Question about Dell Axim X50v Pocket PC
It won't turn on, bt the battery still charging
My axim v50i suddenly won/t turn on, eventhough i've charged the battery, please teach me how to turn it on via ac power to check if the problem is the baerry or the hardware, and could it be a software problem, how can i fix it, and where can i fix it, i'm in jakarta, Indonesia, thanks a lot...
Another way I've found to do this is to press the power button and reset button at the same time. Then when you get the message to clear all data press cancel. I get this every time I re-charge my axim in the cradle. Doesn't anyone have a better solution? When it happens I have to reset my time. It's usually a day behind.
Posted on Jan 18, 2008
Take out battery, put cover back on. Plug to cradle and turn on. Then do soft reset while on the cradle working. After, turn off , remove from cradle and install battery. Turn on with battery only.
Posted on Oct 26, 2007
  • 3 Answers
Please help...it works except for he last step. i am the guest who has the same problem above.
Posted on Jan 13, 2008
This was very helpful because i broke my cradle so i had to wait a year till i got a charge cord of eBay; however, that last step did not work. it put my battery in and it did not work..again. all other steps worked however. what is going on.
Thanx a lot, i did it, finally can turn it on...thx...bless u
  • Kimberly D Sep 28, 2010
    I am having the same problem and have tried all of these steps, I even bought a new battery and it will still not work. It also says AC only in battery settings. It will only turn on on the cradle/cord. It used to blink when I was charging it as well and it doesnt do this anymore either. What do I do?
I had the same prob. Went to dell site and found this. Take out battery. Put the cover back on. Attach to cradle and turn on. While it is on, do a soft reset. Turn off, take it out of the cradle and put battery back on. Try turning on with battery only.
Help, as others my pda wont turn on, i tried taking out the battery and tuning it on whist inside the cradle but it still wont turn on, tho when it is attached to the cradle the orange light comes on the power button. I'm totally clueless please help!
Posted on Feb 07, 2008
My textbook 7p won't turn on
This tablet does t reset with the power button unlike other Android devices. When you hold down the on/off switch, it only drains the battery. If you see the color indicator still charging, allow a full charge.Then, only stay put and pulse the button for a moment quick and let it rest few seconds to try again and again. Only when u see a light coming out of the screen, and I recommend you do this with the power cord on, you hold the power switch down until the rebooting is iniciated. Let go til it is finish and see where the problem is. More likely, like mine, the Settings stop working and needs tune up for the CPU. Never leave an application running when closing your system. With or without internet connection.
Apr 20, 2013 | Tablets & eReaders
I haven't turned the camera on for a couple of years. I've tried charging the battery, but I can't get it to power up. Do I need to replace battery or is it something else?
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 06, 2012 | Samsung i85 Digital Camera
Charging problem of dell pp41L, it works as an ac online power bt it doesn't charge it.
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
May 20, 2012 | Dell Computers & Internet
My dell axim does not charge a new battery- I tried 2 new ones.
check the charging unit or the plug on ure phone,it mite be loose and not charging
Sep 24, 2009 | Dell Axim X50 Pocket PC
MY DELL AXIM X30 WILL NOT TURN ON
My Axim X30 would not turn on using battery power but would turn on when connected through charger adapter.
Solution:
1. Connect AC adapter directly to the charger adapter and then to the Axim X30 and to the electrical outlet.
2. Charge battery until power button is solid green.
3. Press the power button to power on.
4. Remove cable from cable connector leaving the cable connector connected to the Axim X30. The Axim X30 will remain powered on.
5. Turn the Axim X30 off.
6. Turned the Axim X30 on using battery power.
7. Remove cable connector from Axim X30.
Apr 07, 2009 | Dell Axim X30 Pocket PC
When charging my axim X30 on the cradle, the on-off light is blinking from green light to amber consistantly... when I remove the device from cradle the device does not turn on at all.. I have replaced the...
It sounds to me that your "original" battery, the one that causes the blinking when charging is completly drained dead, causing it to show an error by blinking the light.
I have one of these PDA's and have never had that problem, I also have a larger battery as well, and it works great. I suggest recycling the other battery, and possibly purchasing another larger one for back up,
Mar 27, 2009 | Dell Axim X30 Pocket PC
Reset button won't work on dell axim x51v
to wlumbria... hey listenup... if ur connecting ur pocket pc to the cradle it is not only used for the flow of data bt it also charges ur pocket pc... bt the chargin is quite slow  it will keep on showing  the red lite as compare to an charger it will charge fast and the red lite will turn green... so wht i suggest charge it with a charger not with a cradel if stil it doesnt wrk try changing the battery...!!!
Aug 21, 2008 | Computers & Internet
Dell Axim Powering on Issues
This happens to me all of the time now when I charge my axim on the cradle. I press reset and power on button at the same time and the cancel when it asks if I want to delete memory. You'll have to reset the time then.
Jan 13, 2008 | Dell Axim X50v Pocket PC
Battery Charge - First Use
My experience was similar to yours. The LED turned green after about only 2 hours. Because I didn't want to stay up until midnight to start playing with my Axim, I took it out of the cradle after the 2 hours and everything was fine. Besides, having downloaded and read the user's guide 2 days before receving my Axim, I knew that a green LED meant it was ready to go. 3 days later, everything is still fine and seems normal. A year ago, I received a Palm with similar initial charging requirements, and it also didn't take as long as the directions said it would.
Sep 13, 2005 | Dell Axim X5 Pocket PC
Dell Axim X50v Pocket PC Logo
2,068 people viewed this question
Alun Cox
