Question about Uniden Cordless Phone
My phone has a answering machine with it but i now have call answer with cable how do i set up the phone to show that i have messages
How do i set up my phone to useexternal answering system
  • 89 Answers
If you want to use a different answer machine just run the phone line from the wall to the machine you want to use. Be sure you plug in the cord that say's "Line". Then use another cord that will plug into the answer machine that say's "phone". Plug that other end into your phone and be sure to turn the answer machine off on the phone. Good luck.
Posted on Apr 17, 2009
Hi. My At&t Cordless 2 Hand set Telephone (EL52213) Answering machine (ON) doesn't record incoming messages. The Message window shows 0. The Telephone base is connected with my FAX machine (Teleph
If your Phone service is recording messages, that disconnects your line. You need to have them turn that feature off, OR set the answering machine to answer is less rings, say two or three. If the FAX machine listens to the line, it can still be set at a higher amount of rings, say four, and should still answer any FAX signal as it's sent to the answering machine.
Jan 25, 2015 | AT&T Lands Phones
THE ANSWERING SYSTEM WON'T RECORD MESSAGES,ALL MESSAGES GOES INTO POOVIDERS VOICE MAILE, AS IF MY PHONE IS BUSSEY?????? I CHECKED AND RECORD TIME IS NOT SET TO ANNOUNCE ONLY ANS ALL MESSAGES HAVE BEEN...
This happens when the number of rings to answer of the provider voicemail is less than the number of rings to answer that the answer machine is set for. For example: if your provider voicemail rings to answer is set for 3 rings and the answer machine is set for 4 rings then the voicemail answers before the 4th ring, therefore the answer machine will never get a message. I would call the service provider's customer service number and request they increase the rings to answer above the number of rings to answer that the answer machine is set for. If you don't want voicemail to answer any calls(when your line is busy or when the answer machine is turned off) ask your service provider to disable voicemail.
Mar 30, 2011 | Uniden Cordless Phone
Answering machine is set to fax only i cannot seem to be able to set up the answering machine to receive messages.
Hello
The fax has a phone port labelled 2-EXT. Connect a phone cable to the 2-EXT port on the end, and then the answering machine on the other end. No setup the answering machine to answer the call after 4 rings, and setup the printer to answer after 6 rings, and make sure Auto Answer is turned ON on the printer.
good luck, and do rate the solution if got help
Dec 08, 2010 | HP Photosmart C7280 Printer
When people leave me a message - the answering machine does not show that I have a message. The person calling hears the greeting - leaves a message, but I do not receive the message.
It may be similar to the problem I had on wireless home phone with answering machine not taking messages when had the answering machine set to 12 rings before answering. Found the sim card (my wireless system) auto response would answer first. Fixed it by reducing time to 6 rings and answering machine now comes on first.
Oct 12, 2010 | Uniden Cordless Phone
I have philips landline phones. My main phone does not ring or flash when an incoming call comes in. I t won't go onto answer phone either it just rings out. I can pick it up and answer the call. i can...
Looks like the basic functions of the phone are correct. Remain the answering machine. Are you sure it can act as an answering machine?
If it can act as answering machine the reason it is not doing so may be the following.
  1. Answering function is turned OFF
  2. Answering function may be ON but the number of rings before it answers is set too high.
I suggest you try the following
Call you phone. Let it ring at least 10 times. If it can act as an answering machine it will pick up the phone and read the welcome message, because most answering machines (the recent ones at least) answer after 10 rings even if answering function is turned OFF.
The phones that can be answering machines usually do have a display that shows the number of incoming messages, or a LED that flashes to let you know that you have new recorded messages.
Jan 03, 2010 | Philips Lands Phones
Can not get messages on my answering machine, show the letter a
Your machine is set to "Announce" instead of "Answer" mode. The announce mode merely plays an outgoing message but does not record any incoming messages.
Since you neglected to specify the model of your VTech 5.8GHz cordless system I can only suggest you enter it into the search box here to download a copy of the manual to learn how to switch modes.
Apr 22, 2009 | Vtech 5.8GHz Expandable Cordless Phone...
Record my answering message
If you have the manual there is a full tutorial on how to set it up with a standard phone line. It is pretty simple if you have that. What type of phone service provider do you have? For example I use a cable phone provider and my answering machine has to be set up via their phone number.
Nov 25, 2008 | Uniden TRU8885 Digital Answering Machine
Answering machine does not take messages
answering machine does not record message but keeps showing an A on screen
Jul 01, 2008 | Vtech i6772 Trio Cordless Phone
Shuts off before I can leave a message
If you are on (Rogers) phone via cable, this model of answering machine is not compatible. I'd love to hear a work-around.
Apr 11, 2008 | GE 29875GE Digital Answering Machine
Can't get the answer machine to work
i own my answering machine but friends say it doesn't come on , i bought a 205 . help
Jan 07, 2008 | Lands Phones
Uniden Cordless Phone Logo
235 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
