I went to make a cd today and the computer said to connect cd burner and restart . the only thing is i have a internal burner and its never given me this problem before . i just recently installed norton 360 because i had a trojan virus is it possible it was deleted and i have to get a copy of the burner and reinstall.
XP provides buring software for CD-ROMs
First check device manager to make sure CD-ROM is listed. If it is listed, try to use XP to write files to the CD.
Norton should not have affected the CD writing capabilities.
If you cannot write to the CD, use device manager to remove the CD-ROM, and then restart your computer. New Hardware utility will reinstall the required software
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
select properties general troubleshoot, select driver click to reinstall drivers click update driver
