Specks of blue on my printing.
I am getting specks of blue toner on my print outs. I am asuming I have to clean something but what? It is an Oki C5600 printer.
  • 95 Answers
Replace the cyan drum unit. If the specks are always in the same line there is small ding in the drum. If the specks are random then the cleaning blade inside the drum unit is bad. When ever the defect is just one color it usually is that color drum unit.
Posted on Apr 15, 2009
SOURCE:
I have a Lexmark C522 Color Laser printer, all cartridges are showing as ok, no error messages but printed pages have specks of magenta toner on them
It sounds as though you have a leaking toner cartridge. If you aren't using Lexmark brand toner, that is VERY likely.. nobody seems to be able to make a good compatible cartridge. Test by replacing it.
Feb 22, 2014 | Lexmark C522n Laser Printer
Brother HL 5140 has black specks on the page
There's probably something wrong with the drum unit. I would check the manual on how to change the drum unit. Good luck!
Dec 30, 2011 | Brother HL 5140 Laser Printer
I am getting white specks on all four colors on my phaser 8500 and some black smudges. I just did a smudge clean and it helped, but it didn't clear it.
Hello.
Try a laser printer roller cleaner (paper sheets), like PathKleen or Perfect Data. You may need to run sheets through several times before the cleaning is complete. Do not use a sheet more than once.
Hope this helps.
Feb 03, 2011 | Xerox Phaser 8500/SN Color Laser Printer
Strange clicking noise OKI C5600
it is not the toner it is the drum. just replace the drum and it will be fine. you may of noticed your printer has been printing a little streaky. i have had this problem with my c5600 and after i replaced the k drum (the noisy drum) it was fixed intill 4 months later when the blasted thing broke again
Jun 02, 2010 | OKI C5400 Laser Printer
K drum life keeps coming up,
The best is to replace the black drum, you can fix it but you have to take apart, clean out the waste toner, replace the fuse, and cleaning blade and reassemble. The fuse will reset the printer to know it's a new drum.
Dec 23, 2009 | OKI C5200n Laser Printer
OKI C5600 error code 411 says toner cartridge is empty (isn't)
Kedves Mindnyájatok!
AZ alábbi hibaüzenet jelenik MEG AZ OKI C5600dn kijelz?jén Minden szín? tonernél. Sot MEG AZ eredeti sárga-NAL van.
Chip cserével lehet orvosolni SEM a problémát. Eddigi javaslat volt: 4 db toner éS alaplap csere. Ennyiért pia con színes nyomtatót is lehetne mar venni. Tudnak segíteni? Van Valami praktikus javaslat a hibám orvoslására?
További Szép estét kívánok!
Lacika
Oct 26, 2009 | OKI C5650n LED Laser Printer
HP 4650dn Printing Small Specks of Toner
They could ALSO be on the fuser roller... Check that first.
Sep 04, 2009 | HP LaserJet 4600dn Color Printer
Toner warning
THE TONER CONTAIN NEED TO BE WASHED OUT WITH SPECAL CHEMICALS, PRINTS NEED MAINTNANCE, OVER FLOW CONTAINER MAY HAVE TO BE EMPTYED ALL SO, CORRORNA WIRES NEED TO BE CLEANED
DRUM MAY MAY NEED SERVICE ALSO
ROD
Feb 03, 2009 | OKI C5200n Laser Printer
Dark pages
Possibly cleaning blade fault on on K unit.
May 06, 2008 | Ricoh Aficio AP3800C Laser Printer
Small lines or specks on the right side of every page
Did you try cleaning the lense? You'll have to pull all the toners and open the little door below and wipe with a clean lint free cloth in ONE direction.
Nov 10, 2007 | Lexmark C510 Laser Printer
165 people viewed this question
k24674
Marvin
Marvin
