Question about Refrigerators
Purchased a water filter for my estate refrigator and the ice maker stop working.
Changed water filter ice maker quit working.
  • bbrown722 Apr 16, 2009
    No I did not check the flow but I will. Thanks so much for the help.
  • 331 Answers
When you replaced the filter did you check the flow before installing. I have had filters actually clogged right out of the package. Also most filters have a flow direction indicated with an arrow on the filter
Posted on Apr 15, 2009
  • Raymond Ramirez
    Raymond Ramirez Apr 15, 2009
    when you replaced the filter did you check the flow before installing. I have had filters actually clogged right out of the package. Also most filters have a flow direction indicated with an arrow on the filter
Ice maker and water dispencer don't work
Can be the water valves located on the back of the refrigerator. There are a lot of youtube videos to check the valve and replace them. Good luck.
Jul 03, 2016 | Kenmore Sears Refrigerator Replacement Ice...
Ice maker quit
if ice maker is cycleing then it is either water frozen at the tube where water comes in. if it is then shut off refrig. remove icemaker and thaw tube out with a hair dryer. makeing sure not to melt plastic in the back panel of freezer. if it is plastic. if it is not plugged then it is either a bad water valve or the watervalve switch in the icemaker.
May 26, 2012 | KitchenAid Refrigerators
My refrig stop making ice after I changed the water filter. I had the filter out for about 3 hrs, would this cause the problem?
Hi, first , pour about 2/3 cup of water into the ice maker . If if freezes , and dumps , replace the water valve. If it does not dump the cubes , replace the ice maker. After pouring the water into the ice maker , remove the bottom kick panel , and clean the bottom coils , of dust , lint , pet hair , etc , as this will raise the freezer temp . An ice maker has to be 5 degrees , to operate , correctly . If ice maker starts working , after cleaning the coils , GREAT ! ( it does happen ) .
Take care
May 28, 2010 | Maytag Ice2O 24.9 Cu. Ft. Side-by-Side...
No water coming from water dispenser.
It is possible the water control valve for that dispenser has failed and will not open. This happens a lot for those and the ice maker valves. All you need is the model number for your refrigerator and that will look like this for Kenmore. 213.564897 for example. and I will help you find the correct part number. Sea Breeze
Nov 24, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
The ice maker stopped making ice. Any solutions?
A lot of filters ( not all ) do not even access the ice maker . Only the water dispensor . If your water dispensor is working fine , then you need to replace the dual water inlet valve behind the refrig . This is the piece the wall water line connects to . It is called a dual valve because there are 2 coils on the valve . 1 for the ice maker and 1 for the water dispensor .
Oct 23, 2009 | Kenmore Refrigerators
Maytag refrig (french door) water and ice on door stopped working at the same time.
1) Electric Water valve check up.
2) Water/Ice dispenser control check up
3) frozen plastic pipe inside door or/and chilled water container frozen
4) old water filter (clogged)
Dec 07, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Jenn Air JRSD209T
This is just anecdotal here, but one repair guy who came out and thawed a frozen line into the icemaker told us the fridge required near-full line pressure 90- or 70- or whatever that is, in order for the ice maker to work. This was a licensed repair guy. We were feeding it with an RO, which only pumped it in at 17 or 20 psi (or whatever the unit is) which he informed us was inadequate. However, after he thawed things out and we changed out the inline carbon filter in the fridge, everything was hunky dory for a couple of years. About a year back, the icemaking stopped, and changing out the carbon filters in the fridge AND in the RO system did the trick.
Now we have a different problem. Things aren't getting or staying cold, especially the fridge. I opened the housing in the back of the fridge, defrosted the extensive ice accumulated around the refridgerant coils, and everything ran great for a couple of days. Now we're back in the global warming pattern: steadily rising temperatures and thawing. I'm not feeling too happy about Jenn-Air these days.
Jun 17, 2008 | Jenn-Air JCD2389G Side by Side...
Ice maker quit making ice
your refrig has a built in bypass in the filter housing so yes it will work with out a filter in place. if you have not replaced your filter in the last 6 months that is likely the problem. Hollow cubes are usually a sign of not enough water getting into the icemaker then it cycles too fast and harvests hollow cubes.
when the hollow cubes fall into your bucket they bust and put water in with your cubes freezing them together. so by solving your water supply problem you'll solve most of your icemaking issues..
Dec 19, 2007 | Kenmore 64802 Top Freezer Refrigerator
10 yr old Frigidaire ice maker stopped making ice
check to make sure the fill tube is not plugged with ice if it is not then i would guess the valve is shot
Oct 30, 2007 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
178 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
