Question about Gateway FPD2275W LCD Monitor
Yellowish display Monitor of my desktop gives yellowish display for some time and after that returns to the normal display...I don't do anything, everthing is done automatically.
  • Ashwin Thejaswi Nov 25, 2007
    My monitor displays everything in a yellow tint. After keeping it running for a while it displays correctly, probably because it warms up. On top of all my product warranty expired last month, so there is no scope of free repair or replacement.
  • 136 Answers
This is due to one of two things, First the easiest is check the pins on the cableing going to the computer and monitor if its the type that you can change the VGA cable try that first. Sometimes when you move the cable around while its turned on with a signal to the monitor, and the video turns colors its the cable. However there are internal components that can cause this type of problem. If you have a yellowish tent then you have red and green working and blue is the culprit. If the cable is bad YAY! change it but at the same time if its manufactured with the cable molded to the case just go get a new monitor. Typically with monitors if ya gotta crack em open to fix em, its cheaper to just get a new one because of repair costs and you get a warranty with a new one. Let us know :-D
Posted on Sep 14, 2007
LG CRT TV, picture becomes yellowish
yes it is due to dry solder in vedeo driver section(a board fixed to the pict-tube.).
Jan 22, 2010 | Televison & Video
The color suddenly changed to where everything has a yellowish tint. And now the display is too wide to fit on the screen. How do I get it back to normal?
Right-click any free space on the desktop, choose properties, choose display, change the settings to 32-bit and which ever screen ratio you want.
Nov 20, 2009 | Proview PL926WBi 19" LCD Monitor
Lg display yellowish
your vga cable has broken twist it if works otherwise you needs to replace vga cable
Aug 14, 2009 | LG Flatron F700B 17" CRT Monitor
Yellowish colour of the monitor
check the datad cable of monitor, if ok.then soldring may be dry ot the CRT neck
Jul 29, 2009 | Samsung 793S 17" CRT Monitor
Auto-adjust not correctly fixing display
was it always like this if it want go to the start botton on windows all programs accessories then system restore restore it to the date it was normal if that dosent work then re install the disk that came with the monitor if there was no disk try playing with the monitors color settings and if then still dosent work!! then right click your desktop then click properites then settings tab then there should be a little bar at the bottom you can mode ajust it to the right setting hope this helps rate!
Jan 20, 2009 | AOpen F70PS 17" Flat Panel LCD Monitor
My monitor displays yellowish color instead of original color
yes please take the power on self test means disconnect signal cable and monitor will give
display without cpu if display appears then monitor ok fault is in cpu if not then fault is in monitor move signal cable and look display changes or not if changes then cable faulty replace it
Nov 11, 2008 | SAMTRON 55V 15" CRT Monitor
Monitor screen appears yellowish
resolder components on the CRT neck circuit! the color ICs or Transistor connections migth have loosen up!
Dec 06, 2007 | LG Flatron F700B 17" CRT Monitor
Screen Gone "Yellowish" Colour, Appears that Blue colour is not working
your problem is in blue color cathode circuit. as you say that it becomes ok tha5t means 1 cable wire is loose from computer to monitor. 2 crt base loose. 3 loose contact in blue video ckt. 4 signal processor cable to crt board connector loose.(blue wire)
Oct 14, 2006 | LG Flatron F700B 17" CRT Monitor
Gateway FPD2275W LCD Monitor Logo
160 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
