Question about JVC TH-A35 System
TH-A35 receiver only get sound from left and right channel of a 5.1 surround sound receiver. I ran the test patterns through all of the speakers so i know they are working. seems to be receiver related
    Problem Solver:
  • 13 Answers
You can't get 5.1 sound from a MP3 source !!! You get a 5.1 sound only from a good STEREO (analog) source or from a REAL 5.1 DVD audio track. Also check your "Autosurrond" setting on the remote-control.
Posted on Sep 15, 2007
SOURCE:
Pioneer VSX-818V-K Receiver
wondering if input levels are too high on some channels causing safety limits to shut it out..check level outputs on eguipment.
Jan 08, 2014 | Pioneer VSX-818V-K Receiver
Subwoofer
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
Jan 03, 2008 | Yamaha RX-V640 6.1 Channels Receiver
Hi, I hve JVC TH G30 and i have connected my DishTV receiver (not HD) to the Aux port of the device. I can get sounds only on the front left and right speakers.. Is there an option to get surround for...
This is a 2-part question. You can get ALL speakers to SIMULATE a surround experience from ANY input, even 2-channel analog.
If there is an optical digital audio output on the Dish TV receiver use THAT and the TH-G30 can decode the surround audio properly.
Read up on surround modes in the manual.
Jun 07, 2011 | JVC TH-G30 Theater System
Only two of my speaker channel's work when I hook my speakers into it, and one of those two only powers some of the speakers in my Infinity Beta 50. The surround sound channels do not work either. only the...
You have to configure it first. Make sure you follow the instructions on page 5 of your manual to run Auto MCACC Setup which tests the acoustics of your room, speaker size, power level, etc. This is necessary before it will enable you to use surround sound.
Apr 13, 2011 | Pioneer VSX-72TXV Receiver
In dolby digital mode i can not get any voice volume. All other sounds are ok
Assuming that you mean Dolby digital 5.1, confirm that you have a center channel properly connected and perform the following;
Using the remote, enter the menu on the receiver and navigate to the selection labeled "LEVEL." Toggle through the selections until you reach the "CENTER CHANNEL". You will be able to use the remote to increase the volume of that channel in .5dB increments.
Feb 01, 2011 | Denon AVR-589 Receiver
Unable to connect surround sound with a stero player
There is a obvious difficulty here. If you have a stereo receiver then it can't produce surround sound. You must have a surround sound receiver to present true surround sound. If you already do have that then on the back of your Phillips set there are audio outputs. The left and right audio out will be decoded in your surround sound receiver and they will automatically play from your speakers. You should have seven speakers, center channel, left and right front speakers, left and right rear speakers and left and right mid or side speakers. A sub-woofer would be nice too. Best bet is to speak with the store you purchased the set from. They will have that information.
Zashiban
Jun 23, 2010 | Philips Televison & Video
Sony STR-DE635, Sound from left surround speaker but not right
first turn the actual volume up on that channel on the reciver then make sure your speaker wires in the rear are using the same lenght each
May 18, 2009 | Sony STR-DE635 Receiver
Reciever only allows 2 channels(speakers) at a time.
If the amplifier is not receiving a surround sound signal, you will get nothing from the rear speakers and probably nothing from the front centre. Play a dvd in dolby surround and it will work.
Apr 14, 2017 | Pioneer VSX-918V Receiver
No sound from all speakers except front left and front right
Check the cables from the DVD to the Amp and make certain your in Dolby Digital mode on player.
Jan 24, 2009 | JVC TH-G30 Theater System
I had this problem too. Finally, after using the MCACC setup and making sure all the speakers worked, I found I had to set the source to FM, TV or whatever from the remote control and set the mode to advanced surround sound using the front panal button on the upper right. Had to fool with them a lot. Good luck.
Jan 03, 2009 | Pioneer VSX-818V-K Receiver
JVC TH-A35 System Logo
177 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
