Dvdr5520h upgrade required
Require upgrade download my tv guide wont load on standby and generaly slowed down
  • 630 Answers
It's not a solution but it may help. Mine will download on standby overnight but will then lose it all if left on standby during the day so switch it on in thew morning and leave it on all day. I'm waiting for a response from Philips.
I have occasional days where I can wait for 3 or 4 minutes for a button press to register be patient it works eventually!
Posted on Jun 23, 2009
My washing programme has just finished but my door now wont open
I presume you have waited long enough for the door release to operate after a few minutes. POWER OFF! remove lid and lide arm down in side the front panel to the door lock and release the door lock. A new lock is generaly required
Oct 03, 2014 | Washing Machines
Slow wont load games even with extra memory
If your Hardware is pretty much compatible with game requirements than you have to go through some points before playing game to prevent your PC from slowing down:-
- Shut down all running updates
- Remove all temporary files from your system
- You must have enough memory on disc that can support your paging memory
- Shut down all background running applications
- Run Reginout Utility for extreme gaming experience
- Update DX on your system
Oct 19, 2013 | Acer Aspire One PC Notebook
Says it requires 24 hrs time to program channels by zipcode 91042. Is this the case??
if you are programming a TV Guide type function yes.
The info is downloaded twice daily, around 2:10 pm EST and 2:10 am EST from your local PBS station.
The TV will wait for that down load before it gives any info in the TV GUIDE.
Apr 12, 2011 | Televison & Video
My vbr120 blu ray player frequently locks up when downloading netflix movies or tv selections, requiring me to unplug the player to reset.
I have the same problem. While I don't have the permanent solution, I can tell you a few things. 1) You don't need to unplug, simply hold the power button down on the unit until it does a full reset (it normally just goes into standby mode when you tap the power off button). 2) I've noticed the locking only happens if I try to watch a netflix after I've used an optical disc between resets. IMO, I believe it's a problem with the system memory not updating and won't be solved unless they put out a specific firmware upgrade for it (unlikely on such a cheap player).
Feb 06, 2011 | Vizio VBR120 Player
Why does my printer prints a few pages and it slows down to a snail pace
The cause and solution may include one or more of the following:
  • The print head temperature is too high. Make sure the printer is not placed in direct sunlight or is not operating in a high-temperature environment.
  • Cooling vents are blocked or dirty. Check the cooling vents and clear any dirt or obstructions.
  • There are too many applications running on your computer. Close unnecessary software applications.
  • The computer is not running efficiently. Consider upgrading your computer to meet the recommended system requirements.
NOTE: When printing a large number of prints, printing may slow down to prevent the print head from overheating.
See your printer user,s guide for more information.
Dec 03, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
TV switched itself off. Standby light flashing on and off once then five rapid flashes. Tv would come on but then turn off again after a few seconds.Standby light even stayed on when tv switched off at...
Subject
Unable to Power On or Off the set
Symptoms / Customer Description
The symptom may occur while the TV is ON or in Standby.
1) If the problem occurs while the TV is in Standby:
The TV will not turn on via the remote or power button located on the set however after AC reset (i.e. unplug the TV for at least 30 seconds from the AC source) the TV returns to normal operation.
2) If the problem occurs while the TV is in use:
You may lose the ability to power off the TV or switch the video inputs however channel changing, adjusting volume, or accessing the menu may still be possible. After AC reset (i.e. unplug the TV for at least 30 seconds from the AC source) the TV returns to normal operation.
Sony has designed the BRAVIA Televisions to be CUSTOMER Software Upgradeable and therefore Sony will not pay a service claim on any issue resolved by a software upgrade. If a customer requests an update please refer them to the following website: http://www.updatemytv.com. If the unit requires the update, you may enter the customer's information in the website and a USB device will be sent to their address.
If a customer does not have access to the web please have them call the Sony Call Center Support line: 1-866-210-6333
If a customer reports either symptom above request that they unplug the set from the AC wall outlet for at least 30 seconds and then plug the set back in. This will reset the TV and it should work fine for several months. If resetting the TV does not resolve the issue the customer has a different problem and a service call by a technician may be required
Jan 02, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Will not load to my computer
Sometimes, problems like that is associated with missing program required by the installer you loaded to your computer. Usually graphics require .netFramework 2 or any higher. When you are prompted once you unload it to PC, try to read why it doesn't load and then if it requires some rpogram, download it from the net. Some programs like Java Environment is free for upgrade download.
Dec 12, 2009 | Audio Players & Recorders
When trying to watch movies computor slows and almost stops for a long time. Using Netflix for one example.
For watching movies using netflix you require to have an high speed broadband connection as your computer slows down go for upgrading ram this can solve the problem.
Aug 23, 2009 | Computers & Internet
Upgrading firmware n97
connect ur phone to pc via data cable. install the ovi suite first. now there will be an icon of nokia software update on the desktop.click on it
INternet is required on ur pc
now follow the step by step process.
sumtimes the download might fail but try again u will be successful and sfter upgrading to 11...21 u will like ur phone better than before
Aug 06, 2009 | Nokia N97 Cell Phone
Etower 633id runs very slow. Only has 64MB of RAM.
Normally upgrading bios does not require flashing the bios. But in order to find out the max amount you can upgrade too requires some info off the motherboard. You need to get the model number off the board to look up the info
Dec 24, 2008 | E-Machines etower 633id PC Desktop
Televison & Video Logo
179 people viewed this question
Top Televison & Video Experts
Electro Med Services...
