Question about Hitachi 46BX01B 46" Rear Projection Television
Hitachi 46BX01B Convergence
I am told I need to try adjusting my TV by doing a Convergence setup. I do not have the original remote for this TV. Am I able to do the setup and alignment manual using the buttons on the actual tv? If so, please tell me how walk me through, I do not have my manual any longer either for this TV. Thanks!!!!!!!!!!
  • NCGirl1968 Sep 14, 2007
    What is the Chassis number?
    Genius:
  • 1,153 Answers
Do you know the chassis Number?
Posted on Sep 14, 2007
  • Lashawn Robinson Sep 24, 2007
    Could this be a 46FX01B?
My tv has double vision
What you describe sounds like a convergence issue. If you still have the original remote for the TV you can go to the TV Settings menu and then into the Convergence section. Try and adjust the red and then the blue convergence by using the arrows on the remote for up, down, right, and left.
If you are unable to adjust the convergence back to normal with the remote then your TV has an issue with the convergence chips themselves. There are six IC's that you would need to replace, and Hitachi also recommends that you replace the accompanying resistors at the same time, as the new IC's may cause the resistors to malfunction. If you pay a repair tech to do the job it will probably cost you between $3-400.00. IF you have the experience and the tools, you can go to the following website:
http://www.tvrepairkits.com/
They can sell you a complete kit that includes original IC's and resistors, fuses, thermal paste, a photo instruction guide, and email and phone support. There are lethal voltages inside the TV that have to be dealt with correctly, so if you do decide to try the repair on your own, make absolutely sure that you read over the instructions a number of times, and call them if there is any section you do not completely understand.
Mar 09, 2011 | Hitachi 53FDX20B 53" Rear Projection...
Hitachi 43uwx10b. How do i test resistors for convergence? i replaced i/c chips with upgraded stk394-160 and all resistors i was told rk42=3.3ohm/ rk46=1.8ohm/ rk50=2.7ohm/ rk54=1.5ohm/ rk58=3.9ohm/ and...
You have all the resistor are correct! Yes I can Tell you exactly what you need to know and How to Save settings after you adjust convergence, I have to pull out my manual on your hand unit Be right back. first you need to go to front of TV remove front bottom panel to where you can see the front of chassis on the board you replaced ICs there is a small blue contact button with TV on press and hold for 5secs Convergence Pattern should appear! You will need your hand unit to begin to adjust convergences.
Dec 17, 2009 | Hitachi 43UWX10B 43" Rear Projection...
How do i set convergance on my53uwx10B
you can go in through the back of the tv to set the focus you should be able to converge the tv from the remote.if not i would call a service tech and have them come and reset it for you.
Jan 21, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi projection tv
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in but stationary.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence or magic focus section
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
You can get a repair kit that includes all the parts from www.TvRepairKits.com.
They have put together a kit for the Hitachi TV sets.
The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself. Its a fairly easy fix on the Hitachi sets.
Dec 29, 2008 | Hitachi 61SDX01B 61" Rear Projection...
Hitachi 51S500 51 in.
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Using your original remote go-to the tv settings then goto the convergence section.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Aug 11, 2008 | Hitachi 51S500 51" Rear Projection...
Hitachi 43FDX01B Convergence Problems
Hitachi remote part # HL01643........I like the original remote
to do adjustments.................T.
Aug 06, 2008 | Hitachi 43FDX01B TV
Hitachi 43VWX10B Rear Projection Television - color adjustment problem
  • Screen looks 3D
Dec 25, 2007 | Hitachi 43FWX20B 43" Rear Projection...
Hitachi 50" 50GX30B PJTV
Solution:
Screen looks 3D
Oct 20, 2007 | Hitachi 50UX57B 50" Rear Projection...
Hitachi Big Screen TV 46 inch Problem
  • Screen looks 3D
Sep 06, 2007 | Hitachi 46BX01B 46" Rear Projection...
Hitachi 46BX01B 46" Rear Projection Television Logo
57 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
