Question about Philips 51PP9303H Rear Projection Television
No audio or video just chirping
I have changed the two stk392-120 ic's. The kit includes 12 resistors that i didn't change. These tv's do not use 1 watt resistors so don't tell me to change them too. After changing the ic's i still have the same problem. This is the dptv345 chassis. Does anyone on here actually know what causes this?
  • 11 more comments
  • andthehorseu Apr 15, 2009
    I can't change resistors that don't exist!
    It's sounds like it's coming from the power supply board.
    The chirping sounds like it's coming from the ps board.
  • andthehorseu Apr 17, 2009
    Didn't help. I'm going to try changing the regulator.
  • andthehorseu Apr 21, 2009
    Didn't work.
    None of your information has worked. With so many having the same problem, i have to believe someone knows what's wrong with it.
    It's a Philips 51pp9303h.
    Please don't waste my time answering if you don't know what you're talking about!
    You gotta be kidding me?????????
    I have changed the 3 power FET on the power supply board and everything else checked ok on it.
  • andthehorseu Apr 25, 2009
    All the voltages checked ok on the power supply board.
    All the voltages checked ok on the power supply. I have already changed the 2 FET's for the horizontal output on the ps board itself. There is another FET that is the h/o driver on the main board and an ic that i believe is a gate. I'm going to change them and hope that was the problem.
    That site is no help.
  • Philips Master
  • 3,866 Answers
We apologise you feel that way aparently your doing it yourself and you pbring your problem to us to figure out for you, Listen I been doing this for 1 week now and let me tell you I help out everyone to the best of my abilities! We provide solutions,suggestions,commentary to get you to Fix it yourself your the hands,eye's,ears,nose,mouth or should I say fingers to help us FIXYA, making comments like that people are just more inclined to take the next solution. You are telling us you changed resisters for something other then the power supply and chirping is comming from the power supply well have you checked the load on this PSU "power supply unit" to make sure your reapair is in check? Have you hooked this up to a testing unit to test the value of the current after your fix? Well I do not trust you have thus you put us down saying "this site is no help" Try checking the negitive at the door and ask me some questions maybe I can help!
Posted on Apr 26, 2009
    Sergeant:
  • 199 Answers
Http://en.allexperts.com/q/TV-VCR-Stereo-1749/Pioneer-SD-P404-Picture.htm
visit this link and it is helpful for you and please rate it
Posted on Apr 25, 2009
  • 11,896 Answers
Hi!
First what comes to mind is that power supply had gone bad. And so it
can be 2 cases:
1)The problem is located in a "hot" part of power supply. The sound you
described says that the TV begins to start and then shuts down.In this case is
necessary to check the feedback circuit elements like photocouple, transistors
and diodes.Except it replace the electrolythic capicators in "hot" part.
2)The problem is located in one of secondary power circuits.Possible short-circuit or
bad electrolythic capicators.Check the circuits with multimeter.
Posted on Apr 21, 2009
    Sergeant:
  • 254 Answers
Its a faulty power supply board issue as per the details you have mentioned.if any components are faulty that can be replaced and the power supply board can be repaIRED,but if the track of circuit are getting short it cannnot be repaired.as you mentioned the readings of all the components are showing ok.very correct.if the circuit track are short it will show all the readings of the components perfect.but the only solution is to replace the board.that you can get from
www.partstore.com
.keep updated.thanks.
    President:
  • 2,923 Answers
For us to better assist you and give you more accurate answer, may I know the brand and the model of your TV?
  • Melvin Ramos
    Melvin Ramos Apr 21, 2009
    Kindly click this link:
    http://www.retrevo.com/support/Philips-5...
    1. Expand the Table of Contents and then click on troubleshooting.
    2. Right-click the Toubleshooting guide and then zoom it.
    3. After zooming it, right-click on it again and then select hand tool so that you can view the entire troubleshooting instruction.
  • 15,935 Answers
Thanks for using FixYa!!
Posted on Apr 18, 2009
    Champion:
  • 205 Answers
If one of the secondary supplies is shorted, the power supply will "chirp" when plugged in. This is the power supply's way of protecting itself and this usually happens when the horizontal output transistor is shorted. The only real problem I find with front AV jacks is that they crack loose from the board, because they are subjected to the extra stress of the AV jacks being constantly plugged in and unplugged.
Posted on Apr 15, 2009
  • 10,515 Answers
Hi andthehorseu,
A full, hard reset requires the power cord to be unplugged for at least 4 hours.  However, that probably will not solve the problem.
The set has gone into protection because of a shorted condition somewhere within the several sections of the tv.
The chirping sound can come from several places.  There are over 3,000 components in this model and there are about 100 parts that can "chirp" under the right failure conditions.
You should try to decipher where the sound is coming from.  Listen very carefully and up close to see if it is coming from the speakers or from within the set.  And from the front or more towards the back of the set.  That will help considerably when you call the tv service people to arrange for their visit.
As you may know, service on big screen sets in the home always run over $200.  It is one of the expected obligations that go with owning one of these big, complicated monsters; the price of sensational enjoyment - one way of thinking about it!
Taran.
  • taran_2005
    taran_2005 Apr 15, 2009
    Hi andthehorseu,
     It  is either a shorted Horizontal Output Transistor (HOT) / Power FET (whichever one is used in this case) or the IHVT (Flyback Transformer) has developed a short in its windings. In ether case both components will have to be replaced. I would suggest you have a qualified TV technician come over and troubleshoot the problem and give you an estimate on the repair.However, if you are doing this repair yourself take into mind that the HOT and the IHVT (flyback) are in a series circuit configuration and if the Flyback is bad I would change out the HOT also, and vice verse.
    I hope this helps,
    Thank you,
    Taran.
    Brigadier General:
  • 3,917 Answers
The STK's were replaced because a problem in the convergence. This problem (convergence) in most cases allows you to turn on the set just the screen looks out of geometry (by the way the resistors are critical parts that fail together with the IC's. To get the tv back on is needed a check up in the power supply and other areas related to high voltage power supply.
Thanks
Hear chirping sound from power switch, keeps tying to turn on, but no picture.
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • No Audio/Video - TV Makes Chirping Sound
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc
Dec 24, 2010 | Philips Magnavox 51MP392H Rear Projection...
The red and green is separated and there is a double image.
Projection TV sets have two very common problems oulined below.
  • Screen looks 3D
Dec 24, 2010 | Hitachi 57F500 57" Rear Projection...
Screen is a little blurry and can not seem to get color just right
  • Screen looks 3D
Dec 23, 2010 | Philips Magnavox 60PP9701 60" Rear...
COLOR IS OFF---LOOKS RED
  • Screen looks 3D
Dec 23, 2010 | Philips Televison & Video
I can barely see the picture
  • Screen looks 3D
Dec 23, 2010 | Philips Magnavox 51MP392H Rear Projection...
The screen is showing a red outline around objects and in double vision.
  • Screen looks 3D
Dec 23, 2010 | Philips 60PP9202 60" Rear Projection...
Double image orange and green
  • Screen looks 3D
Dec 20, 2010 | Philips Magnavox 9P6034C 60" Rear...
Image has duplicate shadow
There should be different HDMI slots on the back of that TV. Switch you HDMI cable to use another slot. Change to that HDMI slot on your TV menu. Sometimes the ports go bad, or there is something messing with the signal.
The HDMI can carry sound and video. Make sure that in your tv menu that your tv is setup under audio has the receive audio from hdmi as well.
Sep 22, 2009 | Televison & Video
Philips 51pp9303h/17 dptv345 chassis no audio or video
Apr 14, 2009 | Philips 51PP9303H Rear Projection...
CONVERGANCE REPAIR KIT FOR HIT 43FDX01B
Yes - But Ddent will not provide any instructions or support with your repair. If you need that goto sites such as www.TVRepairKits.com instead.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 07, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Televison & Video Logo
332 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
