variable gain control. Please note that the gain control setting is critical when setting up your tuner for auto-programming. If the gain control is set too low or too high it will result in your symptom.
If you still can't get it to work you could try buying a line amplifier which you would install to the rabbit ears before the tv. If you still can't get it to work you'll have no choice but to purchase an outside antennae as a result of your being in a weak signal area as signal quality changes by such things as the switch over to digital upcoming and environmental changes.
Apr 27, 2009 | Televison & Video
Sharp Aquos LC-52D64U LCD-52 wdscrn tht won't scan in digital...
Seeing that you have a superior brand and not getting channels is a bummer. It may have to do with the setting, make sure you're set to cable rather antenna and then do a rescan. Btw, often times channels from an over the antenna is much clearer than from cable because cable tv has to compress the signal. If you're high in the air like the top floor of a building a cheap $10 will pull in great free digital channels. It helps to experiment and read the troubleshooting guide in your manual.
Dec 03, 2008 | Sharp Aqous LC-26D5U Television
Analog/Digital
HDLCD2600 come set for cable. Make sure the tv is set for "tv" or "air" then run the auto channel memory or search feature of the set. If you have the manual it's under "memorizing channels". If your still have problems, call Sansui TV's customer service number 800 289 0980.
Nov 04, 2008 | Sansui HDLCD-2600 26 in. LCD Television
Samsung HP-S4253 black screen, with sound
Its the broadcasting company and there "new technology" Have had an over the air box to get local HD channels and lost my PBS station, turned out to be a new signal incompatibility. The same is with my HP-S4253. Must not have the latest SW to process the new signals
Feb 19, 2008 | Samsung HP-S4253 Television
Televison & Video Logo
90 people viewed this question
Top Televison & Video Experts
