Question about Panasonic SC-PT660 Theater System
Can I change the dvd player on a Panasonic SA-HT545
I have a Panasonic SA-HT545 and would like to purchase a new dvd player which upscales. Is there a Panasonic dvd player which will allow me to connect my existing speakers to it? The speakers on this above system work fine and would rather not pay out for a new home cinema centre.
SOURCE: PANASONIC Home cinema SC-DT100 - Flat cable connection
Hi, when you say it doesn't work, will it just not play/read the disc? Mine has to be "initialized" every time or it shows "No Disc". To initialize I turn the unit on then press and hold "Stop" on the unit and the "10-" button on the remote, then it works fine.
Posted on Oct 09, 2007
  • 4234 Answers
SOURCE: F61 on SA-HT545
I can not find a listing for model SA-HT545. All I can suggest is that there should be a large black IC attached to a heatsink that should be marked STKxxx or something similar. Post that marking here and I'll confirm that it is the correct one to replace. That part is the output amplifier pac and is the most common failure part that generates the symptom you describe.
Keep me posted.
Dan
Posted on May 30, 2008
redhead7377
  • 51 Answers
SOURCE: My receiver for the Panasonic-SA-HT800V is toast
ebay? the speakers can only be used with this model..unless you strip the speaker wire...
Posted on Jul 25, 2008
SOURCE: No sound through the Panasonic cinema surround sound on TV
Had a similar problem mate. I solved it by connecting the tv to the PT460 system with a scart lead. You then have to have the AV channel selected on the PT460 system to listen to the tv. You will always have to have the AV channel on the PT460 selected to listen to any sound transmitted through the tv - be it playstation/xbox or any other device that you may connect in the future with HDMI leads or otherwise. Hope this helps
Posted on Jan 04, 2009
  • 447 Answers
SOURCE: Replacing Panasonic SA-HT500 with Newer Model that has HDMI Input
ANY amp will be ok, as long as the wattage of your new amp does not exceed the wattage of your speakers. Otherwise you could overdrive your speakers and damage them. First clue, if you turn up the volume and the speakers start to shut off and on you are pushing too much power to them.
Posted on Feb 03, 2010
What is the region unlock code for a Panasonic dvd SA BTT270 Theater system
Panasonic DVD players these days I have found do not use codes anymore. Instead you have to get a device that will change the regional code. Some dealers will also do this, for a charge obviously!
I bought one for my Panasonic DVD players off E-bay, they are not expensive, if it will work your model. Check that it will change your model before purchasing.
Nov 23, 2016 | Panasonic Audio Players & Recorders
Can I change Panasonic sa-pt860 DVD player to bluray player?any bluray player can fit into this home theatre?
Most BluRay players will work with home theaters. HDMI cables can be adapted to VGI inputs if necessary.
Dec 09, 2014 | Panasonic Televison & Video
I have a SA-HT545 DVD home theater sound system and it shows F61 error. How can I fix this?
The F61 is the Panasonic code for protect mode. See the link below for an explanation of protect. In your case, there is an output amp pac that has failed. The cost for this ranges from $75-$100 for the part. Please update this if you are interested in repairing this unit and I'll get the exact parts required.
Dan
Link: http://www.fixya.com/support/r5390728-protector_means
Nov 01, 2010 | Panasonic Home Theater System System
NEED TO HAVE REGION 2 ON MY SONY DVD PLAYER DVP-FX810 THAT I BOUGHT IN THE USA ? REGION 1 . THANK YOU .
Sorry, it's not possible. The DVP-FX810 is one of many Sony players where the region coding cannot be hacked without making internal hardware changes. To do so is not cost effective when you can buy perfectly good multi region (or at least hackable players) brand new for £30 including a few Sony models which can be hacked (e.g the excellent DVP5980 with progressive scan, USB input, DivX and HDMI upscaling, still widely available at clearance outlets for under £30).
If you want hackable players avoid Sony and Panasonic unless you have found a model specific hack prior to purchase as many of them have the same limitation.
Sorry there's no fix on this occasion, but I hope that you've found my reply to be of some use. All I ask in return is that you rate my answer.
Nov 01, 2009 | Sony DVP-FX810 Portable DVD Player
My player seems not able to upscale the signal from my antennea and DVDs
Upscaling will only occur when playing DVDs. You have to use an HDMI connection from the DVD player to the tv. For upscaling of DVD's you will also have to setup the upscaling resolution in the DVD player's setup menu. Be sure to set the resolution to one that your tv will support.
If your tv does not have a HDMI input, then you will not be able to use the upscaling feature.
Upscaling will not occur on antenna signals. This is not possible because the hardware (inside DVD player) is only meant to upscale DVD video.
Again, to upscale DVDs ONLY, you will have to have an HDMI cable going from DVD player to TV, set up your upscaling options on your DVD setup menu and have a TV that has a HDMI input and is capable of recieving the upscaled resolution you have set your DVD player to.
If you have any further question regarding this, let me know!
Oct 07, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
Can't play dvd burned with nero
you need to author the dvd before burning it
May 20, 2009 | Panasonic Televison & Video
Panasonic SA-PT750 - changing Region restriction
The system region control is a function of the software on the DVD player. I don't believe there is a way to change the region settings on most DVD players. You can however convert your DVDs with software available online. One program is called "DVD Region & Css Free" and is available for a small price. That is perhaps one way you could approach your problem. Otherwise look for a player that will play discs from other regions.
Oct 07, 2008 | Audio Players & Recorders
F61 on SA-HT545
Keep me posted.
Dan
May 25, 2008 | Panasonic Home Theater System System
Surrond sound SA-HT545
found online manual and troubleshooting
May 25, 2008 | Panasonic Televison & Video
Panasonic sa ht545 home theater
I need to no how i get a card so that the wireless speakers work as there wasn't one in the box when we got the system out. HELP!
Feb 18, 2008 | Audio Players & Recorders
Panasonic SC-PT660 Theater System Logo
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
