Toshiba Satellite C850D-BT2N11 Customizable Notebook Laptop Logo
A
Anonymous Posted on Sep 11, 2013
Bios password typed incorrectly for satellite pro C850D
5 Related Answers
Anonymous
  • Posted on Aug 14, 2009
SOURCE: forgot password for bios
Hi Arthur Clarke,
Did you set the BIOS password for your notebook or was it set automatically by the computer? Anyway, to solve this problem, you may need to bring out your system to a near Toshiba ASP.
If you need further assistance or information regarding your problem, call Toshiba Tech Support (800-457-7777). Hope this helps.
peepnklown
Frank
  • 175 Answers
  • Posted on Dec 08, 2009
SOURCE: unlock bios Toshiba Satellite Pro A60FR !
This WEBSITE should help you out:
http://www.tech-faq.com/reset-bios-password.shtml
Silverdragon
electronic & computer repair& servicre
  • 12061 Answers
  • Posted on Feb 20, 2010
SOURCE: toshiba satellite pro l 350 bios password reset
This is the ONLY other way, save paying Toshiba and filling in proof of ownership forms.
The BIOS password is removed by the BIOS configuration, you need the BIOS password to get into the BIOS configuration.But if you do not have the BIOS password then you need to construct this dongle device.
TOSHIBA BIOS PASSWORD DONGLE
You can build a dongle that plugs into the printer port.Purchase a 25 pin male D sub connector and solder insulated wires to the various pins as listed below. The pins are numbered on the connector
http://www.tilman.de/sonstiges/toshiba/dongle1.jpg this is a picture of the finished dongle
Wire the pins as follows :-1-5-10, 2-11, 3-17, 4-12, 6-16, 7-13, 8-14, 9-15
Plug the finished dongle in the printer port and power up the laptop. The password will be reset, go into the BIOS configuration to check the BIOS password, you may have to disable the BIOS password.
Anonymous
  • 4 Answers
  • Posted on Jun 24, 2010
SOURCE: Toshiba Satellite Pro A200 BIOS Password Request
for removing the password,
you have to open the memory cover and remove the two RAM s,
after that remove a black or whit plastic film depending on your model, you will loacte for B500 marqued ( XXX ) or J1 you have at least short
the two point with a flat screwdriver and put the upper memory and power on the laptop will holding the screew driver till you see the toshiba screen, if it doen't work just try again. it works 100%
small6363
  • 18429 Answers
  • Posted on Feb 09, 2011
SOURCE: HOw can I reset the bios password on a Toshiba
http://www.computerhope.com/issues/ch000235.htm
try this link
Need to unlock the password
There are three types of passwords:
BIOS, WINDOWS LOG-ON and E-Mail. Be more specific.
Just so you know, BIOS, just remove the CMOS battery for about 1 minute. Windows Log-on, forget about it. Your screwed. And e-mail, click the "Forgot My Password" link in the sign on screen. Lots of luck!
Satellite C850D bios reset solution
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
As the computer is booting repeatadly press the F8 key as the computer is booting If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. select safe mode with command prompt Then type at the C:\> prompt: type
DEBUG
and hit Enter. You'll see a dash (-) at the DEBUG prompt. Now type:
o 70 2e
which will show as -o 70 2e at the DEBUG prompt. Hit Enter. Then type:
o 71 ff
and hit Enter. Finally type:
Quit
and hit Enter one last time to quit DEBUG back to the C:\> prompt.
Now you're ready to reboot your PC, and press the appropriate key or key
combo (look it up in your motherboard manual if you don't know it) to access
your BIOS Setup. Youll notice the password is gone. If this fails try typing At command prompt type debug
you will get a - prompt where you can type the following (<enter> means press enter, not type enter*)
A <ENTER>
MOV AX,0 <ENTER>
MOV AX,CX <ENTER>
OUT 70,AL <ENTER>
MOV AX,0 <ENTER>
OUT 71,AL <ENTER>
INC CX <ENTER>
CMP CX,100 <ENTER>
JB 103 <ENTER>
INT 20 <ENTER>
<ENTER> just hit enter on this line
G <ENTER>
Q <ENTER>
Basic BIOS password - works 9.9 times out of ten
If this fails you will need to Select safe mode with networking to download you could download all of these or just one save them to a usb drive for later use if one fails to remove the password http://www.tech-faq.com/reset-bios-password.html At some stage you might need to press Ctrl+Enter rather than just Enter if on a Dell Latitude E5410 http://majorgeeks.com/CmosPwd_d239.html A CMOS BIOS password recovery tool Editors note: This tool should only be used by experienced computer users. Please see the enclosed read me if you would like to run it from Windows. Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus. Hope this helps. http://www.laptop-repair.info/toshiba_bios_password.html
Problems witn my laptop toshiba satellite C850D-109
start all over and factory reset at the opening look for something like F10 and you can reset to factory and it's just like new. you will have to put in anything you added though...
Hi, I got a Toshiba Satellite Pro M10, Is there a way to remove Password?, i can not access to the O.S. (not even to the bios). Thanks
Yeah - if it's a BIOS password, but if it's a HDD password then you're screwed and there's nothing to do but replace the HDD.
For a BIOS password removal, either buy a parallel port password removal key, or make your own. Schematics can be found here: http://www.cgsecurity.org/wiki/CmosPwd.
My laptop Toshiba Satellite Pro A210 is locked with password in BIOS SETUP It does not recognise the original password
Wow, as I have a Toshiba Satellite Pro. I'm sorry, but there is no easy way out of this if you have enabled a bios lock. It is looking for a password that "someone" set up. I say that because there is no bios password when you setup the machine. Also, the bios password is completely different from the user or system password. (Although you could make them the same.)
Please find the person you got the computer from; type in the correct password; and be aware that it is case sensitive. Make sure the caps key is not accidentally down.
Recap:
- there is no original bios password; you would have needed to set it, and remember it. There is no recovery (that I'm aware of) to a mis-placed bios password.
dw
5helpful
3answers
How to remove bios password for Toshiba Satellite A200
If you know the current password, use it to enter BIOS SETUP.
Then, type a "blank" ("space-bar") as the "new" password.
If you don't know the current password, you're stuck;
this is a "security" feature to prevent a stolen laptop from being used by the thief.
Bios Password
Backdoor passwords
Many BIOS manufacturers have provided backdoor passwords that can be used to access the BIOS setup in the event you have lost your password. These passwords are case sensitive, so you may wish to try a variety of combinations. Keep in mind that the key associated to "_" in the US keyboard corresponds to "?" in some European keyboards. Laptops typically have better BIOS security than desktop systems, and I a not aware of any backdoor passwords that will work with name brand laptops.
WARNING: Some BIOS configurations will lock you out of the system completely if you type in an incorrect password more than 3 times. Read your manufacturers documentation for the BIOS setting before you begin typing in passwords
Award BIOS backdoor passwords:
ALFAROME ALLy aLLy aLLY ALLY aPAf _award AWARD_SW AWARD?SW AWARD SW AWARD PW AWKWARD awkward BIOSTAR CONCAT CONDO Condo d8on djonet HLT J64 J256 J262 j332 j322 KDD Lkwpeter LKWPETER PINT pint SER SKY_FOX SYXZ syxz shift + syxz TTPTHA ZAAADA ZBAAACA ZJAAADC 01322222
589589 589721 595595 598598
AMI BIOS backdoor passwords:
AMI AAAMMMIII BIOS PASSWORD HEWITT RAND AMI?SW AMI_SW LKWPETER A.M.I. CONDO
PHOENIX BIOS backdoor passwords:
phoenix, PHOENIX, CMOS, BIOS
MISC. COMMON PASSWORDS
ALFAROME BIOSTAR biostar biosstar CMOS cmos LKWPETER lkwpeter setup SETUP Syxz Wodj
OTHER BIOS PASSWORDS BY MANUFACTURER
Manufacturer Password
VOBIS & IBM merlin
Dell Dell
Biostar Biostar
Compaq Compaq
Enox xo11nE
Epox central
Freetech Posterie
IWill iwill
Jetway spooml
Packard Bell bell9
QDI QDI
Siemens SKY_FOX
TMC BIGO
Toshiba Toshiba
TOSHIBA BIOS
Most Toshiba laptops and some desktop systems will bypass the BIOS password if the left shift key is held down during boot
IBM APTIVA BIOS
Press both mouse buttons repeatedly during the boot
Good Luck!
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
