Question about Nintendo DS Console
Replaced top screen on ds will not power on
This is the second DS I have replaced the top screen on. Both times, everything seems to go well until I put the unit back together and turn it on. The lower screen flashes (and light) then it shuts off. I have checked the small ribbon cable a dozen times and had 5 other people try pushing it in and it does not appear to go in any further. Is there something else that I may be doing wrong to cause this.
  • Sweetum Sep 17, 2007
    I am not sure what you mean by" change a new one flex ribbon wire or lcd".
    I was changing the LCD screen on top. The LCD comes with a new ribbon cable.
    Originally the top lcd screen was broke. I put a new LCD screen in and when I was finished the green light comes on for a sec. the lower screen flashes on, then everything shuts off. I did not have anyone else try until I did not know what else to do
  • 790 Answers
The Flex ribbon wire is sensitive parts! you said a dozen times and 5 people that they are trying to fix your DS! ok before you did the action you got the same problem... change a new one flex ribbon wire or LCD.
Posted on Sep 16, 2007
SOURCE:
My action replay just deleted everything i had how do i fix it
This has happened to me to, so don't worry! 1. You could hook it up to your computer and resync it there. 2. 1st, hold Select and Start at the same time, then turn the DS on. keep holding it until after the DS' top screen says "This product is not licensed or endorsed by Nintendo". Keep holding Start and Select until it fades a different shade of white, then wait for a second, then turn off the DS. Now try the AR.
Oct 16, 2010 | Video Game Consoles & Games
Power led lights green, touch screen flashes white and powers off
try taking it apart again and checking closely to see if any inner cable is loose,
Apr 13, 2010 | Nintendo DS Lite Console
Have just replaced both bottom screens a little fiddly but no problem but now ds will not start up, put the charger in and the orange charge light apears for a split second then goes off and console will...
Hello!
If you replaced the lower LCD PLEASE check to see if you put a pad on the bottom of the lower lcd... If the metal is touching the board then your LCD and causing the board to shutoff! and not power on.
That's the main reason your DS wont power on if you changed those things.
Also!
Your F1 or F2 fuse could have died out as well.
Dec 29, 2009 | Nintendo DS Lite Console
My ds lite wont power on how can i fix it?
One of you're screens is broken or the F2 fuse has blown.
Check youtube for a video on "how to check my DS lite F2 fuses" there are several available that give step by step guidance on how to do this.
Having checked these (and replaced blown ones) and you're screens are still not working then it is a screen that has blown.
If the bottom screen flashes for a split second when you turn it on then it is you're TOP screen that has blown and needs to be replaced. If it doen't flash then it is you're bottom screen that is broken and needs to be replaced.
Sep 10, 2009 | Nintendo DS Lite Console
Nintendo ds lite bottem screen problems
go to gamestop or another gaming place like game crazy and get it repaired. (don't know the fee though)
Jun 04, 2009 | Nintendo DS Lite Console
Nintendo no power
I had bridged the F1 and F2 fuses and then replaced the top screen and seemed to fix everything
if you need more info or are looking for someone to repair I also do console repairs and have fix quite a few nintendo ds lite systems.
let me know and ill help you out.
either info or a fix
Aug 24, 2008 | Nintendo DS Lite Console
Nintendo ds lite not turning on
see if you need new carger or if it needs new batteries
Jun 26, 2008 | Nintendo DS Lite Console
I have a version 1 DS,
Theres a good chance that the cable might have been damaged in replacement of the top screen. check the tiny inserts at the end. But first, see if the cables' fully connected. As for the battery, it might already be at capacity, and is fully charged. that might explain your 3 second charge. Anyone please write if this helped you in any way.
Jun 02, 2008 | Nintendo DS Console
Onceturned on, the green light goes on, the touch screen flashes white, then it all turns off.
You might only have a loosen screen ribbon cable.
If not careful while taking out the top screen ribbon you can damage it causing blank screens and finally the DS wont work.
The solution to a broken top screen ribbon is to replace the whole screen in DS lite or buy the ribbon cable in the DS fat and replace.
If the broken top screen ribbon is caused by broken hinge then you should replace the shell also to avoid other broken screen.
May 22, 2008 | Nintendo DS Lite Console
Nintendo DS Top Screen color is faint.
It's very possible that you didn't remove the protective film that the top screens almost always come packaged with. If that's not the case it might just be a loose connection, but that's doubtful, or a lesser quality screen.
Oct 08, 2007 | Nintendo DS Console
Nintendo DS Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Ekse
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
