SOURCE: f2 maintenance B required sf 2540 sharp photocopier
This is a drum code either the dm or id sensor.
SOURCE: Sharp copier sf 2530 developer reqired error code (ie indicator on)
It's hard to be sure because our model numbers are different but drum reset should be 24-7 and dev reset should be 24-6. Good luck
SOURCE: SHARP SF 2540 How to troubleshoot U3-20 and
U3,20 - Mirror motor lock detection
U7 00 - Communication trouble between PC/Modem and the copier.
Seems to me the U3 error is something similar to the L6 errors in the slightly newer machines. It seems as though the laser moter in your machine has seized.
As for the U7, i have had this error out on the field before. Especially when the machine has had IP setting put into the machine but the network cable isn't plugged in. Throws up that bad boy =]
SOURCE: Sharp copier SF-2025 displays an error code U%.
Hello sir; It can be reset by power on and open the front door, press and hold exposure key while you closing front door.
