Question about Yamaha Music
Yamaha PSR keyboard won't power up
When dismantled, I found that the Voltage Regulator is blown, or missing.
I obtained this device at a bargain price, and thought it might be a good idea repair it.
I need schematic diagram for this device, or label code for missing VR.
  • 1 more comment
  • mrkan15 Apr 27, 2009
    It is Yamaha psr 7, I forgot to put the model name, old&simple model. To avoid any mess, here is the link, about this model
    http://en.wikipedia.org/wiki/Yamaha_PSR-...
    The voltage regulator is placed on the Printed circuit board, near the headphone and the DC power jack. The correct orientation, as well as the correct name-label of the electronic part iz very important to me.
    Thanks for Your interest!
  • mrkan15 May 01, 2009
    Problem is in exact replacement,I dont know which it is. I actually
    don't know is it simple 7812 voltage regulator, or something else,
    because it is not there. Somebody obviously tried to fix it, but
    without success.
  • Michial Gueffroy May 11, 2010
    I may have the schematic you need if you can let me know which model it is.
    President:
  • 1,138 Answers
Unfortunately, I only have schematics for PSS-560 and PSS-570. If I remember correctly,with the parts side facing up, there should be a parts orientation printed on the circuit board. It will look like 2 black bars side by side with one of the black bars thicker than the other. If you got an exact replacement with the correct pin out the metal piece on the part that the black piece is mounted to with the 3 pins facing down towards the parts side of the circuit board should line put with the black bar lines on the circuit board. I hope this makes sense. Please get back to me. I had one of these keyboards laying around in my parts bin but stripped it because all the keys were broken and as they come in one strip asnd have to be ordered specially, I didn't bother keeping it. I may still have the circuit board somewhere.
Posted on Apr 28, 2009
  • Michial Gueffroy May 02, 2009
    It sounds like the 7812 is what you need if the place where the part is missing had three holes side by side directly under it. The pinout for the 7812 is as follows. Looking at the part with the pins straight down and the black piece with the numbers on it facing you the pins are left to right: pin 1 voltage in, pin2 ground(tab), and pin3 voltage out. Without a schematic, I know it is hard to troubleshoot something like this but usually the circuit board had part orientation symbols on the part side. If it doesn't you can still figure it out by looking at the trace side. The ground trace is fairly easy to tell and it will be the middle pin. It will also be the trace that the negative wire from the battery supply is soldered to. The input voltage to the 7812 will be the trace that the positive wire from the batteries is soldered to. You will need to get the power supply happening before you can troubleshoot the rest if that doesn't initially solve the problem. Please get back to me for further info if you need it.
Does it have an internal battery?
HQRP AC Adapter / Power Supply for Yamaha PSR ... - Fixya
www.fixya.com/search/...hqrp_ac_adapter_power_supply_yamaha.../60...
HQRP AC Adapter / Power Supply for Yamaha PSR-280 / PSR280 / PSR-290 / PSR290 Keyboards Replacement plus HQRP Coaster, 600 related issues. ... is there an internal battery to protect memory and if so, do i need to replace it? yes there ...HQRP AC Adapter / Power Supply for Yamaha DGX-620 / DGX620 / DGX- ...
www.fixya.com/...hqrp_ac_adapter_power_supply_yamaha_psr/adapter
HQRP AC Adapter / Power Supply for Yamaha PSR-280 / PSR280 / PSR-290 / PSR290 Keyboards Replacement plus HQRP Coaster, adapter related ... need a new one, you could try to get a replacement from casio or try to get an ... It MAY appear to operate on DC BUT it can't generate the +/- voltages internally for sound .
Musical Instruments - Keyboard Accessories on Pinterest ...
https://www.pinterest.com/.../musical-instruments-keyboard-accessories/
HQRP AC Adapter / Power Supply compatible with Fulltone CATALYST / CHORALFLANGE Guitar Effects pedals Replacement plus HQRP Coaster by HQRP. $7.91. ... The MS-90 is a column monitor stand that features three internal channels - .... Yamaha SK88 Survival Kit for 88-Key YPG Series Keyboards by Yamaha.
Dec 25, 2015 | HQRP AC Adapter / Power Supply for Yamaha...
Power falier
Power failure?
First check the power supply / adaptor to ensure this is working correctly. Measure the voltage using a multimeter - if this is correct move on ( if not replace power supply )
Does the keyboard work if you hold the plug in the socket or move it slightly ? If so this is a common problem as the power socket on the pcb fails at the solder joint and will need to be repaired / replaced.
If this appears to be solid then you may have done some internal damage by either plugging in a power adaptor with a too high voltage or wrong polarity. If this is the case you may have blown some circuitry inside which controls voltage regulation.
Please report more if you have more information.
Jan 22, 2014 | Yamaha PSR-E223 keyboard
My yamaha psre323 does not connect
I have a PSR-E323 and to connect it with my pc using a MIDI connector should i install driver from http://download.yamaha.com/usb_midi/ ??? I tried to install that.. An error msg popped up... error 25001 no device is connected. connect a device and try again. If the "found new hardware" wizard appears push the cancel button...What should I do?? Help me pls...
Apr 10, 2012 | Yamaha PSR-E323 Keyboard
Repairing Yamaha psr-12
If the power adapter is not the original adappter- check to make sure the polarity is correct- it should be marked on the keyboard near the adapter socket, and also on the adapter itself.
The keyboard should have an internal fuse- check that. Then with keyboard open, if the fuse is okay, trace the power flow from the power pack and look for broken wires, bad solder connections, stressed components like bulging capacitors, etc. It may have a burned out zener diode in the power supply regulator portion of the main circuit.
Mar 29, 2012 | Yamaha PSR-E223 keyboard
Am looking for a power supply board for yamaha keyboard
Normally if the board is there, I repair failed components. If the board is missing, call Yamaha America parts dept. They MAY have the part you need. That will be the only source of a complete replacement. Power supply boards are usually easily repaired.
Mar 04, 2011 | Yamaha PSR-295MS Portable 61-Key...
Do you have yamaha keyboard psr 2000 spare parts?
My keyboard yamaha psr2000,so I want parts silicone rubber keypad 61 and including electronic board,thank you.
Feb 12, 2010 | Yamaha Full-Size Keyboard
Yamaha PSR-280 : AC power instead of DC power
An answer, but likely not a solution. I believe all Yamaha PSR series keyboards use the same 12 VDC adaptor, so I looked at the electrical schematic for another model I have. There seems to be no fuse on the power input. There are two components shown on the positive and negative wires off the power socket, but the symbols do not look like anything I have seen for fuses - they may be resistors. Power goes directly to a 5 VDC voltage regulator, which powers all of the solid state componenents. Too much voltage of the wrong type could have easily ruined many of the sensitive components.
Your only hope is to check the power socket area for the possibility of having fuses. My drawing shows the power socket, voltage regulator, and audio power amplifier being on one circuit board. That may not actually be the way it is in your model.
(your English is fine)
Feb 23, 2009 | Yamaha Portable Keyboard with 61...
Music Logo
505 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
