FAN CASING AND FAN/HEATSINK
Hi as i am new to this site i am unawre of the protocols, so Hello everybody i ahve been given a 478 mobo which is a 478:- N4-IBFGL V1.3(GV the only trouble is there is no fan housing for the fan to fit in, i thougt i would try a 478 fan housin that i have and it doesnot fit the hols on the mobo are a lot smaller apart than a standard 478. I am having trouble locating one. I would be very greatful if you could point me in the right direction for one Many thnkas for your help All the best Simshi
  • simshi Sep 15, 2007
    thanks for your reply, unfortunatley this is not myboard but here is the link to a photo i tool and posted on net hope this helps a little more
    all the best
    Matt
    http://img146.imageshack.us/my.php?image...
    Scholar:
  • 136 Answers
You need to get a p4 fan with the 4 tabs to put on that bad boy: http://www.directron.com/heatsinkholder.html
Posted on Sep 15, 2007
  • 62 Answers
Is this your board? http://www.bikudo.com/product_search/details/9172/nec_galileo_845gl_n4_ibfgl_motherboard.html
CLip of motherboard felt off.
http://www.heatsinkfactory.com/cpu-retainer-clips-intel-pentium-4-478.html
That would be for an AOpen AX4SPE-UN motherboard, because it has a Socket 478 processor socket.
I had it happen to an old mobo in the past, with a Socket 478 processor socket; and no clips.
I used a straight piece of coat hanger, and went from hole to hole, on one side.
http://www.ebay.com/itm/P4-Socket-478-Intel-CPU-Retention-Retainer-Bracket-/140647148266?pt=US_Fan_Heatsin_Brackets_Accs&hash=item20bf392aea
Had a slight bend in the middle, and this bend went partially across one side of the finned Heatsink.
Small piece of coat hanger again, on the other side.
Cut to the right length, and with the correct bend, the two pieces of coat hanger, put even pressure down on the finned Heatsink.
Problem is they twisted. The pressure on the bent part against the Heatsink, made them want to spin up away, from the Heatsink.
So I added a piece of coat hanger on each side, to keep the side coat hanger pieces from twisting.
Hard to explain, and looked like something from Dr.Frankenstein's laboratory.
Worked though.
(Too much pressure, and it will break the plastic retention bracket on the motherboard.
Not even pressure on both sides, and Heatsink will not sit flat on Processor. This = No.
You just have to 'dial it in', (Coat hanger pieces), or use the correct part/s)
Regards,
joecoolvette
May 06, 2013 | AOpen AX4SPE-UN Motherboard
Right i need the size or model for the cooling fan that all intelboard mode E210882
The Heatsink/Fan combo is based on the processor socket used.
After a few search hits, I have seen E210882 on Intel based motherboards, that use two different processor sockets.
The Socket 478, and the LGA 775 processor socket.
The socket for the Socket 478 has the pin holes. The Processor has the pins. (478 of them)
http://en.wikipedia.org/wiki/Socket_478
The socket for the LGA 775 processor socket has the pins. The Processor has the pin holes. (775 of them)
http://en.wikipedia.org/wiki/LGA_775
Identify which processor socket you have, buy accordingly as to the Heatsink/Fan combo.
One example of a Heatsink/Fan combo for an Socket 478 processor socket,
(Only Intel uses the Socket 478 for their Processors),
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=578161&CatId=795
One example of a Heatsink/Fan combo for an LGA 775 processor socket,
(Only Intel uses the LGA 775 socket for their Processors),
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3302824&CatId=1588
Remember to observe Anti-Static Precautions, Thoroughly clean the top of the Processor's case, and aplly fresh new thermal paste.
(A Processor is the most susceptible hardware component to Static shock)
[ Example of thermal paste,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3071621&CatId=503 ]
If you would like advice on how to properly clean the processor's case, properly apply thermal paste, and/or what Anti-Static Precautions are, post in a Comment.
Nov 07, 2010 | Intel Motherboard
Need to find a new alum&copper heatsink and fan combo
This is a standard micro atx board. The holes you are seeing will be on any 478 mobo, you just have to remove the black bracket, which is usually achieved by lifting the center pin in each of the corners.
Sep 02, 2009 | HP COMPAQ BUSINESS DESKTOP DC5000 SFF - 1...
On/off connection
ftp://europe.asrock.com/manual/P4i65G.pdf
There is the manual, on page 18 you can see where to connect hte pw-led and the the pwr that ist the frontpower connectors.
And here is the support site for you mobo, in case you need updated drivers for it:
http://www.asrock.com/mb/download.asp?Model=P4i65G&s=478
Good luck
Nic
Apr 17, 2009 | Asrock 845GV (P4I45GV) Motherboard
No beep,No Display on my monitor,only CPU heatsink fan is moving
You motherboard has onboard video. It's possible it needs to be disabled and the option changed to use the pci or pci-express slot for the Ati card you installed. Since you have no post error beeps this is the best place to start. Also I had built a system not to long ago and had a similar problem. Resetting the cmos on the motherboard (usually a pin combo) solved the issue.
Start by hooking up your vga cable to the onboard video.
Hope this helps.
Apr 07, 2009 | MSI P7N Diamond Core 2 Quad/ Nforce 780i...
Fan and heatsink
Just ask for the fan & heatsink for the 478 socket. Its easily available in the market../
Nov 16, 2008 | Intel D845GRG Motherboard
How to change
Hi
Replacing the heatsink fan on a PC is not a difficult job, but it pays to be thorough, especially with cleaning the top of the CPU die before replacing the fan.
Don't be mean with money when choosing a new cooler either. With CPU coolers you get what you pay for. I personally always use coolers from a company called Zalman.
Ok ..with that out of the way ..the basics are ...remove old cooler..
They are either held on by a sprung clip that fits across the cooler and locates in lugs on the cpu socket surround, or they are held by screws that go through the motherboard.
Clean the top face of the cpu die carefully making sure to use a blunt implement ..... scratches on the machined face will lead to premature failure due to overheating.
If the cooler you buy has a "thermal pad" stuck to the face of the heatsink, then remove this too and clean up the heatsink face. Use good quality thermal paste on the top face of the CPU die, then fit the new cooler. Getting the right amount of thermal paste is a bit of an art .... too much is a bad as too little. The paste is NOT a glue. The paste simply fills in any imperfections on the machined surfaces of the cpu die and the heatsink to aid heat transfer.
Does this sound complicated? It isn't really. The key is not to rush it and make sure the surfaces are completley clean and the thermal paste applied correctly.
Here is a link to one tutorial on fitting cpu coolers that you might find useful:
http://www.jsyte.com/tutorials/replacehsf
Oct 31, 2008 | Intel Socket 478 CPU COLLING FAN & HEAT...
Upgrade CPU In my SAMBA SM-1845
Hi, as long as both chips are slot 478 it should work fine, you wont need to change any bios or jumpers, just open up the computer, remove the heatsink, lift the lever and remove the CPU.
Insert new processor.
you will need thermal grease at this point, you need to apply a little amount onto the cpu, and make sure the old thermal paste is removed from the heatsink and then refit the heatsink & fan.
other option is fit the new cpu and purchase a new heatsink & fan, they usually come with the thermal grease, a new heatsink will cost about £10 or themal grease by itself will cost about 2-3 pounds.
just make sure you have new thermal paste before you remove the heatsink as the processor will get damaged otherwise..
Hope this helps
John
Jul 31, 2008 | FIC Samba SM-1845 (SM1845GV) Barebone
The cpu heatsink clip has come apart, would like to know how to fix. the model is hp pavilion 734.uk
http://cgi.ebay.com/Intel-Socket-478-HEATSINK-RETENTION-BRACKET-Module-ONLY_W0QQitemZ170211538308QQihZ007QQcategoryZ14293QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
That's what usually breaks if you have a 478 pin cpu. Should be available in any computer shop. If the actual metal bracket on the heatsink broke you will have to buy a new fan/heatsink. Both solutions are cheap.
Apr 24, 2008 | Computers & Internet
My mother board AOpen MX4LR, socket 478, dead
bad mobo or psp is bad try psp for now lock down mobo tight also losee no good
Jan 06, 2008 | AOpen (MX4SGI4DN2PRE) Motherboard
Computers & Internet Logo
305 people viewed this question
David Payne
David Payne
