Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
Cleaning solution drains out !!
I bought my pro-heat about 7 years ago when my house was carpeted, now I have hard floors. Anyhow my machine has been sitting for a long time but I got it out recently to use at my grandmothers house, I went and bought this $25 bottle of cleaner (from a chemical supply store) to get out her cat?s **** odor , it said it could be used in any machine. Well I filled everything up and started it up and the cleaner just drained right out of the little bottle in the machine! Could there be a seal or something missing? I have looked- and everything seems there- but the lid to the bottle is a little hard to get screwed on tight. Thanks in advance for any advice!
  • pizzaguy08 Mar 03, 2008
    the soap bottle run out in two sqeeze.I filled bottle up and checked for leaks there was no leak. Also dont think the water is not being used. I blow though all the lines and they were clear. need help!
    President:
  • 1,673 Answers
There is a plunger and a seal on the bottom of the soap dispenser. It may be that the plunger is stuck. You may have to replace it part number SmartMix® Cap Assembly 2101795
Posted on Jan 08, 2008
Can the suction be adjusted manually as it is too powerful on my carpets
returns are up to the place of purchase. we can not answer that for them. contact the place of purchase.
the suction can not be adjusted.
Jun 25, 2016 | Dyson DC40 Multi-floor Vacuum DC40
How do i alter the dyson dc04 to use on hard floors
Hi there, it's Jack at Dyson.
If your DC04 has a brush control on the cleaner head, you'll need to set this to 'On' for carpets, and 'Off' for hard floors. You can find out how to do this on our Support site:
http://www.dyson.co.uk/support/dc04/dc04-brush-control/my-machine-is-not-working/i-can-see-something-wrong-visual/i-can-see-something-wrong-visual/my-brushbar-is-not-rotating2/does-the-brushbar-rotate-with-the-power-on
If your machine does not include the brush control, it will only be suitable for vacuuming carpeted surfaces and we'd advise against using it on hard floors in upright mode. However, you can use the hose and wand to vacuum hard floors and we have several suitable hard floor tools available which may help.
I hope this helps - if you'd like further advice you can reach our freephone Helpline on 0800 298 0298. Just to let you know, our Helpline is available from 7am-10pm, 7 days a week.
Best wishes,
JackDyson Online Customer Supporthttp://www.dyson.co.uk
Mar 06, 2013 | Dyson DC04 HEPA Bagless Upright Cyclonic...
I have just installed travertine floors in my entire house. What's the best vacuume for my floors?
If you have mostly hard floors you can't go wrong with a Miele canister vacuum. They have many models out. I would suggest one with a 14" horse hair floor brush. they are german made and last for years. Don't buy a Dyson they are very harsh on hard floors and your carpet.
May 06, 2011 | Vacuums
Can you advise which setting should be used on different floors, ie hard floors and carpets, theres 2 different settings and I don't know which setting should be used on the different floors
Turn the machine on and look at the bottom. Turn to the two settings. The setting that stops the platten wheel from moving is for hard wood floors. If you cant tell, then setting 1 is most likely for carpets and 2 is for hard wood floors. Your machine is primarily a carpet vacuum cleaner, so 1 should be for carpets.
Feb 03, 2011 | Hoover Vacuums
Proheat2x carpet cleaner
Sometimes we will get a lemon even in small equiptment but I would encourge you to not allow call again but email tech. support too see if you get the right person that will see you thru to the end.
Dec 01, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
I have a Lux Floor Pro Heavy Duty carpet cleaner. Whis attachments (scrubbers) do I attach to the bottom to wash a non-plush carpet. I have three attachments that have hard bristles and three that have...
NEVER USE THE HARD BRUSHES ON CARPET ! You can burn up your motor, break the drive belt,or strip the drive gears The black bristle brushes are for all carpet types.
The hard bristle brushes are made for hardwood and other smooth surfaces.
Oct 24, 2009 | Electrolux UltraLux 2000 Bagged Canister...
My Bissell Pro Heat 2X will not release water or
its probably a solenoid that controls the flow to the floor, take it to a bissell repair center, because its not an easy fix.
Jul 02, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Carpets soaking wet
turn dial in front on the water tank to floor not tools and thats should do it...go to bissell.com to read and print manual so you can double check everything
Feb 10, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Pro heat 2x no water coming out carpet part / hand tool either
In case any of you are still trying to figure this out... I took mine into a repair shop and had the pump replaced for $66. The repairman had 6 other machines in his shop when I bought mine in. He said the pump goes the minute it runs dry, so if you get yours fixed, or know anyone else with one, make sure to KEEP THE CLEAN TANK FILLED AT ALL TIMES!
Nov 27, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
61 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
