Home | Epson | Stylus Color 740 InkJet Printer | Eson 740 will no lon...
Epson Stylus Color 740 InkJet Printer
Problem for Epson Stylus Color 740 InkJet Printer
Eson 740 will no longer print black ink
By jake_redondo on Apr 15, 2009
The printer has worked great for 6 years and now it stopped printing black. The color ink works fine. The blinking light to indicate "out of ink" never goes on. I have changed the black cartridge "3" times with no success. Once I got it to print black when I changed the printer features to "Resolution: 1440 x 720 DPI Highest Quality." However, after 3 pages, the black began to fade again.
About drivers: When I ran this on OS 9, there were drivers. But on OS 10.3.9, you use the System Preferences and simply chose Epson 740 from the menu. So I am not sure if the driver is the problem or even how to re-install the driver. Any help would be appreciated. Thx.
Best Solution
posted on Apr 20, 2009
Very Helpful)
Liquid_Metal
Rank: Apprentice
Rating: 98%, 4 votes
Thank you Scott Ellin for your tip on connecting the Epson printer to another computer, that helped. I connected it to my OS 9 Mac and prompted the utility to clean the heads etc. Then I tried printing and both the black ink & the color ink worked. Then I connected back to the OS 10 Mac and it continued to work just fine. I'm not sure why this procedure worked, but it did. Thanks.
Comments:
Apr 20, 2009
- Thank you Scott Ellin for your tip on connecting the Epson printer to another computer, that helped. I connected it to my OS 9 Mac and prompted the utility to clean the heads etc. Then I tried printing and both the black ink & the color ink worked. Then I connected back to the OS 10 Mac and it continued to work just fine. I'm not sure why this procedure worked, but it did. Thanks.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Apr 15, 2009
Very Helpful)
Scott Ellin
Rank: Wiz
Rating: 83%, 321 votes
May I know if the printer is working on any computer.
It assume to be the Black Ink Head of the Printer is decayed. I mean to say the Surface where the Ink cartridge contacted to Printer, the film also need to be replaced. Plz check it to nearby service centre.
Comments:
Apr 27, 2009
- We are here to diagnose root cause of the problem and if we have some experience related to it we have to share with the user and the community. Thats all I wish to say.
Thanks for your comments Liquid_Metal
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for Epson Stylus Color 740 InkJet
Questions and Unsolved Problems for Epson Stylus Color 740 InkJet
Do you recommend Epson Stylus Color 740 InkJet Printer?
Answer
Answer
my epson 740 color printer does not work after several years
Answer
keep getting message jobs stopped and i don't know what to do
Answer
what should be the power supply if it happens that the fuse is ok?cause the power supply i'm using... (More)
Answer
Epson Stylus 740 - Black will not print. Cleaned several times, installed a new cartridge.
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Epson Stylus Color 740 InkJet...:
Top Printer Experts
Rank: Guru Guru
Solutions: 437
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
