Question about Mitsubishi WD-52525 52" Rear Projection HDTV
I have an older Mitsubishi WS-55905 and would like to add a HD receiver but the HD control port on the TV is not compatible with the new BluRay receivers. Can this problem be solved?
  • eugenekamp Apr 15, 2009
    Did not answer the question !
    Champion:
  • 230 Answers
Dont waste your time w/ this kind tv, I lot problems w/picture tube coolant. serious.
Posted on Apr 15, 2009
How do I connect a bluray player to Mitsubishi WS-65313
Check the connections for firmness. If the converter works properly, there shouldn't be any problem other than this.
Jul 09, 2014 | Mitsubishi Televison & Video
Add hdmi port to mitsubishi ws-65807
I doubt it as it was never designed for that kind of input, Component works best on this set and it should have only one HD input for a box marked in the menu as DTV.
Dec 13, 2012 | Mitsubishi WS-65807 65" Rear Projection...
The picture on tv looks dimmed on my mitsubishi WS-55905
There are a few things to try first if you have not done so:
If the set has not been "serviced" for several years, unplug it and remove the back cover. You will see 3 large black lens dead center above the main boards-------wipe them clean either with a lens cloth or a paper towel with glass cleaner sprayed on the towel.
If the lens are dusty, the picture will be darker and duller looking than it used to be.
Let me know what you find as I am here to help.
SD TECH
Jul 30, 2010 | Mitsubishi WS-55905 55" Rear Projection...
It say 480 stretch on the screen how do I turn it to 1080 for my Hd tv
Make it sure that you have a 1080 signal from your source(eg. HD receiver, bluray player etc.). Try pressing format button on the remote until you get full picture . Or try changing the format or aspect ration in your satellite or cable box.
Dec 29, 2009 | Mitsubishi WS-65511 65" Rear Projection...
I have a tv model # WS-65315. I would like to know if I can hook up a Blueray player and still get HDMI quality?
No, your tv is strictly a Standard Definition one. Even it can receive a HD signal, it is downscaled internally to SD so the image would look exactly like from a low quality dvd player (that's because the internal converter is a cheap one) For best image quality use the converter from the BluRay and the Component connectors.
Nov 29, 2009 | Mitsubishi WS-65315 65" Rear Projection...
Mitsubishi WS-55905 No picture or sound, but TV stays powered on
Most of the time its the STK ICs they are big Black ICs they will have Part number on them example STK392-570 replace both of them Call Mats for parts and you will need heat sink silicon as well to put on back of ICs 1-800-628-1118
Nov 19, 2009 | Mitsubishi WS-55905 55" Rear Projection...
Blue, green, red parallel curved lines at top of screen
hello sorry but it sounds like the chip have gone again when you replace these chips you might have to change the resistors and the 2 capacitors as well
shaun
May 08, 2009 | Mitsubishi WS-55905 55" Rear Projection...
Can't seem to add HD channels to Mitsubishi WS-65513
You need to run an external antenna feed to the air DTV input jack, bottom left. You can use your loop out if you already have an antenna connected to your antenna A input jack. Create a DTV device, then run your antenna setup for DTV.
Mar 14, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Upgraded DirectTV satelite TO HD
direct tv hd receiver is hdmi or rgb which is a different signal than the rgbhv input on the back of older mitsubishi tv . You can buy a converter that converts the format for about 90 dollars online. It converts rgb or component to vga/rgbhv
Oct 24, 2007 | Mitsubishi WS-55805 55" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
73 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
