Question about QDI Group QDI SynactiX 2EP Motherboard
No sound When i look at icon shortcut to sounds no audio sound available. When I look at Volume Control message is no active devices available. I have identified my mother board as Legend QDI Synactix 2EP. Please can you help
  • 57 Answers
You got to install the sound drivers.
Posted on Apr 15, 2009
Have Koss hd-50 (hand me down) would like a diagram, have no sound, running winxp on dell xperion 8400, says "no active mixer devices"
i will go through the process of setting up sound on your computer
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
if you need more help with this post a reply
hope this helps you
Sep 21, 2011 | Koss HD 50 Computer Speakers
Volume speaker icon not show
The volume speaker Icon wont show usually because you have no sound drivers installed. To confirm this,
1) Go to your control panel and double click on "Sounds and Audio devices"
2) The window that appears sholu show the device volume slider active - which means the driver works fine and is installed. If this is so, click on "place volume icon in task bar".
If not, you need to install the sound drivers for your device.
(Don't forget to rate my solution)
Dec 02, 2010 | Audio Players & Recorders
No active mixer, volume control i did the services.msc thing, still no audio
Your question is not cleared. You indicated two opposite problems. One no sound and other volume control if not available. Lets try the both. First relating to volume control. Click on START BUTTON - CONTROL PANEL - here double click on SOUND AND AUDIO DEVICE - now on the VOLUME TAB check mark on "place volume icone in the taskbar, click APPLY, OK.
NOW, solution #2 if your sound card is not properly installed or some of the files have gone corrupt. Right click on MY COMPUTER icon click on property, locate and click on HARDWARE click on DEVICE MANAGER here locate Sound, video and game controllers if there is any YELLOW COLORED MARK on it, it indicates that your sound card is not working or not installed properly. In this window you see monitor shaped Icon, which if also used for refreshing. First click on plus (+) sign and highlight sound card then refresh it by clicking icon stated above. If the problem remains as it is, then uninstall from the same window, and refresh it and window will install automatically. restart the computer once. REMEMBER TO VOTE ME.
Sep 22, 2010 | Computers & Internet
No sound, get active mixer devices message and code 28
First verify you see a small sound icon in the Systray . If this icon is missing follow the below section
1. Open the Control panel
2. Open the "Sounds and Audio Devices" icon.
3. Verify the "Place volume icon in the taskbar" checkbox is checked. If this option is not available or is grayed out, skip to the next section of this document.
4. If you were able to check this box, click ok and close out of this window and the Control Panel.
5. Double-click the sound icon in the Systray and verify that all the sound volumes are mid-way or higher.
Check Windows services. Right Click My Computer and Manage. Choose Services and Application
Sep 10, 2010 | Microsoft Windows XP Professional
Can not show volume icon on my pc
XP view
Control Panel
->sound,speech, and Audio Devices
->Sound and Audio Devices
->sound And Audio Properties
->check "Place volume icon in the taskbar" box
Classic View
Control Panel -> Sound and Audio Devices->sound And Audio Properties->check "Place volume icon in the taskbar" box
Hope it helps.
Aug 14, 2010 | Microsoft Windows XP Professional SP2
I accidentally delete or lost the Speaker icon next to the clock at the bottom of my computer and cannot get any sounds from the computer whatsoever.please assist. Thank you.
You will want to go to control panel and go to sounds, if you go through the tabs (probably the first) there will be a check box that says 'show sound icon on system tray' enable this and whala.
Jun 25, 2010 | Computers & Internet
This is the active mixer error message... --------------------------- Volume Control --------------------------- There are no active mixer devices available. To install mixer devices, go to Control Panel,...
NO active mixer is one of the volume control, your sound card or your audio port is not installed. try to install again your motherboard installer and locate for the audio of it of for the soundcard. Then after that restart and when the sounds come then you successfully installed it
Jan 10, 2010 | Computers & Internet
Hi, I have an Acer D150 and I have no "sound icon" or audio at the moment. I think I deleted the audi/sound/icon by mistake a while ago.
If you are referring to the sound icon that's in the system tray (down by the clock), you may go to the Control Panel and create a shortcut.
1. Start > Control Panel > Sounds and Audio devices
2. Put a check on the box of "Place volume icon in the taskbar" under the volume tab.
If you are referring into another sound icon, please let me know. Have a great day!
Sep 13, 2009 | Gigabyte Computers & Internet
Audio problem
You either have the wrong driver installed or a conflicting driver is present. Go to control panel->system->device manager-> look for the yellow exclamation point, double click on it and follow those instructions. If that does not work. Right click on the device, REMOVE, then reboot and let it refind it.
Jul 11, 2009 | Compaq Audio card Sound Card
QDI Group QDI SynactiX 2EP Motherboard Logo
146 people viewed this question
Top QDI Group Computers & Internet Experts
Tom Chichester
Bill Boyd
Are you a QDI Group Computer and Internet Expert? Answer questions, earn points and help others
