Question about Kenmore 23822 Top Load Washer
Kenmore Washer #11092273800. Will not aggitate or spin. Drains ok.
  • chsara Apr 16, 2009
    Thank you however there seems to be a white plastic part on the bottom that has broken. It fits into a black rubber piece that resembles a gun cylinder it has 6 holes. Do you know what that is?
    President:
  • 1,865 Answers
The Timer is the most common problem. Call Appliance parts store in your area for a price on new timer, and install it
Posted on Apr 15, 2009
Http://www.fixya.com/support/r823955-replacing_agitator_dogs
Posted on Jun 07, 2009
Kenmore top loader washer aggitates but does not spin out the water it drains but no spining any ideas?
The spinning coil might be not received power supply properly please check it then check spinning coil if it faulty means kindly change the motor
May 18, 2010 | Washing Machines
Washer was working made a clicking/humming sound now the aggitator doesent work and wont spin. Still fills and drains.
your motor coupler is broke,tip the washer back and look between the motor and trans that is where the coupler is located-mike
Feb 19, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Fills and drains but it makes a loud squeeling noise when it try to aggitate
does it spin ? if it spins sounds like you have in internal transmission problem to replace it would be roughly 1/3 cost of the machine
Dec 01, 2009 | Kenmore 22422 Top Load Washer
My Kenmore model 80 washer won't aggitate but spins and drains without issue. The aggitator tries to move but acts like there is a gear stripped or something.
you will need to purchase an agitator replacement kit for your washer and, the clutch will need to be replaced as well. these components are damaged and, replacing them will restore your units agitation functions.
Jun 07, 2009 | Kenmore 15944 Top Load Washer
Water drains during spin cycle, but tub does not spin and appears to have dropped down. Machine does aggitate.
If you can move the tub by hand laterally - the rear main bearing has likely failed - or the drum rollers are worn.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 30, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore 20842 won't spin or aggitate
Check your motor drive coupler. Tilt washer back against wall and look between motor and transmission . You will see a rubber grommet and two plastic couplers on each end of rubber , They may appear broken or you will see rubber shavings under washer.
May 11, 2009 | Kenmore 24032\24036 Top Load Washer
Aggitator won't work and won't spin/ drains ok
Coupling is bad.
There is a coupling between the motor and the transmission. When this part breaks then it will pump the water out but won't spin or aggitate.
Jan 18, 2009 | Kenmore 15944 Top Load Washer
Kenmore 70 series
First thing is to remove the 2 screws from the console, they may be hidden in the front or bacl of console. After removing screws, lightly push the base of the console towards the front of the washer and pick up. This will expose your lid switch connection. Using a jumper wire, jump out the black and white wires then try advancing your washer into spin/drain. The culprit will usually be the lid switch assy.
Apr 04, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Front Loader-Doesnt Aggitate nor Spin
the speed control board needs to be replaced in the lower rirght corner of the washer
Sep 12, 2007 | Kenmore 44102 Front Load Washer
Kenmore 23822 Top Load Washer Logo
201 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
