Question about Samsung NC10-14GW Notebook
Cannot Connect to Internet on Samsung NC10
Went through the setting up and put in our wi-fi connection codes etc. It is showing the the signal is strong, but when I click on Internet Explorer it says it is unable to connect.
Can you help please
  • Anonymous Apr 16, 2009
    My network shows full connection and yet the internet shows nothing.
    President:
  • 1,865 Answers
Try running installation CD and then connecting
Posted on Apr 15, 2009
HOW TO CHANGE THE INTERNET SETTINGS IN THE HTC WILDFIRE A3333
Wi-Fi provides wireless Internet access over distances of up to 100 meters (00 feet).
To use Wi-Fi on your phone, you need access to a wireless access point or "hotspot". The availability
and range of the Wi-Fi signal depends on the number, infrastructure, and other objects
through which the signal passes.
Turning Wi-Fi on and connecting to a wireless network
From the Home screen, press MENU, and then tap Settings > Wireless & networks.
Select the Wi-Fi check box to turn Wi-Fi on. The phone then scans for available wireless
networks.
Tap Wi-Fi settings. The network names and security settings of detected Wi-Fi networks
are displayed in the Wi-Fi networks section.
If the wireless network you want to connect to is not in the list of detected networks,
scroll down the screen, and then tap Add Wi-Fi network. Enter the wireless network
settings, and then tap Save.
Tap the Wi-Fi network you want to connect to.
If you selected an open network, you will be automatically connected to the network.
If you selected a network that is secured with WEP, enter the key and then tap
Connect.
Depending on the network type and its security settings, you may also need to enter more information
or choose a security certificate.
When your phone is connected to a wireless network, the Wi-Fi icon appears in the
status bar and tells you the approximate signal strength (number of bands that light up).
The next time your phone connects to a previously accessed secured wireless network, you
will not be prompted to enter the key or other security information again, unless you reset
your phone to its factory default settings.
Jan 28, 2015 | HTC Wildfire A3333 Cell Phone
Tip
How to set up internet on Samsung Jet
Ensure that you have the appropriate network key code needed to enable you to access a secure Wi-Fi network.
If you are connecting to a secure Wi-Fi network with MAC address restrictions, you will require pre-authorisation for the router. You will need to find your Samsung Jet's MAC (Media Access Control) address. This is a 12-character code which may be needed by the network controller to enable the phone to connect. See Getting the Samsung Jet's MAC address below.
You can get to the Wi-Fi application either via the main menu or using a homescreen Wi-Fi Widget.
  1. To get to the Wi-Fi application via the main menu, press the MENU button (either on the home screen or the hexagonal button beneath)
  2. In the main menu, swipe your finger sideways to go through the menu pages until you see the Wi-Fi icon. Press to select.
  3. The Wi-Fi application opens.
  4. Alternatively, to use the Wi-Fi Widget, from standby, press the home screen. The Widget toolbar opens up.
  5. Scroll down to find the Wi-Fi Widget icon. Press the Wi-Fi Widget. The Wi-Fi Widget will pop up on the main screen.
  6. Press the Wi-Fi Widget on the main part of the display to launch the Wi-Fi application. The Wi-Fi application opens.
  7. Once in the Wi-Fi screen, press the large Wi-Fi button in the middle of the screen to turn it on. Wi-Fi is activated and the button turns blue.
  8. Press SEARCH Nearby Wi-Fi access points (APs) will appear as small circles on the display, with their names next to them.
  9. Press the circle representing the Wi-Fi Netowrk you want to connect to. An options panel appears.
  10. You can press CONNECT to connect to the network or press ADD if you want to add it to a list of preferred networks for easy access later.
  11. You are taken into a settings menu for the Wi-Fi access point. If the Wi-Fi access point requires a network key code, scroll down to the Network Key panel. Press to select.
  12. The numberpad appears. Type in the network key code and press DONE. You are returned to the previous settings screen. Press SAVE
  13. A list of connections appears. Press the back arrow button
  14. If you initially pressed CONNECT, the phone will connect to the selected Wi-Fi network and a confirmation message will appear. The display now shows the new connection, illustrated by blue dots linking the circles onscreen (Figure 15).
  15. If you initially pressed ADD, you will be returned to the Wi-Fi screen. Press the circle representing the Wi-Fi network you want to connect to. A pop up panel appears.
  16. Press CONNECT. You will be connected and the connection illustrated onscreen.
Press the back button to return to the home screen.
  1. From the home screen press MENU to enter the main menu (Figure 1).
  2. In the main menu, press INTERNET
  3. Choose which browser option you want (Home, Enter URL, Bookmarks, etc.) (Figure 18) and press to select. If you press Home you will be taken to the pre-loaded home page.
  4. If required, use the numberpad to type in an URL or scroll a list to select bookmarks. When an URL is completed press GO. Alternatively press the bookmark you wish to access. You will taken to the web page requested.
  1. Activate Wi-Fi and press SEARCH, as before.
  2. When the Wi-Fi access point you want to connect to appears on the display (Figure 8), press it to select.
  3. A pop up options panel appears (Figure 9). Press DETAILS
  4. Details of the Wi-Fi access point appear onscreen.
  5. Scroll down by dragging your finger up the screen. Towards the bottom of the settings list, DEVICE MAC appears, with a string of 12 charactesr beneath (Figure 21). Each handset has an individual MAC address, and this panel will display your Samsung Jet's unique Mac address.
Make a note of the MAC address. You will need it if you want to use the Samsung Jet's Wi-Fi to access a secure Wi-Fi network using MAC address restrictions. This can be added into the wireless router settings access list.
on Apr 17, 2010 | Samsung Jet S8000 Cell Phone
I can only get a very weak wi-fi connection
What is you internet speed? if the speed is less than 5Mbps change the network speed settings in the wifi router to 100Mbps to 10 Mbps that will solve the issue.
Apr 28, 2012 | Samsung P30 Notebook
I cant get an internet connection on this phone, do i need to set it up manually?
There are two ways you can connect to the internet over your phone. You can purchase a data plan from a company like AT&T which you can use anywhere. The other option would be to use your phone to connect to a wireless access point(WI-FI).
What are the differences? Wi-fi is usually free unless at a cofee shop etc but has a smaller area in which you can access(you have to be within a certain distance of the wireless router). A data plan cost money and is typically slower, however, you can use it at anytime as long as you have a signal on your phone.
You can click here to access the user guide for your phone.
If you have a data plan purchased and are using the SIM card they gave you then whenever you use a application on your phone that requires internet access it will connect.
If you go to page 83 of the manual it will go over the steps you need to take to enable Wi-Fi. In short, first active Wi-Fi
1) In Idle mode, open the application list and select Settings
? Wireless and network ? Wi-Fi settings ? Wi-Fi.
1) Then under Wi-Fi settings click Wi-Fi networks, select the Network you wish to connect to then click Connect.
Reference the user manual as it goes into more details about the features on your phone and how to use them.
Regards,
G33k
Jul 29, 2011 | Samsung Galaxy S GTI9000 Smartphone
Am having trouble findind my wifi coneection for my osns phone , how can i connect it to my home hub . plz
1st switch on ur Wi-FI from setting menu. then search wireless connection, (pls make sure ur home wi-fi is tuened on) if found any signal, just connect it it will ask for pass key or key. just entered it. (pass key is configured in ur home wi-fi router) u will able to surf internet from ur mobile................
Feb 04, 2011 | Samsung Star GT-S5233 Cell Phone
I dont know how to connect my internet to my wii
the wii has a built in wi-fi reciever so you HAVE to have wi-fi if you dont buy a wireless router hook it up to your computer you need to have high speed internet for this then once your wi-fi is set up go to wii options internet connection then click search for connection if you have it set up right it will show your connection name then you click on it and it will retrieve the signal from your connection and you can go online from your wii.
Dec 23, 2009 | Nintendo Wii Console
Samsung np-nc10 shows good signal for site wi fi but wont connect
Go here and download the latest Wi Fi card drivers for your samsung, from samsung.
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=&prd_mdl_cd=&prd_mdl_name=NP-NC10
Hope it works
Jim
Dec 20, 2009 | Samsung NC10-14GW Notebook
Could not connect to the internet using wi-fi connection
need to configure modem/router. just put ip address off modem into address bar on web browser. use admin as name and password for password. Check out portforward.com and all info will be easily found to solve problem.
Oct 26, 2009 | Samsung Omnia Pro B7320 Smartphone
I have wireless - router with built in dsl modem DGN2000. Working fine with my desktop but I have just purchased a laptop and have not been able to connect signal to it.
1. Dear! Check your notebook wireless settings and correct it if it is necessory.
2. Chekc your wireless router settings may it need to update for your notebook.
Good Luck
Sep 28, 2009 | Computers & Internet
Samsung NC10-14GW Notebook Logo
496 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
