Question about Canon PIXMA iP1800 InkJet Photo Printer
My PIXMA iP1800 printer will not print. The green light flashes once then the orange light falshes 4 times. This cycle keeps repeating. I've turned it off. I've unplugged it. What else can I do to get it to print?
    Brigadier General:
  • 8,619 Answers
Hi
The indicator light by the card slot flashes when a memory card is installed and the printer is reading the card. If the power lamp and the alarm lamp flash alternately after the drivers are installed and you have connected and switched on again. Did you install the drivers from the supplied disk before you connected the printer? If not, the computer may not recognise the printer. Disconnect the printer from the computer,install the drivers and reconnect. Try downloading the Printer Drivers from this link. If this does not help then 1. press power button while plug in the powerchord - green lamp.
2. while hold the power button press resume button twice - orange
blink and return to green.
3. release the power button,
4. click the reset black reset color
5. click the reset main and reset platern
You will see in the iptol menu that the ink lvl will be reseted and the wp and wm will set to 0 and new cartridege installed.
then exit
restart the printer
if the problem still occured do the same procedures from 1 to 3 then.
click the eeprom reset botton
wait for for a second the menu will be resetted and the printer will initialized.
turn off the printer then turn on and try to print..by the way i recognize the printer if u park the head of printer in the replace ink area position, there will be a blinking error u will notice after a few print or after u used u need to reset the eeprom in iptools. Please do accept this solution and revert for further assistance. Thanks Rylee
Posted on Apr 15, 2009
Canon Pixma iP1800: amber, green, amber, greeeeen flashing lights
what error message coming from your computer...i think something stuck inside your printer
Feb 24, 2010 | Canon PIXMA iP1800 InkJet Printer
Canon i850 light is green then flashes orange 7 times then goes green and repeats orange flashing. Printer never gets ready
This is a very bad error. It means that the printhead needs servicing and may need to be repaired. There is no easy fix. Sorry.
Jan 21, 2010 | Canon i850 InkJet Photo Printer
Ink absorber is full and need to reset
found this at fixyourownprinter.com. Seems it works on most canon models and may work on your ip1800.
1) With the printer2_bing.gif power turned off, while pressing the Resume/Cancel button, press and hold the Power button. (DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light
alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4) When the Power LED lights in green, press the Resume/Cancel button the specified number of time(s) according to the function listed in the table below. (Each time the Resume/Cancel button is pressed, the Alarm and
Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.) [hth: I believe the power button has to be pressed once more after cycling the alarm button to complete the action. The power/resume-cancel button LEDs toggle to help you count.]
Time(s) LED indication Function Remarks
0 times Green (Power) Power off When the print head is not installed, the
carriage returns and locks in the home position capped.
1 time Orange (Alarm) Service test print See 3-4. Verification Items, (1) Service test print.
2 times Green (Power) EEPROM information print
See 3-4. Verification Items, (2) EEPROM information print.
3 times Orange (Alarm) EEPROM initialization [hth: does not re-initialize Waste ink counter]
>>>> 4 times Green (Power) Waste ink counter resetting
5 times Orange (Alarm) Destination settings [hth: not applicable]
6 times Green (Power) Print head deep cleaning (Cleaning of both black and color)
[hth: 7-10 not applicable]
11 to 13 times Orange, Green, Orange (Alarm, Power, Alarm) Return to the menu selection
14 not used in servicing
15 Orange (alarm) return to the menu selection,.
Note: If the Resume/Cancel button is pressed 16 or more times, the Alarm or Power LED lights steadily without
any changes.
Nov 27, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
IP1800 PIXMA printer will not print.
If consumables are all replenished, your printer should work properly.
Apr 15, 2009 | Canon PIXMA iP1800 Printer
Cannon pixma ip1700 not printing
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal.
Feb 13, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Canon iP1800 printer,flashing orange light under the green 'on'
First off, How many times does it flash organge before it goes to green?
two: out of paper
three: paper jam
four: Ink has run out
Five: FINE cartridge cannot be found
Seven: FINE Cart. not installed in correct position
Eight: Ink absorber almost full
Count how many times it flashes. Then get back to me
Feb 05, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Canon PIXMA iP1000 Printer - don't work
GO ON LINE
CANON PIXMA iP1000 7 FLASHING LIGHTS
ENTER
ROD
Feb 04, 2009 | Canon Office Equipment & Supplies
I get a message error that ink cartridge is not well installed
Remove all the cartridges then back again installed..if the orange light is always blinking.long press the cancel botton til the green light is steady..ok..
Jan 03, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Canon i550 printer stoipped printing
My cannon printer no longer responds to any commands. I get 4 yellow blinking lights and then 1 green blinker.
Oct 09, 2008 | Canon BubbleJet i550 InkJet Printer
Canon PIXMA  iP1800 InkJet Photo Printer Logo
old marine
old marine
