Question about Dymo LetraTag QX50 Thermal Label Printer
Letra tag qx 50
When I print, the writing is all faded and blotchy. I tried cleaning the parts, but it is still blotchy.
I had the same problem, thinking it needed a new tape, but it was actually just the batteries. I forgot it is not ink based - it is thermal based. It needs lots of power to burn the letters onto the thermal tape, so even though the tape was moving and it sounded like it was working, the thermal head wasn't getting enough power. I changed the six batteries and it is working fine.
hope this helps, even though it's almost a month since you posted it.
Frank A
Posted on Oct 29, 2007
I want to than Frank who posted the thing about batteries. My Dymo Letratag (sorry I don't have the model in front of me) was doing the same thing. When the guy at Office Max said it might be the batteries, I thought he was nuts. But I saw Frank's reply, changed to some good batteries and yes, it's printing clearly again. So try that first. That didn't make sense until I read Frank's message.
Posted on Nov 14, 2007
SOURCE:
Can dymo letratag ink be replaced? seems i ran out of ink
you can reink it or replace it
looks like this in there easy to do an messy need gloves
they sell everywhere
http://static.labelvalue.com/images/productimages/183/large/inkroller.jpg
Jan 04, 2015 | Dymo Office Equipment & Supplies
Letra tag QX50 Faint printing. I replaced the batteries to no avail. Are ther other causes?
You need to check whether is ther any printer ribbon for this device, If any try replacing it and then it will print better.
Regards
Rudra.
Oct 11, 2010 | Dymo LetraTag QX50 Thermal Label Printer
I am getting error 1 on my dymo letra tag qx 50
Error 1 indicates a tape jam or low battery. To resolve, try removing the cassette and clearing the tape or replacing the battery.
Don't close the back - and press print.... and pull on the tape to help it along.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 18, 2010 | Dymo LetraTAG Thermal Label Printer
The print on my dymo letra tag is very faint, how to fix?
The first thing you should do is check the batteries. Because the LetraTag requires heat to generate thermal printing, not ink, the batteries need to be well charged. Also, there is a small brush fitted to the inside of the lid of the cartridge cover, that is for cleaning the print head and roller. Remove it, dampen the felt tip with a little rubbing alcohol, and gently clean the print head and roller. You should find this will improve the print quality 100%
Oct 28, 2009 | Dymo LetraTag QX50 Thermal Label Printer
Dymo Letra Tag
Hi - You can download the manual by clicking the link underlined in blue below:
letra tag QX50
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 17, 2008 | Dymo LetraTag QX50 Thermal Label Printer
Dymo Letra Tag
I have to assume you are pressing the print button. That being the case, either your batteries are weak or the tape is empty or jammed.
Aug 28, 2008 | Dymo LetraTAG Thermal Label Printer
Dymo Letra Tag
It runs on heat transfer. It probably needs new batterys. If youve been on a labeling spree you've most likel killed it.
Sep 24, 2007 | Dymo LetraTag 2000 Printer
Error 1
The user guide lists all the error codes and possible solutions. http://download.dymo.com/media/UserGuides/QX50US.pdf Error 1 indicates a tape jam or low battery. To resolve, try removing the cassette and clearing the tape or replacing the battery.
Sep 20, 2006 | Dymo LetraTag QX50 Thermal Label Printer
Dymo LetraTag QX50 Thermal Label Printer Logo
159 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Marvin
Marvin
Steve Allison
Steve Allison
Joaquim Martins
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
