Typically a computer case has small brass screws holding the components in. Every case is different, but just start taking out any screws you see and dismantle it piece by piece, whatever becomes available to remove. Be careful of the ribbon cables, they are damaged easily. Be sure to ground yourself on something or wear an ant-static band.
SOURCE: how do you reset Acer Aspire T180-GB7Z PC
Perform a system recovery:
Does not come with recovery cd's - there is a program that allows you to burn the disks or
recover.
3 ways:
1. If in Windows - Start - Programs - Acer empowering technology - Acer E-recovery management -
click on Restore at bottom then "Restore to factory default settings"
2. Or click on Burn disks instead of restore
3. if unable to ge into Windows then Alt/F10 during boot right after Acer splash screen on startup
End User Technical Support and Service (USA only)
For end user technical support, spare parts and service: 1.800.816.2237
SOURCE: Upgrading ram in an acer aspire sa80
I've read up on the 661GX-M7 by looking at the manual at http://eudownload.ecs.com.tw/dlfileecs/manual/mb/eng/p4/661GX-M7.pdf all it does is agree with what you've done. It should be able to handle 2GB of DDR400 without a Bios update and Kingston's definitely one of the best to go with. All I can think is that it's not the RAM. If you're alright inside a PC case try breaking it down to a bear minimum, so just graphics card, memory and processor and see if it acts ok like that. If it's not then one of those things is setting it off and you might have a dodgy stick or you might have handled the memory too much. If it's ok, then plug one thing in at a time and retry until you find the culprit.
SOURCE: Upgrading my Acer Aspire M1641 Desktop graphics card
The motherboard will support any PCI Express x16 or PCI Express 2.0 x16 video cards. Your main concern should be with the power supply since it is either a 300w or 250w.
Here is a pretty good choice for your price range:
http://usa.asus.com/products.aspx?l1=2&l2=8&l3=725&l4=0&model=2328&modelmenu=1
Input your info here to see if you need a power supply upgrade.
http://support.asus.com/PowerSupplyCalculator/PSCalculator.aspx?SLanguage=en-us
A little money for system memory would be good if you have less than 1 Gig.
You can test it here:
http://www.crucial.com/systemscanner/index.aspx
If you are saving money by not buying a motherboard and want to spend it (which is what I would do), I would put the money into a the video card and power supply.
Like this:
http://usa.asus.com/products.aspx?l1=2&l2=8&l3=726&l4=0&model=2705&modelmenu=1
And this:
http://www.amazon.co.uk/Netzteil-Corsair-620W-ATX-2-2/dp/B000KJNK8U/ref=sr_1_10?ie=UTF8&s=electronics&qid=1248740669&sr=1-10
I do not know the dimensions of the Aspire Case, so one thing to keep in mind is the dimensions of the card and the power supply. Make sure they will fit before buying.
If you start replacing motherboards and such, you might as well just go with a whole new system. A new motherboard, new CPU, new memory, new graphics, new power supply, fast hard drives, new case.
SOURCE: Acer Aspire E360, Need new Motherboard, cpu and powersupply
If you're going to replace the Mobo, Processor, and PSU, you may as well as replace the computer case, also.
Another $50 USD will buy you a decent computer case.
(Seen this? http://www.directron.com/cs888uvbl.html )
You can reuse your optical drive/s.
Mobo? Are you going to stick with AMD processors like what is used in your computer now, or are you going to go Intel?
AMD hardware is cheaper price wise, but not quality wise. Myself I prefer Intel.
Just a personal preference.
Dual core processor with DDR Sdram ram memory?
You're not going to like this answer, but this = No, for Intel processors.
DDR2 Sdram for dual core processors.
There are some older AMD processor based motherboards that do utilize DDR Sdram, and dual core processors.
It is IMHO this is going backwards.
Why?
Because using DDR Sdram will cause a 'bottleneck' of information. The dual core processor will be bottlenecked, by the slower DDR Sdram ram memory.
Also, I would imagine you would like to be able to buy a dual core processor now, and be able to use a Quad Core processor in the future, on that same motherboard.
Again, I'm more towards Intel than AMD, so forgive me if I'm talking to an AMD man.
I go for the 'Best Bang for the Buck' theory.
More performance for lesser money spent.
It is for the above reasons that I would recommend an XFX nForce 750i SLI Extreme mobo.
Why?
1) Supports Intel Pentium 4 processors, (With an 800MHz FSB, and fit into an LGA 775 processor socket), all the way up to an Intel Core2 Quad.
(Supports Intel - Pentium 4, Pentium D, Pentium Extreme Edition, Core2 Duo, Core2 Quad, and Core2 Extreme processors)
Supports Intel processors utilizing the 45nm architecture, and up to a 1333MHz FSB. (800MHz, 1066MHz, or 1333MHz)
2) Supports DDR2 Sdram at either 800MHz, or 1066MHz. (PC2-6400 and PC2-8500 respectively)
4GB's with a 32bit operating system, 8GB's with a 64bit O/S.
(A 32bit operating system has it's limitations. Only 3.2 to 3.5GB's, will be recognized of that 4GB's of ram memory)
3) Has Two PCI-Express x16 graphics slots, that use the PCI Express 2.0 technology. You can install two graphics cards, that utilize the SLI technology. (Scalable Link Interface)
With this motherboard, when you use two graphics cards, BOTH will operate at 16X.
Not 16X for one, and 8X for the other, like some motherboards.
(Things they don't tell you)
(Information about the Nvidia nForce 750i chipset, from Nvidia.com,
http://www.nvidia.com/object/product_nforce_750i_sli_us.html
Click on the Specifications tab)
Has 4 SATA headers on the motherboard, that utilize the SATA 3.0Gigabit per Second technology. (3.0Gb/s)
4) The MOSFET has a heatsink on it, as well as the Northbridge chip, and Southbridge chip. Plus there is a heatpipe in-between these heatsinks.
Helps keep everything nice, and cool!
5) Price is $70
2GB's of decent DDR2 Sdram at 800MHz, (PC2-6400), will set you back about $50.
You can buy a Motherboard/CPU combo with the Intel Core2 Duo E7500, for $190 USD.
(Intel Core2 Duo E7500:
Two processor cores operating at 2.93GHz Each.
3MB's of L2 cache.
1066MHz FSB
Based on the Wolfdale Core.
For the power supply, I would recommend an OCZ StealthXStream 600 Watt.
Why?
Because if you keep the temperature of this PSU at 118 degrees Fahrenheit, (47.9 degrees Celsius), it can reliably put out 728.8 Watts.
(Remember, 80 percent of the rated maximum wattage, is the figure you should go by.
80 percent of the rated maximum wattage, when the PSU is operating at a 100 percent load)
Has Four 12 Volts power rails. EACH 12 Volt rail is capable of handling 18 Amps.
Total is 72 AMP's!
Has all the power cables you will need.
Has a 120mm fan.
A larger fan means it will turn slower, and still produce more air flow.
Also will make less noise. (Unless you are running an intense game at high settings. You won't hear it anyway, because of the game!)
Just my thoughts. If this is not what you had in mind, please state so in a comment.
(Additional comment. I think utilizing two graphics cards in an SLI configuration, is redundant. Basing this statement on price versus performance.
Again with the 'Best Bang for the Buck, theory, but I would recommend an EVGA Geforce GTX 260 Core 216 graphics card.
Graphics performance is VERY close to an Nvidia Geforce GTX 280, but at way less cost)
SOURCE: Acer Aspire AM1640-U1401A has black screen-@ boot attempt.
Had this issue with two Acers of similar make. Replacing the Motherboard resolved the issue on both.
