Question about Xerox Phaser 8400 Laser Printer
Fault code 37,004.40:49612
When starting the printer this is all i get. Please advise
  • wandaejg Apr 23, 2009
    I am having the same problem with mine -- error code 37,004.47
    (remaining number is your page count).
    The reference manual says perform the following tests:
    a. inspect and reseat the printhead interface cable and retest
    b. replace th electronics module and retest
    c. replace the printhead
    Sounds simple, but pricey!
  • Xerox Master
  • 4,338 Answers
Check you power coming in to the unit. If you are using a surge protector or UPS unit, Plug the unit into the wall and power up the printer. If that does not work, then:
PEST Fault 37,004.40: xxx
Printhead reservoir 0 disconnect:
Reservoir is not drawing the expected power from the power supply.
Service manaul states the the printhead needs to be replaced.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 10, 2009
I had my car Nissan Maxima 2011 sitting for 6 weeks now I have no power and the car will not start. Please advise
probably a flat battery
have it charged and then run the fault codes if it doesn't start
Oct 12, 2016 | 2011 Nissan Maxima
Truck wont start
A defective EGR will never cause a no start, rough idle yes, check engine light yes. Who told you this would cause a no start and what fault codes did you have?
Aug 15, 2016 | Cars & Trucks
Xerox 7345 error code009-936 has been received. Please send the solving process.
Return to Search Results
Solutions for : Fault Code 009-936: More Than One Consumable is End of Life Fault Related Fault Code: 009-936 Solutions ranked by relevance:
  1. Make Sure All Highlighted Supplies Are Replaced
Have you found what you are looking for? Yes
Not Yet
Please Help
Dec 17, 2015 | Xerox Workcentre 7345 Printer, Copier,...
Miele G641 SC Plus Drain /inlet light 4 short 1 long flash. How do I find a fault code chart?
Inlet / Drain is a general fault meaning there was no water movement when it was necessary to start the pump. Either it didn\'t drain out or it didn\'t fill the last time.
Call 800-999-1360 for free Miele tech support. They will advise you free of charge. You will perform step by step control board operations over the phone to clear the fault code as well as advise you how to cleanout the drain pump.
Dec 27, 2014 | Miele Dishwashers
Fault code on a 2004 Freelander td4 = P3505. Vehicle won't start at all? Please advise. Thanks.
from what research I have found it looks like the glow plugs is the answer to the question of what code # P3505 is.
I hope I helped you in the right direction, it would make sense why it wont start.
Mar 24, 2011 | 2004 Land Rover FreeLander
Service Light keeps coming on with Code C440. Please advise why?
This is a fuser heat error. Have you performed the reset procedure? If not just turn off the main power, hold the 0 and 8 keys WHILE turning the power back on. Type in 400 then press Start. Set the displayed number to 0 (zero) then hit set or enter.
Power off then back on and the code should be cleared. If it keeps coming back then the fuser unit will need service. Most common fault is the thermistors which are small electonic parts that monitor the temperature of the fuser unit. Pretty in-expensive parts.
Good Luck and Thank You for using Fixya.
Jan 04, 2011 | Toshiba e-studio 455 Copier
I have a ricoh Aficio 3025 all in one, it is now giving me a fault code of SC543 please advise
its temp. or fixing error. try to clear it in service mode.
yellow 197 red when it says SERVICE MODE turn off and on machine, if it does not help you need to call service to replace thermistor, or lamp, or rise temp. ,or ...
Nov 12, 2009 | Ricoh Aficio 3025 All-In-One Laser Printer
2006 2.9 turbo diesel will not start fault codes P1119 P1120 P1640 check engine light stays on cannot locate main relay & computer position any suggestions
dear friend-it is very difficult to explain myself in a text. I would say ignore the fault codes at hand for a while untill we have a definate fault. I would like you to make sure that the battery is fully charged, when you carry out the next exercise. I want you to try and start it with quick start, but please do not crank to long, gentle squirts will do it. If no joy, then we must go live chat- I am sure it will work, but please come back to me
Jul 07, 2009 | Hyundai Motor S Cars & Trucks
F7 fault code on Hotpoint WD860
Fault code F7 is a heater relay fault
Sep 25, 2008 | Washing Machines
Sharp sf7800 photocopier
The machine has not reached temerature in time which is down to either the heater lamp has blown or the thermal fuse. Press a series of buttons to reset - Cancel / Interupt / 0 / Interupt / 14 / Print button.
Aug 01, 2008 | Office Equipment & Supplies
Xerox Phaser 8400 Laser Printer Logo
139 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
