Question about Logitech 967461-0120 Keyboard/Mouse
Looking for a special mouse driver
Hi Expert team, I'm looking for a mouse driver that makes my mouse automatically jump to the left side of the screen once I'm leaving the screen on the right side or backwards or top to bottom / bottom to top Do you know of such a drive? thanks for your support & have a nice day Martin
  • 89 Answers
Well.. i am quite sure that no such a thing exist i don't know why you want your mouse pointer jump to the right but there is nothing like that
Posted on Sep 17, 2007
SOURCE:
Hi I purchase a gigabyte optical mouse model no GZ-PMSUO3-G3 If I plugg it into the usb port of my labtop it gives me a message of unidentified usb device. I have looked every where on the net for a...
Normally usb mouse driver automatically installed by operating system specially on windows os. which operating system your laptop have. do one thing remove usb driver from device manager and restart your pc and install usb driver from your motherboard cd if you have.
But again i dont think mouse need driver os has default driver for mouse.
Oct 15, 2017 | GE Optical 98802 Mouse
In my compaq window vista compute ,cursor is jumping.pls help.tks
If you are using a mouse, change it or try using a mousepad. If it happens on the trackpad then you need to uninstall and replace the driver.
To do that you need to right-click on 'My Computer' and select 'properties'. Then choose 'device manager' (top left) This will list the hardware on your computer. Expand 'Mice' Right click on your mouse/trackpad and choose uninstall. Close all the windows and restart the computer. It will load the new driver automatically.
Jul 25, 2010 | Dell Inspiron 1525 Notebook
My Kensington 72216 mouse makes selections automatically.
Have you installed the drivers for your mouse? Sounds like you need to install the drivers. I looked on there site and they don't have separate drivers for each mouse. I'm guessing you need to download the mouse works program and install it. Here is the link to the website to get that software. After you install that software for the operating system your working on, your mouse should work fine. If i helped please leave me a rating. If i didn't help, comment and ill try again.
Mar 22, 2010 | Kensington PilotMouse Optical Wireless...
Automatically cursor jumps . When we type in the cursor automatically moves fromm one place to another
I presume you have a touchpad under your keyboard.
Usually the hand position when you type is such, that it's very easy to involuntarily lighlty touch the touchpad with the base of your thumb, usually the right one, when you move the hand over the touchpad, mostly in the up-left direction.
This causes the cursor to move to some other place, usually up and to the left, resulting in the next characters you type being put in that place :)
Try to keep your hands a little bit more above the touchpad when you type. Also, many touchpad drivers have settings for ignoring light touches/drags, try looking into these settings in your pointing device properties.
As an aid, I would recommend a soft gel wrist support, which automatically elevates your palms above the keyboard.
Nov 13, 2009 | IBM Lenovo ThinkPad T400 7417 Notebook
Keys on left side of keybord do not work
if you have a laptop with special keys left of the keyboard, you may need to install drivers and or software for them, look for them at the makers website the the brand and model of the laptop or keyboard.
if its a special keyboard look for its drivers and software at its makers website.
also if after all that the problem is still not solved make sure hid input service is enabled.
info on the service:
http://www.theeldergeek.com/hid_input_service.htm
how to turn it on or check its status
press the windows key and R key at the same time or windows key first and then r.
in run menu write in services.msc
presss ok or enter
in services look for HID input service or similiar make sure its started, right click on it and select properties make sure its set on automatic start up and start the service if its stopped with the start button. Apply, close ok. should work.
May 20, 2009 | Compaq Keyboard
Dell d600 mouse pointer jumps into corners if working on documents etc.; maybe if the system stores data in the cache or ram, the cursor wether jumps into the left down corner or moves slowly in directon...
What the issue is, is the eraser head mouse in the enter of the keyboard. When you type, it's putting uneccessary pressure on it, and it makes the pointer move. The only solution I know for this is to get the updated ALPS driver for the mouse, and disable the eraserhead (The updated driver gives you an option to do this), thereby using only the touchpad mouse.
Mar 15, 2009 | Dell Latitude D600 Notebook
Expert Mouse scrolling problem
I have the same problem running under win7 64 bit, I have just pulled apart my expert mouse\trackball to clean it and found that the scroll ring works by using a little infrared diode ... so no cleaning required ...
the screws for the base are located under the little rubber feet.
So I think the problem may be more related to drivers\software...
at the moment I cant find a win 64bit driver or mouse works application anywhere
Feb 05, 2009 | Kensington Expert Mouse Trackball
Cordless mouse works only with the right click side and can't go
You may need to go ahead and remove the driver for the mouse and reinstall the driver.
You will first need to remove the program by going to "Add/Remove Programs". Once you have found the driver there, then do "uninstall". After the program uninstalls, remove the wireless dongle if one came with the mouse, restart the computer, then use the same disk that came with the mouse to reinstall the driver on the computer. During installation, make sure to re-insert the wireless dongle so that it can communicate with the mouse.
If that process is unsuccessful, then you may want to look into returning the mouse as it may have hardware malfunctions taking place which will require an expert to remove certain aspects of the mouse in order for it to function correctly. Without ruining your manufacturer or store warranty, I would highly recommend taking the mouse back at this phase to ensure you can get a replacement for the product without making the problem worst.
May 20, 2017 | Computers & Internet
Open Questions:
See all Logitech 967461-0120 Keyboard/Mouse Questions
Logitech 967461-0120 Keyboard/Mouse Logo
51 people viewed this question
Top Logitech Computers & Internet Experts
Ekse
Damen Wong
Damen Wong
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
