Question about Panasonic PT-56HX41 56" Rear Projection Television
Panasonic blue convergence problem
I have a 2002 Panasonic (PT-56HX41PF) rear-projection, 4:3, HDTV whose blue convergence went out all of a sudden yesterday. I turned it on and the picture was awful. The red and green were fine, but the blue will not converge in the corners or on the sides (converges fine down the middle). Any idea what's going on?
  • 6 more comments
  • Dempmeister Sep 15, 2007
    What would be the likelihood of being able to fix that myself? And if so, where could I get original parts? I got an estimate today of between $500 - $600 dollars ($300 for the parts (like you said), rest for labor) and I just don't know if I want to put that much money into it. The more expensive it is the more I think about just buying a new TV.
  • Dempmeister Sep 16, 2007
    I do work on computers and have done a little soldering, so I'll give it a shot. Do you know where I can get a schematic diagram or instructions for that model tv? The bdent.com site has the integrated circuit that I think I need; another post on Fixya said two STK392-110 circuits would do it. Is that correct?
  • Dempmeister Sep 27, 2007
    You nailed it techman! I replaced the two chips and it works great! If you're ever in Colorado Springs look me up - you've got a free dinner coming. :-) It's the least I can do for all the money you saved me. Thanks man.
    Best regards,
    Dempsey
  • jlshep May 02, 2008
    Same problem with Blue and now red. Need schematic or picture to see the chip layout. Can replace and hope to have the same success, but I have no manuals to refer to.
    That fixed it. Went to the local electronics store "Audio Lab" Plug... and picked up what I needed and now its fixed. Thanks.. by my count thats $600.00 plus dollars tech man saved and possible big land fill items. Thanks for your help!
  • kerryfan Oct 18, 2008
    I have same problem with the TV of same module, and I know how to soIder/unsolder ICs. I have bought 2 ICs of STK392-110, when I was trying to fix it I got a problem: I couldn't move PCB out. There are 2 boards, one is green and one is yellow. I want to move the green one out, but there are 4 connectors joining these 2 boards together. I cannot disconnect the green board from another one, so I cannot take the board out to fix it. Could you tell me how to get the board out? I'm looking forward to hearing from you soon.
    Kerry Fan.
    My email address: fan_xian@yahoo.com
  • pfinni2364 Feb 06, 2009
    hi i have the same problem changed both stk932-110 made by sanyo
    set will come on but no picture blue and green on but faint red is on but it looks like it is out my solder joints look good under a magnifiging glass
    were did i go wrong
  • Anonymous May 07, 2009
    I have bought 2 circuits, not real good with repairs, but I am going to give it a try. Do I need to change both if only the blue is out? also, which of the two is the blue? Do you have a copy of the circuit board? PT-4743G.
    Thanks
I found them. was looking for something a bit smaller. Thanks will try to replace.
Posted on May 02, 2008
    President:
  • 3,130 Answers
Yea, you have to have the two convergence Amp IC's replaced. Should run you about 300 bucks or so. Good Luck
Posted on Sep 14, 2007
  • 1 more comment
  • Larry  Dillon
    Larry Dillon Sep 15, 2007
    No the 300 dollars was for parts and labor, the parts should not cost you for the original IC, about 25 to 30 bucks. They are ripping you off big time. This is an in the home repair my friend. Can you solder on printed circuit boards? Can you follow a schematic diagram? If you say no, play it safe and get another price. %00 to 600 is WAY WAY to high for 30 bucks worth of parts.
  • Larry  Dillon
    Larry Dillon Sep 19, 2007
    Get the right IC's for this TV set. The ones that do not have the word Sanyo marked on them they are aftermarket cheapo parts, or factory rejects. Always stick to the original replacement parts. I always use this place for original parts, plus they sell them in pairs, just what you need. http://www.electronic-repair-kits.com/in...
  • Larry  Dillon
    Larry Dillon Sep 27, 2007
    Glad to hear you fixed the tv set. Contact me at techman32k@yahoo.com.
Panasonic (PT-56HX41PF) rear-projection tv with no picture
The three blinks indicates a convergence IC fault. The convergence ICs must be replaced with the manufacturer replacement part. Use only the original replacement part. Your set uses STK392-110 convergence ICs.
These ICs are mounted on a large heat sink. Yes, you can replace it yourself and save few hundred bucks. But you must be knowledgeable enough on how to solder, resolder and use a multimeter.
You will need:
  1. Convergence ICs
  2. Heat sink grease or thermal compound
  3. Soldering iron
  4. Solder lead.
  5. Digital multimeter
  6. Solder pump
  7. Small side cutter
Feel free to inform me if you decide to replace the ICs yourself
Dec 03, 2009 | Panasonic PT-56HX41 56" Rear Projection...
Panasonic PT-53TW53 color suddenly seperation went way off.
You can get the convergence repair kit at www.tvrepairworld.com which contains the parts and the CD which has the instructions and the service manual on it. You would need the PT53WX53 convergence kit.
Oct 18, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Blue convergence wont work
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly. 4) TV Chirps
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 05, 2009 | Panasonic PT-47WX49 47" Rear Projection...
need to replace both stk392-110 , one is for vertical and the other for horizontal , if one is bad the otrere one would go bad anytime
May 07, 2009 | Televison & Video
Panasonic convergence- Blue Cross line not able to adjust
The panasonic rear projection convergence repair kit #2 is available for your model at the following link under convergence repair kits which has the ICs and resistors plus detailed instructions.
http://servicemanuals.vstore.ca/
Mar 13, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Convergence problem
Hi, you`ve lost the convergence IC`, requires a good knowledge of soldering and. posssibly an alignment after replacement, good luck, video-tek
Feb 14, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Blue convergence problem
you lhave a problem with the convergence IC that control the blue but for the description you made it seems you have no even a slight idea about electronics then my best recomendation is do not mess with it & get some body that does it for you because trying to save some bucks may be costly if you make a mistake think about it
Jan 28, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Replace IC Convergance chip in Panasonic PT-56HX41PF
Enter the tip of a pointed knife between the left side edges of the connector (circled in black in the attached pic) and gently tilt the knife away from the connector. Do the same on the right side. The connector should pop up.
Jan 21, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic PT-53WX52F Color blue adjustment
most likely the two convergence Ics need to be replaced. They are STK392-110 you can get replacements at the following link with free instalation instructions with pictures.
Jul 09, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Problems with Panasonic PT-53TW53 53 in. Rear Projection HDTV-Ready Television
sounds like the blue convergence IC is bad.This is quite common in all Projections units about 3 to 4 years old.
Jan 31, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-56HX41 56" Rear Projection Television Logo
647 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
