Question about Amana ARB9059CS Bottom Freezer Refrigerator
Fridge now groaning
We recently had our 1.5 year old fridge have the compressor changed and since then it constantly groans when the compressor is running ....which seem like 24/7....it does not stop very often....but the temp in both compartments are ok ....it is just this constant groaning.....never did this with theold compressor.....any suggestions...Bob
  • 5 more comments
  • Marc Podeszek Jan 24, 2009
    I have a GE and the compressor will stop for awhile and then come back on a few hours later turned up the cold but does not seem to be getting cold enough inside.
    Please help
  • Anonymous Jan 28, 2009
    I JUST WANT TO KNOW WHAT IS THE NOISE...OUT OF WARRANTY...IS IT ON ITS WAY TO GIVING UP THE GHOST???
    NOT ABOUT TO SERVICE...WILL BUY NEW BEFORE SERVICING. APPRECIATE ANY FEEDBACK ON MAYBE DO-IT-YOURSELF...THANK YOU...MJ
  • Anonymous Feb 07, 2009
    Fridge is super loud
  • Anonymous Feb 10, 2009
    My Acceler-ice, is groaning. It is still making ice with no problems. The constant groaning is making me crazy. Help!
  • Anonymous Feb 20, 2009
    I had the same problem and recently found out that its the Condensing Fan Motor that needs to be replaced. Did you find anywhere to get the parts for this unit?
  • Anonymous Feb 22, 2009
    Replaced my 1st 'made in Brazil' compressor just out of warranty. Technician said they are junk. Now my second one is grinding when running. Doesn't run too often and it's still cold. Help?
  • telstar401 Apr 10, 2009
    Same problem, although the groaning is like a steady croak. Like creaking wood. Totally infuriating. It only happens when the freezer door is shut, however. When the freezer door is opened, even just a little, the noise stops.
    Problem Solver:
  • 5 Answers
My noise was the ice maker wire bail arm that turns on the ice maker.
I have no water line to the fridge, so the ice maker is not in use. The wife bumped the arm down that turns on the ice maker. I pushed it back up, turning it off and the intemittant groaning / buzzing stopped.
Too bad I replaced the perfectly good condenser capacitor first!
Posted on Mar 09, 2009
    Novelist:
  • 87 Answers
First question is when was the compressor change done. If it is within the last year or within the first year as a warranty issue then you should have some grounds to contacting the supplier of the cabinet or the company that did the compressor change. I would definately recommend throwing the problem back at them. If you say that the compressor is constantly running then they should at least check the system out. (you have nothing to lose by contacting them and most companies like customer satisfaction). The system could well be overcharged from the compressor change which can create additional noises, or undercharged causing the system to run more frequently. Either way get them to check it under the premise of the work carried out. Engineers can get the charge off (speaking as one), and correcting mistakes is the qay engineers can learn more, so you're helping them to improve. Hope this is of some help.
Posted on Sep 14, 2007
SOURCE:
Auto a/c compressor will not stay on
Could be a restriction in the system, or a problem with the clutch. Is there a chance the system is overcharged ?
Sep 05, 2012 | 2007 Dodge Ram 2500
I have a samsung 1 year old fridge that wont get cold at all. the compressor, evap and condensor fans all run and i installed a schrader valve on low side to try to vacuum and charge with no luck. it
Compressor should rapidly bring pressure down from standing pressure to running pressure when switched on. If no change, compressor not pumping. Make sure the line tap valve isn't leaking, and the gas you used was correctly charged.
May 19, 2012 | Samsung RF217ACPN 19.7 Cu. Ft. French Door...
Amana side by side fridge makes a groaning noise when freezer is shut, no ice buildup nothing, just groans when light button is pushed
When light goes out, fan starts inside. Groaning sounds like the fan is hitting on something or has a dry bearing. Spray with wd40 on the shaft
May 01, 2012 | Amana Refrigerators
Fridge seems to run too frequently
How old is the fridge? Newer units will run more frequently and make "running" noises.
Apr 30, 2012 | Kenmore Refrigerators
HELLO I have an LG fridge w/bottom freezer model Problem with the LG Refrigerators I have an LG fridge w/bottom freezer model LRBN22511TT approx 9 yrs old. Actually haven't had any troubles with the...
i think that you have diag the problem it is the relay on the compressor . at it age the relay is worn out . i would replace the relay and if it won't start then it may be the compressor . example out 10 friges with this problem 1 will be the compressor and 9 will be the relay. you can also use a 3 or 4 in on kit these help old comp. start easy and keep them running . mm hope this helped . feed back pls .
Dec 12, 2010 | Refrigerators
Both fridge and freezer keep rising in temp, seems to be running constantly. Only about 3 years old. Replaced the board in it, seemed to run quietly for one day keeping proper temps, now back to running...
when you install a new board you have to check i think it's the 9 pin connector,the instructions will tell you what one it is,if there's a wire in the second pin you need to cut the wire or the machine won't run correctly.
Aug 17, 2010 | GE Profile 22.2 Cu. Ft. Bottom-Mount...
I have a labored groaning noise
may be compressor clamp is loose in back side check it
Jun 05, 2010 | LG LBC22520ST Stainless Steel Bottom...
Refrigerator makes thumpa-thumpa-thumpa sound when it's running.
i would start saving up for a new fridge,,if yours is 10 years old its getting past its best by now so its realy not worth spending good money on trying to get it fixed up as its going to pop its clogs soon anyhow
a new one would be cheaper to run plus it would look nice so you could show it off to all your friends,,,
its like,,,eat your hart out i got a new fridge!!!
Apr 03, 2010 | LG LRBN20510WW Bottom Freezer Refrigerator
Small office fridge quit working, will not cool at all, and doesn't seem to be running just about 1 year old
check and change the temp controll first but you cna bet the compressor is out or going out on the unit
Jan 18, 2010 | Refrigerators
Fridge/freezer running, but not blowing cold air
sounds like compressor has failed remove the fridge and put your hand on the black unit at the back (compressor) it should be quite warm if running if not its not starting compressor are at there most stress when starting up and if failing this defrost may have killed it completely
Nov 13, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
Amana ARB9059CS Bottom Freezer Refrigerator Logo
1,309 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
Thomas F. Schneider
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
