Question about Cameras
The cassette cage holding my tape in my Canon ZR65 camcorder will not release the tape. The door is open and the cage tries to move forward or backward (barely) and then stops---won't open up. I dropped my charger for my battery a few days ago---could the battery not be getting enough power to the camera to release the tape? This has never happened before.
  • 1 more comment
  • meyekb Apr 15, 2009
    I can't run a head cleaner because the tape is secure in the tape cage---it will not release the tape.  If I understand correctly, a head cleaner must be inserted into the space where a tape would be placed.
    My Canon ZR65 camcorder will not release the cassette tape from the tape cage. The outer covering (door) at the bottom of the camera is open and the cage is raised up as though it is ready to eject but it does not complete the action---it will not open up. The cage attempts to move forward or backward only slightly then stops.
    I'm not reposting anything-specifically, this is in regard to Rylee Smith. You must be kidding if you think I'm going to accept an answer like that. This is not a joke---I'm going elsewhere for help-
  • Cameras Master
  • 19,396 Answers
You can test the charger using a multimeter (it has +-0.5 volts from voltage written on charger), or go to a local repair shop and have it tested.
A more serious problem is if the tape is stuck inside or the release mechanism is broken. In that case camera will need disassembling.
If mechanism are moving slowly and screen does not come up this can be a power issue. Either charger or the connector on camera, that can have a broken solder joint. Also a faulty battery can cause the problem.
test charger with Multimeter , if it is fine go to a shop and test a charged battery. If it is a major issue and not charger/battery ask a quote on repair. You can also get an online quote here: Repair.
Thanks for asking us.
G.
Posted on Apr 15, 2009
    Brigadier General:
  • 8,619 Answers
Hi
Please turn off your camera and then switch it on again and then insert the tape cage back. After doing this place your camera on its side and thump on the side opposite the screen. Give it one or two thumps and it will work. This method has worked most of the times. If this doesn't work then check if the tape is not stuck between the head rollers. If not then you'll need to open and disassemble your camcoder. Please see this picture for details---
Please do accept this solution and revert for further assistance.
Thanks
Rylee
  • 10,515 Answers
Hi meyekb,
Try to run a head cleaner and using a hair dryer to gently blow air into the tape mechanism. Also remove batteries and let it stay disconnected for 20 minutes and then try again.
Also to avoid the problem:
1. Don't mix brands of tapes
2. Run a head cleaner through the camcorder
3. Only change tapes in a protected area/environment
If the problem does persist, contact the vendor you bought it from, or Canon directly, to get it repaired.
Thanks for using Fixya.
DO RATE THIS AS "FIXYA".
  • taran_2005
    taran_2005 Apr 15, 2009
    Yup.
    TRY THIS: Open the tape door on the bottom. LEAVE IT OPEN. Power off your camcorder and remove the battery. With the battery removed, move the power switch to ON. LEAVING THE POWER ON AND THE TAPE DOOR OPEN, replace the battery. The tape should eject without damage. This works for many other models as well.
    Any further help, let me know.
    DO RATE THIS AS 'FIXYA'.
Canon xl2 tape won't eject
This is a known problem.
Broken loading gear, Example: canon zr65 replace broken gear
Canon XL2 and ZR65 uses same tape drive system.
Feb 20, 2015 | Canon XL2 Mini DV Digital Camcorder
Grey line on the screen when playing de video
The head unit that reads the tape is dirty or clogged, or the tape has moisture on it. Try fast forwarding to the end of the tape then rewinding back to the beginning, sometimes this clears the moisture. If that doesn't work try buying a head cleaner from an electronics store and follow the instructions to clean the head. if that doesn't work you need to take it somewhere where they fix cameras or send it in to canon to get fixed. If nothing else works it's most likely a bad head. I have the exact same cam (zr400) and the same thing happened to me but rather than send it in to canon, (who refused to honor their warranty saying it had major sand damage when it never even went outside) i opened it myself and replaced the head with the one from my older zr65 camcorder. It worked flawlessly. Hope this helps -J
Dec 19, 2009 | Canon ZR400 Mini DV Digital Camcorder
I have an Elura 90. The cassette door opens but
When ejecting the tape you must hold the eject switch down for a full second. There are two stages to the eject process just as there are with the insertion of a videocassette. Hold the button in position long enough to hear the motor mechanism start.
Oct 30, 2009 | Canon Elura 90 Mini DV Digital Camcorder
Cann't eject cassette from Canon ZR60
I had a similar problem last few days with my ZR60.
The problem I had was that the tape won't eject and on repeated attempts to eject it would eject as if it had a mind of its own.
I was messing with it a little bit and realized that the door was not opening fully. Being a delicate item I didn't realize that I was not fully opening the door may be because there was a little friction in the pivot pins or what ever.
Try to gently swing the door open fully and see if it helps.
Since I discovered this problem I tried 10-12 times, and every time it would eject the tape and load it.
I was almost going to give up this camcorder last night thank GOD, I am able to use it.
Good Luck to you.
Dec 27, 2008 | Canon ZR60 Mini DV Digital Camcorder
REMOVE THE CASSETTE message
Perhaps this will help some.
I realized that this problem occurs on my Canon Optura 30 (consumer mini DV) when the tape is fully rewound. Tapes that are not rewound seem to work fine. If this situation appears to apply to you, try the following, and make sure that in the future you don't fully rewind your tapes!
Fast forward your tape in a tape deck or rewinder. It should play in the camcorder now. If you don't have a machine to do it for you, you can manually advance the tape with a pointy object and a pencil (the eraser--or your pinky!). On the back of the tape, locate the notch between the two spools (the "wheels") near the top, that is, opposite the side where the tape is exposed. The notch will have a spring-loaded slider inside which you can hold open to free the spools. Otherwise they are locked in place and you can't turn them. Holding the slider open with your pointy object, insert the eraser in the right-hand spool (i.e., when the exposed tape is pointing down and the "spine" of the tape is pointing up). Turn the spool slowly counterclockwise, making a few complete turns, to gather up a short length of tape, enough so you have a few seconds' worth of timecode. Be careful not to leave any slack. You can turn the other spool a little bit (clockwise) to catch any slack; lift the cover on the exposed tape (by holding back the little release) to make sure it is tight. If you're not sure which spool to turn, it's the one that does *not* have a window on the front side of the tape. (If the tape is fully rewound, the spool in the window should look full.)
Hope that helps, and good luck. In the future, I'll heed the common advice to use the camcorder playback as little as possible, relying on a tape deck for RW/FFand making sure to transfer material to scratch disks ASAP and then just storing that footage away in a shoebox!!!
Oct 09, 2007 | Canon ZR100 Mini DV Digital Camcorder
Machine just shut off when opening the cassette door. Locked up!!
look for a tiny pinhole and insert a pin while powered up to reset the device
May 27, 2007 | Canon ZR70MC Mini DV Digital Camcorder
Tape won't come out!
I had the exact same problem, and just by dumb luck, I managed to get the tape compartment to pop open after trying hundreds of things. Maybe this will work for you too...who knows??? What I did was to first remove the battery and AC power to "reset" the camera (I guess). I then put the battery back in place and WHILE HOLDING THE CAMERA IN THE UPRIGHT (AS IF USING THE CAMERA FOR VIDEO) POSITION, I pushed the "Open/Eject" latch. VIOLA!!! Like I said, it may be dumb luck, but I haven't had the problem again. It may be that gravity helped to take the stress off the ejecting mechanism...dunno???? BTW, when I was having the problem, the mechanism would "click" 3 or 4 times while trying to move the tape out. Good luck!!! I hope this helps someone!
Jul 24, 2006 | Canon ZR70MC Mini DV Digital Camcorder
Cassette jam
I had this problem, and here is how it was resolved.
My cassette would not pop out when I opened the door with the camera turned on. When I turned off the camera and opened the door, it slid out much further, but still failed to pop open so that I could remove the tape. Then it slid back in.
Remove the battery, and have the camera off, but make sure the power cord is connected. Open the door until the tape slides out further than at other times. (Note: It intermittently slides out further when the camera is off. Sometimes it will not slide out any further than when it is on.) When the tape is slid out as far as it will go, quickly remove the power cord. The tape will stay in the slid-out position. Now, at the bottom side of the tape door there is a curved channel for a small pin to slide in. This channel has a 90% curve at the bottom of the channel to catch the pin, which holds the door closed. Push that pin back a little (toward the lense) to get it to go around that 90% curve, and the door will pop open so you can remove your tape. The ribbon of your tape will be jammed in the camera a little, so you will have to be careful and move the ribbon around a little until you can get it out freely.
This worked for me twice. I did not try putting a tape in again.
I hope this helps.
Apr 10, 2006 | Canon ZR10 Mini DV Digital Camcorder
Cassette Jam
The most frequent cause of this type situation is not having a power source attached, or a depleted battery pack. Once the power source is available, some models require manually unlatching and opening the cassette compartment cover. When the cover is fully open, the videocassette will eject automatically. Please try the following procedures. 1. Attach the power source to the camcorder correctly or use a fully-charged battery pack. 2. Fully-open the cassette compartment cover until it stops while sliding and holding the OPEN/EJECT switch. The videocassette will eject automatically after a few seconds. If the videocassette still will not eject, seek assistance from a Canon Service Facility.
Sep 04, 2005 | Canon Optura 60 Mini DV Digital Camcorder
Cameras Logo
80 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
