Question about Dell E173FP 17" Flat Panel LCD Monitor
Vertical lines on LCD monitor
I have a Dell 8300 Desktop PC with 17" LCD monitor. It has developed several vertical lines of noise approx 20mm wide on the screen. Running in safe mode creates lots of large square pixels with rainbow colours. I have tried replacing the video drivers but the computer tells me it's running properly. It has been taking ages to boot up recently but I put that down to a new AVG antivirus program. Any ideas?
I've swapped the monitor for a CRT and the problem's still there
Posted on Sep 16, 2007
    Genius:
  • 1,153 Answers
You have capacitor problem in power supply, if many lines then replace the bigest cap and find anymore that needs replacing. Its an AC filter problem.
Posted on Sep 14, 2007
My Samsung PS50A410 plasma TV has developed two vertical lines down the right side, one at 60 mm and the other at 350mm. Both are approx. 20mm wide with an indistinct picture behind.
vertical lines as apposed to horizontal indicate bad lowerr connections in the ribbon cables inside the TV at the bottom sometimes they can be fixed but most times your panel is failed
Feb 12, 2018 | Samsung Televison & Video
Screen flashes vertical lines when turned on
try a different monitor it sounds just like you think a failing monitor
Jan 15, 2018 | Mag Innovision LT776s 17" LCD Monitor
Vertical lines accross the screen
Vertical lines running down the screen is indicative of a data failure to the screen itself, which means either the screen is starting to fail or the data being transmitted through the data cable is being interferred with. Put a hand on either side of the monitor and give the monitor a light twist....does the line disappear? or do more lines appear...in either case, there is a problem where the data cable attaches to the lcd panel itself. You can try to change out cables, if that doesn't correct it, then the panel may have to be replaced. If you have the option of trying the computer on another monitor that would be the first step in seeing where the problem lies.
May 24, 2010 | Dell 1703FPs 17" TFT LCD Flat Panel...
Bluish green colour vertical line is coming in my
Your laptop screen has been faulty. you can checked it from service center.
Nov 13, 2009 | Dell E173FP 17" LCD Monitor
Dell E173FPf 17 vertical line problem
Yes, but the cost is not worth it. If you get it apart you will no doubt find a couple of bulging capacitors. Dell site has the disassembly instructions.
Oct 10, 2009 | Dell E173FPf 17" TFT LCD Flat Panel...
Vertical gray stripe on left edge, all pics and text gave a blur
any vertical or horizontal line (any color any size) showing stable on the screen that is the hardware damage at the LCD panel back board ( call panel driver board) . it repair complicate but easy to do change LCD panel (common parts). you need find a PC service dealer to do so.
Feb 07, 2009 | Dell E207WFP LCD Monitor
White Vertical Band on Screen
Hi...there,
It's seems you got a busted screen panel...
Dec 15, 2008 | Dell E171FPb 17" TFT LCD Flat Panel...
How to change the resolution of Acer AL1702Wb 17
On windows XP and earlier :
1. Right Click the desktop
2. Click properties
3. go to settings
4. the resolution slider is there. Try different resolutions untill it looks good.
Feb 21, 2008 | Computers & Internet
Dell lcd monitor with vertical lines
You have a filter problem, check power supply for bad capacitors.
Mar 24, 2007 | Dell E173FP 17" Flat Panel LCD Monitor
Computers & Internet Logo
283 people viewed this question
Alun Cox
