Question about Microwave Ovens
My mircowave oven just stop working.the lights are on all the electric stuff works,just on the inside where you put the food lights ont work and its not turning
    Scholar:
  • 192 Answers
I will bet you have blow a fuse. they are on the inside. this can be fixed at home. if you would like further help contact me . DFD
Posted on Apr 15, 2009
I have a High Pointe model EM925Bss-s and although the turntable does not work the oven still works. Is this dangerous?
no as long as you never put any metal or foil inside but food won't heat evenly , the turntable can usually be fixed by cleaning out center bearing with Q tip and a shot of oven cleaner this sometimes gets lots of food and grease build up from heavy use machines (usually mass food prep areas) and slows and stops the drive of turntable
Sep 10, 2014 | Microwave Ovens
Frig or freeser not cold
If it is your freezer, check to make sure that the air vents inside the freezer are not blocked by food. Putting too much food in an blocking the air vents will prevent the freezer from freezing. Air needs to circulate inside the freezer for it to work properly. This can also cause excess freezer ice collecting on freezer or in foods. Dust and lint will collect under and behind a frig. Pull the frig out from the wall, unplug it. Check for lint under and on the back of it. If it has accumulated some, vacuum it all off and plug it back in and wait a while to see if it gets cold. The fan pulls lint and dust under the frig and it stops the cooling system. If this doesn't work, it may need the freon (can't spell it correctly) stuff replaced. If these don't work, you need to call
Feb 15, 2013 | Microwave Ovens
My mircowave just stopped working. Is there a fuse that may need to changed. It is only 2 years old. Please help it would be greatly appreciated.
There is an internal fuse but my advice would be to seek professional help as there is a risk of electric shock from some microwaves even when disconnected from the supply.
Oct 23, 2010 | Microwave Ovens
The controls along with the clock and timer works on the mircowave. The problem is that the food does not cook or heat up.
probably a defective magnetron; very common for this vintage microwave. there are usually generic magnetrons available; as the original GE part will be expensive.
Aug 25, 2010 | GE JVM1650 1000 Watts Microwave Oven
Mircowave turns on but does not cook food food does not get hot all other options on oven work fine
you have a bad magnetron . that is the heating source . the part is not cheap. go to sears parts direct and check out the price b4 you have someone check it.
Feb 27, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a samsung 1000 watt mircowave that appears to be working in every way except that it is not heating the food at all. It is 2 years old.
There is two posibilities, iether the transformer, is not working or the magnatron, there are very expensive, if all the functions are working then there should be an errror code on display
Jan 06, 2010 | Samsung MW1030WA Microwave Oven
All the light blew out, the electric still works, but the oven won't heat food
Hi, my living room light has stopped working, When i turned it on one of the little bulbs went pop and light stopped working although all electric and other lights still work. I tried the bulb in a different light and it still works as well?? I also took light off to check for loose wiring etc but all seems to be fine. Can you help? Thanks!
Oct 04, 2009 | Whirlpool Accuwave Microwave Oven
Hood range microwave not heating up
We had one that did the same thing. my brother got so mad at it he put a wrench in it and turned it on. It didn't do anything to it. No power surge nothing. It acted as if I put a plate of food. Lighted up turned and even beeped when done. The wrench wasn't even hot. Now I do recommend this myself. But we went and got antoher one.
There is something in there that magnifys the power inside the mircowave and it sounds like its out.
Dec 12, 2008 | Emerson MW8778 Microwave Oven
My GE Spacemaker Microwave is not getting enough power
the dimming of the light indicates a big amount of current being drawn by the magnetron. can you see sparks inside the oven?..it looks like the magnetron is shorting out with the ground. what makes it short to ground could be in the wave guide cover...look for some dark spots or accumulation of carbon from old food residue which becomes carbonized due to repeated heating. carbon is a conductive material that shorts the magnetron to ground.
i hope i was able to help
Jun 24, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Mircowave oven stopped working
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Oct 27, 2007 | Microwave Ovens
Microwave Ovens Logo
80 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
