Graphics Publishing and Multimedia Software
Problem for Adobe Graphics Publishing and Multimedia Software
Generic problem for all Adobe Graphics Publishing and...
How do i creat action (making 4 up ) in
By ashok_78673 on Apr 15, 2009
how do i creat action (making 4 up ) in photoshop7.0?
How can i creat an action in photoshop7.0?
How can i remove bacgroung of photo in the place of head area (specialy hair cutting)?
Solution #1
posted on Apr 17, 2009
Not Rated)
dotball
Rank: Wiz
Rating: 83%, 39 votes
There's a few things you ask here and as with all Photoshop processes there are a number of methods to get to your goals.
First up I'll tackle the Erase Background. What you've picked is something quite difficult - removing background around hair. I think maybe the best way for this might be to use the "Magic Eraser" tool, which you'll find by clicking on the Eraser (Rubber, where ever your from) and holding it down where you'll see 3 options (Eraser, Background Eraser, and Magic Eraser). Once you've selected the tool, up the top of the screen there are tool options where you can select the "Tolerance" which is the gammut of colour the picker will select, and select "Contiguous" for selective delete, otherwise it'll delete all that similar colour. If you choose to use the "Background Eraser" you use the same options but you choose a background colour and foreground colour, one is deleted and the other is erased.
the other method for deleting backgrounds is to use the "Magic Wand" and use the same set of Tool Options to set sensitivity with the 'Tolerance' and then once you have selected the area to delete, before you hit the delete button, set a Feather to the selection, this will soften the edges and make the erasure more realistic. (use a small feather of 2 or 3pixels).
OK, Actions. I love actions and use them alot. Once again there's a couple of ways to do this but the 2 easiest are ... with your 'Actions' pallette open, click on the options arrow on the top right corner of the actions pallete and select 'New Action' and Name your action and click "Record" - even though in this instance we are not going to Record the Action. Now go to the Actions Pallette and press the black square 'Stop' button to stop the record process. Go back to the Options pointer in the top right of the Actions pallette and choose "Insert Menu Item" - this will bring up a vaige window about no menu selected, where you go to any of the Menus at the top of the screen and select a menu that will do what you want (such as Filters/Sharpen/Unsharp Mask) and this menu now becomes your action so you either just hit the actions button or use the shortcut you selected before record, to save having to hunt through the menus all the time for regular things you use.
Now, the 2nd method to create and action is very similar - but first, open and image that you'd like to apply the action to and put it in the state you would like the action to start from (ie, if you need to crop or colour or size it first). Now go to your Actions Options and choose 'New Action', name it, apply a shortcut if you want, and hit 'Record'. NOTE that you are now recording and everything you do will be recorded in the action - now go about and do as you would like to the image, colour it, size it, unsharpen it, greyscale it, anything, and all these steps will be recorded. Once you have finished all you want to do to the image, hit the black square 'Stop' record button to end the process and this action is now saved.
Don't forget to go to the Actions pallete Optios and check 'Button Mode' to turn your actions into buttons for one-click instant access.
good luck.
Was this helpful?
Yes
No
Popular Solutions for Graphics Publishing and
Questions and Unsolved Problems for Graphics Publishing and
Answer
Help programe shuts down as soon as it loads photos in organiser Adobe photoshop elements 8
Answer
Cannot link Word file to Avery labelPro. Get message ''The data file linked to this design could not... (More)
Answer
how do I set the offset for dimensions in Autosketch 9?
Answer
The picture on my Sony Triniton KV-34XBR800 ( set to 1080i with HDMI converted to DVI ) is too big... (More)
Answer
I turned on the pc88 keyboard and am not getting any reading on the little window screen display.It... (More)
Describe your Graphics Publishing and... problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Graphics... Experts
Top Computer & Laptop Repairmen
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
