Question about Pioneer KEH-P2030 Cassette Player
PLUG MISSING AT BACK FOR WIRES SER.NO. FBTR429796ES
    Scholar:
  • 105 Answers
The plug for the unit can be ordered through pioneer . you can simply call 1-800-pioneer and give them the model number & place the order.
Posted on May 18, 2009
Engine starts back firing. When I check the plugs, the back cyl plug is black. Tells me fuel but should be missing instead of backfiring. Could the resistance from the plug be causing the plug wires to...
On you motorcycle the wire is part of the coil and there are two coils. Either you have a bad coil, a bad spark plug , or a bad spark plug cap. NGK makes some spark plug caps for about $5 each. Replace both of your spark plug caps and spark plugs. This should solve your problem.
Sep 13, 2010 | 2005 Suzuki Boulevard S83
How to plug in ignition wires on Golf Chico 2003 if plug is missing
YOU NEED TO BUY A NEW SPARK PLUG OR PLUGS F ONE IS MISSING.IF MORE THAN 1 MISSING YOU NEED A HAYNES REPAIR MANUAL.TO PUT PLUGS AND WIRES IN THE RIGHT FIRING POSITION.YOU CAN BUY REPAIR MANUALS AT AUTO ZONE OR ADVANCE AUTO PARTS.
Aug 02, 2010 | 1990 Volkswagen Golf
Stuttering 1999 f-150 Lightning
sounds like a bad coil or coils, you should have a scanner hooked to it and watch the data stream to see which cylinders are misfiring and then check the coils or if it has wires to each plug then check the plug wires . good luck, hope this helps.
Dec 19, 2009 | 1999 Ford F150 Regular Cab
Missing when taking off .ser.engine light on
you probably have a misfiring cylinder (fouled spark plug). just go to a parts store and scan your computer and it will tell you which one is misfiring.
Nov 11, 2009 | 2004 Ford F150
MOD: REX4635EW2 SER: MJ0922226 Type: D433-ELE-2406028-FM54 Won't turn on just buzzes when hit the start button. Have already checked plug in and braker box?
Remove the back panel from the control panel to access the start switch. If there are 4 wires on the start switch,replace the start switch.
Aug 18, 2009 | Roper Dryers
Engine compartment got wet now it is missing and
Let a fan blow in the engine compartment for a long while. More importantly, the ignition wiring and plugs need to be dried out. Trace spark plug wires back to their source.Use WD 40 or a wire dry spray (auto parts store). Unplug spark plug wires and spray. Unplug ignition module wires and spray. Unplug all electrical plugs and spray. Also use a air dryer to remove moisture, and to dry out wires.
Jul 18, 2009 | 2002 Toyota Tacoma
97 Lesabre misfire
change all plugs an wires if you still get the misfire on #3or#6 the coil pack is parabley bad
Jul 17, 2009 | 1997 Buick LeSabre
No harness plug that goes into the back of my stereo
go to ebay and search this exactly the way it is wrote. ISO Wiring Harness connector/adaptor for KENWOOD 12 Pin
Jan 12, 2009 | Durabrand Car CD Player and AM/FM...
Wiring harness in back missing a couple of wires
If you could tell how many pins per row on the connector at back then I might be able to help you out.
Sep 15, 2007 | Kenwood KDC-MP828 CD Player
Pioneer KEH-P2030 Cassette Player Logo
91 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
