Question about Brother IntelliFax-2920 Plain Paper Fax, Copier and Phone , 33.6 Kbps Modem Laser
Changed the toner but it still says "unable to print"
I have a FAX-2920. Just changed the toner, followed all the instructions but it says unable to print and advises to see the troubleshooting in the manual - which I did. This says to switch on and off and then if it still doesn't work, to leave it for a few minutes. Tried all of that but nothing works!
  • 23 Answers
Put the old tone back in machine. Does the problem still exist? If not try another new toner.
If it does then you may have a mechnical failure which will require a service center.
Posted on Apr 16, 2009
Brother 2920 display unable to print pleas help me
hi
check the cable connection
check if you have toner in
check the drivers
Jan 15, 2011 | Brother IntelliFax-2920 Plain Paper Fax,...
How to replace in k
Your machine is a laser type fac (not inkjet). It does,t use ink, but toner. To learn how to replace the toner cartridge you should read the User's Guide.
You can download it from here: Brother FAX-2920 User's Guide
manual.
Look for section "Troubleshooting and routine
maintenance" / Replace the Toner Cartridge / How to replace the toner cartridge and Replacing the Drum Unit (pags. 112 and following of the User's Guide).
Oct 02, 2010 | Brother FAX-2920 Plain Paper Laser
Brother Intellifax 2920 Error "Unable to Print"
Check the flux capacitor, those usually go out on brother faxes.
I just replaced mine last week, same problem.
Jan 05, 2010 | Brother IntelliFax-2920 Fax
I changed the toner and now I get a broad black line down the side of the paper when a fax prints.
Clean the charge corona wire on your drum unit. It should be a green plastic handled device located on top of your drum unit. Move it forward and backward ~ 5 or 6 times, then reinstall drum unit.
Nov 10, 2009 | Brother IntelliFax-2920 Fax
Toner for fax machine 2920
If your machine is a Brother Intellifax 2920, it does take a TN-350 toner cartridge. Maybe you were wanting to replace the Drum Unit instead, DR-350. I'll bet this info is useful, yes?
Jul 03, 2009 | Brother FAX-2920 Plain Paper Laser
Changed the Toner in Fax Machine and Still reads "Low Toner"
First, the obvious
  • Did you gently rock the toner cartridge from side to side to evenly distribute the toner?
  • Did the cartridge "click" into place?(did lock lever pop up when it was inserted)
  • Did you replace the protective cover securely?
Another thing to check is cleaning the Corona wire inside by sliding the Blue tab back and forth several times. Important to return the Blue tab back to the "Home" position afterward.
If you've done ALL of these steps correctly, and the low toner message is still there, a service call is in order. Best of luck with your machine!
May 06, 2009 | Brother IntelliFax-2920 Fax
Brother Intelifax 2920
this sounds trivial but when you changed the toner did you follow the instructions that were included in the box?
Brother machines have to be doen a certain way or the page count on the cartrigde will not reset and will still say low/empty etc
Hope this helps
Pete
Pete@wedotoners.com
Dec 06, 2007 | Office Equipment & Supplies
Brother IntelliFax-2920 Plain Paper Fax, Copier and Phone , 33.6 Kbps Modem Laser Logo
404 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
