Question about Kyocera KM-1505 Copier
Kyocera Mita 1635 Copier Printing Very Light Copies
I have kyocera Mita 1635 Copier which is printing Extremely light copies
even after i added new Genuine toner in the machine.
  • 1 more comment
  • Arthur Hoffmann
    Arthur Hoffmann May 11, 2010
    Several reasons for Light prints, Please answer a few questions:
    1. Is your copier also used as a printer hooked to a computer?
    2. If yes, are the prints Light?
    3. When if the Last time the PCU (Photo Conductor Unit) was changed? I would Like the Number of copies since the last time it was changed (eg: 30,000 ago, 90,000 ago)
    4. When was the last time the machine was serviced? the number of copies since last service (approx)
  • lYDIA MORRIS
    lYDIA MORRIS Apr 24, 2014
    REPLACE NEW DRUM WITH TRANSFER CHARGE UNIT
  • Anonymous Apr 09, 2018
    i have kyucera 1128 printer from computer result is normal but photocopier is very light can you help me pls
    New Friend:
  • 23 Answers
CLEAN THE DRUM UNIT AND CHARGER CHECK THE CONNECTER
Posted on Dec 09, 2016
How to fix drum kit in keyosera mita 1650
Posted on Aug 11, 2012
  • Kyocera Expert
  • 1,326 Answers
Is one side lighter then the other side of the copy? Meaning uneven copy darkness? If so, I believe the problem is that one or both sides of the drum cartridge and the developer are not connected correctly. The two parts need to be close togather to make a nice dark copy. This model has a very wierd drum unit and has a defect that one or both side of the drum unit locking tabs break and you get very light or blank copies. It's some what coastly to replace the whole unit... That would be a worse case.... If it is just on one side you might be able to push on the cover on the side that is light. If the copies come out better. One side is broken..I would fold up some paper and make a wedge to push the catridges closer. Good Luck
Posted on Apr 16, 2009
Produces Light Copies
Have you considered changing or checking the toner cartridge?
Does it display a low toner light?
I had a similar problem with a copy machine, where ALL the settings were correct and the toner was light.
The problem was the toner cartridge, the toner was caking because of the temperature. All it took was a good shake at the toner cartridge and it worked.
Also, check to see if the scan bed is messy, a good cleaning the the scanner bed should work as well.
Hope That helps!
Dec 12, 2007 | Kyocera Mita KM-3035 All-In-One Laser...
I have Kyocera 1635 copier. It's copies are dull and no contrast. I replaced new drum and blade. How I solve this problem.
clean the optics section,main charger and laser scanning unit assy particularly tha polygon mirror
Apr 26, 2011 | Kyocera KM-1505 Copier
Kyocera mita maintenance light is on and lines
check the rectangular **** glas and table for any white out or particles... clean thoroughly... make copies... clean again... make copies... if same issue... then replace drum... but in most cases its the optics... which I advised you to clean thats causing the issue... if the issue occurs when you print an internal report then its definitely drum... if reports are clear... there is something on the glass... or on the part above it... even a little bit of black toner or ink or whiteout anywhere out there can cause a line
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Oct 05, 2009 | Kyocera Mita KYOCERA/MITA AS-M4110 Copier
I have a Kyocera Mita 1635 Copier and it's giving blank copies
it may be the problem of moisture dont worry take brasso(used for shining the mitallic products) and put out photo conducting drum and clean the dum with brasso by using a soft cotton cloth ur problem must be solved
Sep 11, 2009 | Kyocera KM-1505 Copier
Kyocera mita km-1820 not printing clear copies
you have to check the duplex unit on the machine itself.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
May 01, 2009 | Kyocera Mita KM-1815 All-In-One Laser...
Cannot setup/connect to Kyocera CS-2050
go to kyocera mita america online. they have all the drivers. you need the KX driver
Jan 21, 2009 | Kyocera CS-2050 Black and White Copier
Problem in Kyocera Mita 2035 MFD
when you send a print job it delivere prints without pressing any button. just try it.
Apr 11, 2008 | Kyocera Mita Kyocera 2035 Earbud Hands...
Kyocera KM-1505 Copier Logo
1,762 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
