Question about Kitchen Ranges
My Weber natural gas grill doesn't get as hot as it used to.
I have a weber grill that I have had for several years. It has been terrific. Over this winter the automatic starter stopped lighting the grill and the grill, once started, does not heat to nearly as high a heat as it always has. It's on a natural gas feed. Could the problem be the hose, as it seems the gas supply may be a little less than in the past, or what could be causing this? (The lighter is sparking, but the grill doesn't light, leading me to believe that the gas flow may be down).
    President:
  • 1,902 Answers
Check the gas valve. This will cause a decrease in gas pressure and would explain all your symptoms that you are having. Check it with a volt meter and your should read 120 volts
Posted on Apr 15, 2009
Weber Spirit 210 Won't Get Hot
Try following these steps to reset your FLD (flow limiting device)http://www.edyoungs.com/edyoungs/troubleshoot_tank.htm and then carefully follow the lighting instructions. If it works for you I think you will find this is a GREAT grill! Happy grilling and eating!
Apr 19, 2014 | Weber SPIRIT E-210 (NG)
I have Weber Genisi Silver model 8133 which has been hook up to a natural gas line. We have moved to a new location and can only use a propane tank hook up. Do I need a adaption for conversion to...
Unfortunately, you cannot use your Natural Gas Grill on Propane Gas. In addition, there is no conversion kit for Weber Grills. That's why they make two different gas models. Conversion of a grill becomes a safety issue. As each model Weber grill is tested and approved only for the specific gas type. Attempts to convert it voids that approval.
I'm sorry I didn't have better news. Thanks for choosing FixYa.
Jul 27, 2011 | Weber Genesis Silver B Grill
Need to convert our Q300 propane grill to natural gas. Do you sell conversion kits?
Unfortunately, Weber grills are not convertible from one gas type to another. There are no conversion kits available for your model or any Weber model gas grill.
To confirm this, go to the following link and on page 2 under Warnings, last paragraph, left hand column, you can confirm this, if you like.
http://help.weber.com/manuals/pdf_files_2011/Gas/Weber%20Q/Q300320_OwnersGuide_41060_021011.pdf
The only advantage to converting it to Natural Gas is not having to refill the grill tank. The downside, is that you will loose the heating capability that Propane has. It burns cleaner and hotter than Natural gas, in an outdoor environment.
Hope this helped you. Happy Grilling!!
Jul 13, 2011 | Weber Q300 Grill
Can a weber spirit e210 natural gas grill be converted to LP gas? I won the grill but don't have natural gas at my home
Weber sells conversion kits. Basically, you need a new regulator and manifold to accommodate LP instead of the existing regulator/manifold setup for natural gas. Unfortunately, Weber does not sell their parts online. Their parts phone # is: 877-731-8081
Apr 27, 2011 | Weber SPIRIT E-210 (NG)
How to change a weber natural gas grill to propane
According to Weber, "There is no conversion kit available to convert any Weber gas grill from one gas type to another. Any attempts to do it will void your warranty."
Sorry, but if it's any consolation, Propane Gas burns cleaner and hotter that Natural Gas in an outdoor environment. Which translates into faster preheating and hotter searing temperatures.
Hop e this helps and happy Grilling!!
Mar 19, 2011 | Weber SUMMIT S-620 Propane Grill
Where do i find propane to natural gas conversion kit for weber spirit e310 gril
Apparently, Weber does not make a conversion kit to convert the grill from propane or from natural gas to propane. According to the Owners Manual - "Liquid propane gas is not natural gas. The conversion or attempted use of natural gas in a liquid propane unit or liquid propane
gas in a natural gas unit is dangerous and will void your warranty." (From Page # 3 of the Owners Manual)
See below link.
http://www.weber.com/help/manuals/pdf_files/2008_updated/89525_030308_2008.pdf
Feb 23, 2011 | Weber Spirit? E-310 Propane Grill
Converting Weber from LP to Natural Gas
On the weber model you need to purchase the natural gas model. It will cost you alot more to buy all parts needed to convert. Weber doesnt want you to convert do to safety reasons. This is why they will only tell you you can't convert. Buy the right grill and save yourself a headache.
Jan 19, 2010 | Weber S-420 (NG)
Kit for converting weber genesis silver c to natural gas
Some grills do not have conversion kits, if your grill is labeled as dual fuel you can contact weber and get a kit for it.
Dec 31, 2009 | Weber Genesis Silver C Grill
Conversion kit for Weber Summit LP to Natural Gas
Hi, you can purchase your kit at amazon, click here and take a look: Amazon com weber grill conversion kit to natural gas. I hope this was helpful. Cheers
May 31, 2009 | Weber S-420 (NG)
I want to convert to natural gas.
The only thing you can do if Weber doesn't have a natural gas manifold for their grills , is to buy one that will fit. They use propane on outside grills because of the stability of the gas. Natural gas will blow out much easier.
Feb 25, 2009 | Weber Genesis Silver B Grill
Kitchen Ranges Logo
417 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
