Question about HP Pavilion zv5000 Notebook
NOT WORKING AFTER PRESS THE SWITCH ON
My pavilion zv5000 is not switch on. I checkend the power supply it is OK.I checkend the Battery it is OK. I checkend the ON/OFF switch it is good woerking. What the problem?? GCH
  • Kim Bessent
    Kim Bessent May 11, 2010
    When you hit the button to turn it on, what happens? Do the lights turn on, then off again? Do the lights come on and the computer beeps three times? Do the lights flash then shut off? Does it just sit there?
My boyfriend has a HP Pavilion ZV5000 laptop running Windows XP. Everything loads fine. then he trys to log into his user name, puts in the password... it sais loading your personal settings, then the...
Starting point would be to turn the computer right off including taking out the battery unplug the power supply wait a while and then reconnect power supply and restart holding down the key that allows you to enter the BIOS. Reset the BIOS to default settings and then restart. If this works then reinsert the battery and hopefully this will fix your problem.
Sep 11, 2010 | HP Pavilion zd7000 zx5000 zv5000 presario...
Hp pavilion ZV5000 was working fing, now it does not start, no lights, with A/C adaptor or battery, wonder if this is a common issue that others have seen.
Yes it is. You either have a bad AC adaptor or a bad internal power supply. My guess, the power supply.
About a $300 fix when sent back to HP. I fixed mine once. Next time its a new computer.
Nov 17, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
HP Pavilion zv5000 - No power with battery in.
the jack is the problem it is not getting enough power to laptop
Nov 02, 2009 | HP Pavilion zd7000 zx5000 zv5000 presario...
My zv5000 has worked well for at least 3 years.
Have you cleaned or blown out the ventilation ducts and grills since you have owned it. If you haven't, there is the possiblility that the thermal paste has been baked off the processor and there has been damage done to the motherboard. The laptop will run fine with no battery installed. Get a few cans of compressed air from an office supply store and using short bursts of air, blow out the grills and all the compartments. If there is easy access to the heatsink, most likely that needs to be pulled and cleaned, as well as the processor and new layer of thermal grease applied. Remember though, if it isn't powering up at all, there could be the possiblility that the ac adapter is no longer putting out the correct voltage to power the system up efficiently. Have your power supply tested, to make sure it is putting out the correct voltage under load.
Oct 09, 2009 | HP Pavilion zd7000 zx5000 zv5000 presario...
My pavilion zv5000 not working after I press the on switch. Lights turn on but i dont hear or see anything?
Good day sir/maam, problem with your laptop memory. look underneath to locate the access panel for your laptop memory, or better see your dealer for the problem and possible memory upgrade.
Oct 09, 2009 | HP Pavilion zv5000 Notebook
PAVILION ZV5000 MAINBOARD: NVIDIA HEATS UP, REST STAYS COLD!
Sorry to tell you but I've seen to many of these - your motherboard has failed. I had one that did the same tried everything except holly water. It is a failed nvidia chip.
Sorry
Glenn
Mar 08, 2009 | HP Compaq Presario V6000T Notebook
Does this Hp Pavilion zv5000 Laptop Batteries Fits for Hp Pavilion ze Series Laptop
hp pavilion zv5000 battery Compatible with Code:
  • Compaq 346970-001
  • Compaq Hstnn-db02
  • Compaq Hstnn-ub02
  • Compaq pp2100
  • Compaq pp2200
  • Hp 346970-001
  • Hp Compaq Hstnn-ib04
  • Hp dp390a
  • Hp dp399a
  • Hp Hstnn-db02
  • Hp Hstnn-ub02
  • so it is campatible with it~~
  • Nov 21, 2007 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
    HP Pavilion zv5000 Notebook Logo
    142 people viewed this question
    Top HP Computers & Internet Experts
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
