Question about HP PSC 2410 All-In-One InkJet Printer
Not working at all
Dear sir, the light is under signal on and off continuasly
    President:
  • HP Master
  • 2,022 Answers
Remove all the catridge and then switch on and see
Posted on Sep 26, 2007
SOURCE:
My Rear Lights Don't Work
I assume you must have broken an earth wire to the rear lights.
Test the feeds with a test light to verify they are ok , if good, just add an earth wire.
However, if tgere are no feeds to lights, you must have dropped a block connector and will have to trace it back..prob under tank!
Jan 12, 2018 | Ford F-150 Cars & Trucks
Loss of speed signal
Dear Sir:
Use the calibration software for easy diagnose and troubleshooting.
Most of them is coming from under the Hood of the motor for instruction follow the steps, or use your user manual.
Adjust the speed sensor see the diagrama, and tight the wires from the sensor.
2_17_2012_12_19_32_am.gifsincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Feb 11, 2012 | Quantum Fitness Q 3.0 Light Commercial...
Dear Sir, I was hoping you could diagnose a
your signal switch is going out and needs replacing , check all the under dash connectors that go up into that area , NOTE,,,, unhook the neg battery terminal, and then the positive one, and wait 10 minutes before doing anything , this will allow the air bag system to disengage and work can be done on the system ,, always do this when messing with any under dash connections that go into the steering wheel area,, once you've finished,, hook the battery up, Pos first then neg ,, clean and tighten all connections
Aug 22, 2011 | 2004 Ford Explorer
Why does the eco light flash when i set a programme
My Eco light was flashing fast ,and the drain pump was running continuasly.It turned out at the drip tray was full of water and micro switch add activated . i tipped the machine forward drain the water off the machine as be working fine since. PS dont know why drip add so much water in it, unless theres a leak. ???
Mar 05, 2011 | Hotpoint 24 in. FDW60 Free-standing...
My trucks turn signal lights only work half of the time, what could be wrong?
sir, maybe your turn signal lights fuse are busted. you try to check sir.
Dec 19, 2010 | 1988 Chevrolet K1500
Installed a new indicator switch on a lml star dlx as i had problems with the previous one. i started it up and it worked but to my dismay it wont work 12 hrs lateri have checked every connection under the...
If it was working, but now is not, then the problem sounds like the rear left bulb is blown, causing the front one to stay on continuasly.
If all your bulbs are fine, then it could be the flasher cam unit is faulty. Some simple tests can be made with a 12volt test lamp, to see where you have power and where you dont
Good luck.
Jun 27, 2010 | Motorcycles
Rear turn signals don't work, bulbs are good, front signals blink fast, at first only drivers side didn't work occasionally, now neither side works at all. What's wrong?
are you sure bulbs are good ?? double check bulbs also make sure there is a ground wire from your light fixture is grounded to the body near by this might be causing your problem .. usually if front ones blink fast rear bulbs are bad ... thanks Jerry holler if you need more.
Jan 29, 2009 | 2004 Pontiac Grand Prix
1994 s10 blazer 4x4 passenger side rear turn signal / brake light
I would guess that you might have trailer wireing that could be a couse. not to mention have you checked the ground?
Jan 09, 2009 | 1994 Chevrolet S-10 Blazer
No charging
defective battery. call tech support and they will replace battery for you for free.
Oct 21, 2007 | Casio Exilim EX-S600 Digital Camera
HP PSC 2410 All-In-One InkJet Printer Logo
22 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
