Question about Microsoft Office Standard for PC
Im using html to create forms and want to store that data in ms access or any other backend so that more of the data is stored so i just want the syntax to be written in html that can connect the database
    President:
  • 392 Answers
Dear friend, for this subjject you should use CGI scripts, you can't save them only by simple HTML codes, so I provide some useful links to learn how to save entered characters in feedback forms by these CGI scripts and HTML, I hope they could help you, just read these articles carefully.
http://www.yourhtmlsource.com/cgi/processingforms.html
http://www.rebol.com/docs/cgi2.html
http://www.help4web.net/webmaster/html_tutorial/chapter15.html
http://webdesign.about.com/od/forms/a/aabg073099a.htm
You can also make feedbacks form simply by FRONTPAGE, you just need to this software, select a feedback form template, customize it and setting up the form option about how to save, and where to save, but remember that if you use frontpage for this job, your domain should support frontpage extension too.
Good luck
Posted on Apr 15, 2009
I want to learn that how can i connect my HTML page with my DATABASE created in MS ACCESS so that i can fill my table in HTML page directly-
1. You can use Pages option in MS Access. The page in MS Access is the web page in MS Access which allows you to access database in MS Access database.
2. You can use MS Office Front Page application and use the Form builder and connect your database in that.
3. You can also use Google Apps Business Solution for this however the database will not remain in MS Access but will remain in Docs online.
4. You can use .net application developer for this as well but needs expertise in that.
Mar 09, 2010 | Microsoft Office Standard for PC
How i get data from html form to ms access or excel file...????
this needs to be programmed - i.e. when you submit the form it needs to be submitted to something (e.g. java servlet, php script, etc.) that will take the data and insert it into a data store (access, excel, mysql, oracle, etc.)
Apr 09, 2009 | Microsoft Office Standard for PC
Hi all i want to launch a form when i click the data base file in MS access 2003 (the form is created inside the mdb file of access)
hi,
on MS Access 2003:
goto Tools Menu --> Startup --> select your form for "display form/page" dropdown
uncheck the "display database window checkbox and display status bar checkbox
Hope this helps.
Thanks.
Apr 01, 2009 | Microsoft Access 2003 for PC
Connectivity between HTML page and Ms-Access
<HTML>
<BODY>
Set MyConn = Server.CreateObject("ADODB.Connection")
MdbFilePath = Server.MapPath("sample.mdb")
MyConn.Open "Driver={Microsoft Access Driver (*.mdb)}; DBQ=" & MdbFilePath & ";"
SQL_query = "SELECT * FROM Friends"
Set RS = MyConn.Execute(SQL_query)
WHILE NOT RS.EOF
<LI><%=RS("Name")%>: <A HREF="<%=RS("Link")%>">Homepage</A>
RS.MoveNext
WEND
</BODY>
</HTML>
Nov 11, 2008 | Microsoft Office Standard for PC
How to use passwd character in a table in ms-access 2003
When you create table where you want to store passwords, go to Edit Table, then select a field where the password will be stored, go to Input Mask field in Properties and type Password in that field. That will set up the field needed for storing passwords.
Aug 18, 2008 | Microsoft Office Access 2003 (077-02871)...
Ms access
before this u should know what is databse.
ms access has various objects likw table,form,query,report etc..
table is a object which stores the actual data and form is used to enter the data in to the table and display the data from the table, while report is object which is used to desplay your data in required formate.Query is used to fetch the data from the table in customised formate.for that u should have knowledge of SQL.
Nov 14, 2007 | Computers & Internet
Coding in ms word by using visual basic editor
Hello Kavita! If you want to get the most of VB then i advice that you install Microsoft visual studio...But just in case you want it for free you can find it here..
http://www.brothersoft.com/downloads/vb6.html
Nov 10, 2007 | Oracle 10g Database Standard (ODBSEONUPP0)
Connecting html form to Ms-access data base
If, as I suspect, this is for a web form, then it effectively can't be done on a "proper" web server. This is because you cannot install MS Office on an MS server OS (e.g. Server 2003). You need to use MS SQL Server or MySQL instead. If this is for very limited use (i.e. only a few clients at a time), you can use XP running IIS but this is really not a good idea. The sedurity implications don't bear thinking about :) Linking a web page to Access can probably be done using ASP (never even thought of trying it - anyone else here know for sure?) If you are using a Linux web server then it's totally out of the question. Use Webmin or PHPMySQL to set up a MySQL database & PHP to code the linkage between the page and the DB. There are plenty of tools out there that will automate this for you, some of them Open Source and therefore free to acquire.
Sep 26, 2007 | Microsoft Office Standard for PC
MSACCESS Multi user APplication
Access is never good for multi-user with more than about 10 users! MS say: use SQL server. Of course, it all depends on the complexity of the app, the amount of data, transaction rate etc. You can also try putting the backend on a "real" server (15K rpm SCSI or sSCSI disc, Xeon CPU) and give it as much RAM as you can afford (at least 4GB) then you might get reasonable performance. If you can't do it any other way & a licence for MS SQL Server is out of the question, use MySQL as a backend: you can make Access clients talk to it as there is a free Access driver for it. You can even run MySQL under windows: you don't need Linux (although it will run faster under Linux). Setting it up is fairly easy and it will outperform an Access backend by at least an order of magnitude, if not 2 or 3 :)
Sep 19, 2007 | Microsoft Office Standard for PC
Microsoft Office Standard for PC Logo
237 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
