Question about ASUS Eee PC 900 16G Notebook
I deleted my audio driver and my sound
One day my computer was slow so i went into my programs and deleted the things i didnt need awhile later i couldnt hear any sounds that played..also when i turn on my laptop it says i dont have AUDIO DRIVER..i have a Eee pc series...model 900...i tried everything,,PLEASE HELP ME..i dont know what to do!!!
  • 447 Answers
You should be able to use the AC97 HD codecs available from Realtek with your sound device.
Post your results under this thread, especially if you continue to have problems after installing the driver.
Posted on Apr 15, 2009
    President:
  • 1,865 Answers
I was trying to remove a few unrequired programs from my computer so i went to the add and remove programs in the control panel...i deleted something by mistake and now the sound in my computer is not...
Yes, it is the problem with the Audio Driver. Click here to go to the website which will allow you to download Audio Drivers for free. Download them and install to have your speakers working again. Don't forget to rate the solution.
Jan 05, 2011 | HP Pavilion dv1000 Notebook
No sound on my gateway laptop i deleted it some how totally
if your computer came with a motherboard disk the sound drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or
audio you will find 3 drop down lists make the necessary adjustments there or
control panel,administrive tools,computer management,device manager,sound video and game controllers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 12, 2010 | Gateway MX6448 Notebook
Deleted Audio Program
Use the drivers CD which must have come along with the Comp.
you will find the audio drivers in that
if you can pls post back a message and i will try to see what else we can do .
Jun 30, 2009 | HP vs15 15"LCD Flat Panel Monitor
Computer running very slow
internet properties delete all temporary files, delete cookies, delete history, set history to a low number. on start menu go to accessories run disk clean up, run disk defragment this will take awhile this action will take duplicate files and put them in one location. you will not lose anything. you also can go to my documents and clear out old items that you dont use this will speed you up some, also in your control panal file add/remove programs you may want to look for files that were downloaded from the internet that you decided you didnt want or that you dont need or use, and delete these,this action wiil free up used disk space that will also speed up your pc just keep in mind do not delete anything that runs another program that you do use because this will cause that program not to function right, any of this information will help speed your internet and your pc all together.
Oct 23, 2008 | Computers & Internet
Failure of realtek audio driver installation
I had the same problem while installing a GeForce 7050M-M motherboard w/AMD quad core processor. I kept getting the message "install Realtek HD Audio driver failure!!" message. After many hours of futility, and reading possible solutions on the internet, I got it working this way: First, go into your cmos setup and disable your onboard audio. Then after you boot up, go into 'control panel' and then 'add/remove programs' and remove any program associated with high definition audio. The Realtek programs that I had tried to install were in mine, so I deleted them. Then I clicked on 'start' and then 'search', and put this in the search window: 'hdaud' for high definition audio. Several files came up, and I deleted them, which put them all in the recycling bin. I didn't empty the bin, in case I screwed up something and had to restore the files later. I then rebooted, and being probably overcautious, let the computer come up and then went back into 'add/delete programs' to make sure there were no HD audio programs in there, and then double checked for any files by going back into 'search' and searching for 'hdaud' files like before. A file somehow had appeared there associated with Realtek, so I deleted it. Then I rebooted, and at reboot went into cmos setup and enabled my onboard audio. When the computer came up, the 'found new hardware' message popped up. When you see this DO NOT let the computer look for the driver. Hit 'cancel', and load your Realtek audio drivers from your setup disc or from whatever location you have them in. You may see the additional message about the driver not loading and your sound not working right, but ignore it, it's because you clicked on 'cancel'. Just let it finish it's install from your setup disc. When mine finished successfully for the first time now, and it prompted me to reboot because of the new drivers just installed, I actually got the 'shutdown' sound out my speakers-the first peep I heard out of them since I started this adventure early yesterday. When the computer came up, lo and behold I had sound. I was about ready to give up and go out and buy a sound card, but stubborness prevailed. So in short review:
1. Disable your onboard audio in CMOS
2. Go into 'add/remove programs' and delete any and all HD audio programs
3. Go into 'search' and type in 'hdaud' and delete those files that come up.
4. Reboot and double check 2 and 3 above.
5. Reboot and go into CMOS and enable your onboard audio.
6. Load your audio drivers from your setup disc-DO NOT LET THE COMPUTER LOOK FOR A DRIVER THRU THE 'FOUND NEW HARDWARE' PROMPT-PRESS CANCEL.
7. Reboot and hopefully, enjoy the sound.
Oct 07, 2008 | Microsoft Windows XP Professional With...
No audio on dell inspiron 1000
restore your computer 2 days later
Sep 19, 2008 | Dell Inspiron 1000 Notebook
Sound
Did you have sound before?
If yes then follow this for xp:
Start/control panel/Sounds, Speech, & Audio Devices/Sound & Audio Devices. Is page greyed out? If yes then most likely its your sound card or on board sound, or your missing drivers.
If not greyed out go to "Sounds" tab, click on any "Program events" sound under Windows then click little black arrow next to browse on bottom right . Sound? If the arrow is greyed out then its the same; audio hardware device or audio driver.
If there is still no sound click on "Hardware" tab and first Sound,video and game controller then "properties". This will tell you under "Device status" if this device is working properly. Do this for each Sound, video ect.... selection in the list. I have found there are usually 6 listings. If not then you are most likely missing a sound driver.
Jun 21, 2008 | E-Machines eMachines Desktop PC
No audio
Open your computer then boot to safe mode(press F8), go to add/remove programs then uninstall the toshiba audio driver, also check on the Device Manager if it is still there then uninstall it. Reboot the computer to normal mode then install the toshiba audio driver again. Be sure to have the correct driver downloaded.
Jun 18, 2008 | Toshiba (4CH-VOUT) Sound Card
Soundmax
I don't know if you manually erase those drivers, but I recommend you reinstall the drivers with the setup option, then uninstall them, again reinstall them ans see if work, or depending the OS if is Xp or Vista, ?
Nov 06, 2007 | Audio Players & Recorders
ASUS Eee PC 900 16G Notebook Logo
334 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
