Question about Twinhead DURABOOK D14RY
I have a GemmaTech Durabook D15R Series. I was
I have a Durabook D15R Series. I was using the computer and all of a sudden the screen went dim. It was very very dim but it got lighter somewhat after I shut down the computer for about 6 hours. Still though the screen is dim. I can make whats on the screen and when exposing to light it can be used. However, I am not sure why this happened , would it be backlight problem or inverter? how can I tell the difference?
  • wailosama Apr 16, 2009
    Thanks for the reply. None of the symptoms you describe fit my computer. The screen is dim (wouldn't say very dim because I can make out whats on the screen and even use it but with much concentration) but no red or any other colors noticed , it doesn't flicker , nor it comes back to normal at any point. So my believe is like you said the backlight / inverter. It works perfectly on an external display without any problems and have not noticed any unusual noise coming from the computer or screen.
  • Singirikonda Praveenkumarguptha
  • Twinhead Master
  • 32,281 Answers
You could have a defective screen, either a faulty inverter or a CCFL lamp - follow this to determine the fault.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out for parts, repair service and DIY info.
Posted on Apr 16, 2009
  • Chris Hingee
    Chris Hingee Apr 17, 2009
    Since your external monitor displays normal images then the video card/chip is OK.
    Can you increase the brightness of the LCD screen using the Fn key plus one of the Function number keys (the key would have a sun like symbol with and UP arrow and another with a down arrow)?
    By the description of the image on your LCD screen - dim and no colors, it is possible that the video driver is corrupted. Try re-installing the video driver.
    The video cable connector which connects the LCD to the motherboard needs reseating to make proper electrical connection.
The palm of my hand accidentally hit a button on my laptop, and all of a sudden my screen went dim..I thought it must of just hit the brightness buttons on my keyboard but when I went to go turn it back up...
Do you mean 'dim' or 'black'? If it's black you might try one of the the hotkey combinations of holding Fn + F1, or F2, F3, F4, etc. They do various things depending on the computer make. It will probably tell you in your computer manual.
Oct 28, 2013 | HP Pavilion dv1000 Notebook
Dell inspiron 1545 dim screen suddenly
sounds like backlights are gone, needs new invertor or screen, 90% of the time its just the invertor there like 9 pounds on ebay atm, and aint that difficult to fit,
Jun 19, 2012 | Dell Inspiron 1545 Notebook
Hello - i need the master code for durabook notebooks because i forgot my password and cant enter the bios setup please help
In order to reset the Master BIOS password on a durabook, you need to remove the CMOS battery and leave it out for a period of time. This will reset everything and allow you to enter the BIOS screen again.
You can find the User Manual for the durabook here
Hope this helps.
Feb 18, 2011 | Computers & Internet
Screen very dim do i turn up the contrast /brightness
Hello !
Test with an external monitor. If it works, there is a problem with the display's backlight or inverter board.
If you were experiencing discoloration in the screen (pinkish lower light hues) before it failed, that would indicate a CCFL backlight issue. If the screen suddenly went dim on you rather than a slow degradation the inverter would be indicated.
Hope this helps.
May 08, 2010 | Computers & Internet
I have a Toshiba Satellite A55-S1063 the scrren is dim but I can still see using a flashlight. I have had the back light replaced once it worked great for about 2 weeks and then went back to being very...
Hello !
Since the screen is dim, the display's inverter board needs to be replaced.
If you were experiencing discoloration in the screen (pinkish lower light hues) before it failed, that would indicate a CCFL backlight issue. If the screen suddenly went dim on you rather than a slow degradation, the inverter would be indicated.
Hope this helps.
Dec 01, 2009 | Toshiba Satellite A55-S1063 Notebook
IBM Thinkpad R51 screen blacked out
try to plug in a extrernal monitor and see if that works if it does your backlight went out
Jul 21, 2009 | Computers & Internet
Acer Aspire 5610. LCD very dim all of a sudden.
That sounds just like an inverter problems. There is a slim chance the bulb could be a problem, but I would replace the inverter. It is not too hard to do, no soldering involved.
You have to remove the screw covers on the frame of the LCD frame, and then carefully pop off the frame. The inverter should be on the bottom center of the screen.
Be careful, there is a high voltage in that little baby. Just get the full numbers, and do a search on the internet and buy yourself a new inverter to replace the old one.
Apr 08, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Screen is dim on the home screen
loose flex cable,happens when phone gets dropped ,open it ,reinstall ribbon cable,turn on,check,close it back up.
Feb 03, 2009 | Motorola Mobility RAZR V3
HP NX9030 15" display problem
Well the most common problem in this series is a bad inverter.
If you remember your LCD being RED tinted before it went dark, then the backlight has failed. Backlight replacement is typically $150-$200. But I see 15" LCD screens in good used shape for $80-$160. There are multiple LCDs on your laptop and we would need the exact part number off the back of the screen to give you an idea what to search for.
If you still suspect the inverter, the nx9000 series are the same as the presario 2100 and 2500, as well as pavilion 4000 and 5000 series. They are NOT the same as DV4000, DV5000 or V2000 inverters can be had for $20-$40.
I would hit up ebay there are tons of parts there for these.
Dec 28, 2007 | HP Business Notebook NX9110 Notebook
Twinhead DURABOOK D14RY Logo
308 people viewed this question
Top Twinhead Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Alun Cox
Lee Durbin
Lee Durbin
Are you a Twinhead Computer and Internet Expert? Answer questions, earn points and help others
