Question about Brother DCP-7020 All-In-One Laser Printer
Back cover error on LCD won't go away
I have a Brother DCP-7020 and after opening the back cover yesterday, the LCD keeps saying that I need to close the back cover. I have tried powering it on/off, taking all the paper out of it and even slamming the back cover. Nothing seems to work. I need help!!!
  • 2 more comments
  • Ashantix Sep 17, 2007
    Is there a way to trick the machine to think that the back cover is closed until I can get it fixed?
  • Anonymous Nov 13, 2007
    I am having the same problem on my machine. I tried everything possible. Can't find my owner's manual to make sure that what I see as the back cover is indeed that. I've opened & closed everything that I can open & close. I've turned power on & off. Where would I find this switch / lever to see if it is defective? What tab are you talking about ...for me "to stick something in the hole"?
    This problem started what some paper got jammed in the copier a couple days ago. Every thing got cleaned out ...but the copier will still not work.
    Am I able to download a copy of the owner's manual through you?
    please respond to email: mark@earthscape.ca.
    This is most likely caused by the back cover switch. It is either broken or the lever on the back cover is broken off.
    Comment by WhIzAtIt, posted on Sep 17, 2007
    Well if the switch is defective, youll have to defeat it internally, but if its the tab just stick something in the hole.
    I am having the same problem on my machine. I tried everything possible. Can't find my owner's manual to make sure that what I see as the back cover is indeed that. I've opened & closed everything that I can open & close. I've turned power on & off. Where is the switch / lever you're talking about so that I can see if it is defective or broken off? What about this 'tab' you're talking about to stick something in it?
  • jlmb22 Apr 14, 2009
    I had a paper jam and opened the front of the printer, removed the drum, then fixed the paper jam adn put the drum back in. After I did this the LCD now says close back cover and I never even opened it. i have no idea how to fix it and I can't print or scan anything.
    Scholar:
  • 136 Answers
Posted on Sep 14, 2007
  • Beau  Delony
    Beau Delony Sep 17, 2007
Back cover open message but cover is closed
Sounds like the sensor has been damaged try turning off at wall and re starting if it continues you'll have to go into maintenance mode and reset
Apr 09, 2014 | Brother DCP-7020 All-In-One Laser Printer
The screen says the "back cover is open" and
If you turn the printer off and then back on with a paper jam in it you will get this error message instead of a paper jam message. To clear the paper jam from the back of the printer read the instructions from here: http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000600/000096/faq000696_001.html?reg=us&c=us&lang=en&prod=mfc7420_all&Cat=11
Jan 24, 2011 | Brother DCP-7020 Black and White Copier
Dcp 7020 "Back Cover Open" lights up even after it
Try doing a power reset.
Turn off the printer/Unplug it for a few minutes/Plug it back in/Turn it back on.
Jan 11, 2011 | Brother DCP-7020 All-In-One Laser Printer
Brother DCP 7020 error 'back cover open close
  • Open the back cover.
  • Pull the flap down that hides the orange roller on the fuser (be careful: it's hot)
  • Locate the inner flap that runs from the centre to the right hand side.
  • 3/4 along the right hand side, there is a tiny little perpendicular appendage on this bar that should sit in a slot. Locate it properly and the error will go away. You can go that by slightly bending the slot if fits into on the inner flap. The appendage can get jossled out of the slot when one is removing jambed paper.
Feb 02, 2010 | Office Equipment & Supplies
The Brother DCP 7020 printer displays error
back cover door switch is displace so it called back cover open.
Oct 12, 2009 | Brother DCP-7020 All-In-One Laser Printer
Brother dcp-7020 printer shows error back door open.
open the front door then pull away your ink cartridge then clean dust or blur from ink cartridge position then refix ink cartridge again.
Mar 21, 2009 | Brother DCP-7020 All-In-One Laser Printer
Help
one ot the doors, most likely the one on the right is not closed, there is a sensor switch there it is not being activated, make sure all levers are in he correct positions so the doors can close evenly.
Jul 23, 2008 | Brother DCP 7010 Multifunction Laser...
Brother dcp 7020 says toner end life
unplug plug it back in, did you remove the protective cover and clean coria wire?
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000000/000065/faq000065_018.html?reg=us&c=us&lang=en&prod=dcp7020_us
Dec 20, 2007 | Brother DCP-7020 All-In-One Laser Printer
The printer jammed and now will not restart
unit was turned off while it had this error, follow these instructions:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000600/000096/faq000696_001.html?reg=us&c=us&lang=en&prod=dcp7020_us&Cat=4
Dec 03, 2007 | Brother DCP-7020 All-In-One Laser Printer
Brother DCP-7020 All-In-One Laser Printer Logo
324 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
