The receiver is turning off with F76 error
I have an av control receiver SA -XR70 and it is turning off with F76 error message. What is wrong?
  • 6 Answers
SOURCE: Need 5 Digit Remote Code for a Panasonic Receiver HE-100
Try 1518 or 1039
/www.comcast.com/remotes/universal.html
Posted on Dec 12, 2008
  • 4234 Answers
SOURCE: F70 ERROR ON PANASONIC AV RECEIVER SA-HE200
This is essentially a protection mode indication. Either the output amp pac is defective or the regulator circuit is bad. Either option could be over $75 in parts plus labor at a local shop.
Let me know if you would like to attempt the repair and I'll try to get you more specific parts information.
Dan
Posted on Mar 17, 2009
VOTIT
  • 2071 Answers
SOURCE: How do I conect my ipod to the Technics AV control
You just connect it in the auxilliary input then switch your reciever to auxilliary so you can the sound of your ipod. First buy a wire connector from ipod to reciever.
Hope it may helps;
Regards:
VOTIT
Posted on Jun 17, 2009
Sparky2012
  • 102 Answers
SOURCE: My Technics AV Control Receiver SA AX530 is in overload
An amplifier should never be turn on without speakers, it will overload internally.
make sure speakers work and try again.
Posted on Dec 04, 2009
dunnbiker
  • 8546 Answers
SOURCE: My Technics SA-AX540 AV Control
Heat?
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections as a root cause for intermittent shutdown.
Posted on Feb 21, 2011
Panasonic sa-pt770 will not power on
When power is applied do you get any LED light or display that shows?
Dec 27, 2014 | Panasonic Sa-pt770 Receiver
AV CONTROL RECEIVER SA_HE7 F70
F70 error checking fixed contacts fuses.
Oct 04, 2013 | Panasonic SA-HE7 Receiver
Sa-100bt i have an f76 error after taking unit apart i have found that there is a black wire next to where the fan plugs in this wire has been disconected does any one know where it goes thanks
Usually that is just to wrap around the fan cable to make sure it doesn't go into the fan. F76 error can be either the fan is not turning, or the amp is bad.
Apr 16, 2013 | Panasonic sa-ht930 Home Theater Audio...
I have an old Panasonic SA-HT40 surround sound system. When the unit is powered on the error message "F76" shows on the display and then the unit shuts off immediately. The user manual instructs to un
I have the same problem with my Panasonic model SAHT-40. I get the same code plus popping and shortly reads maximum overload then cuts off. I disassembled my unit and discovered that my fan fails 2 work causing the unit it over heat. I called Panasonic 2 place an order 4 a cooling fan. This model is obsolete they dont even manufacture parts 4 this unit anymore. The closest that I can get with my credit card is Samsung model AH31-00056B cooling fan through Panasonic. I hope that this solution helps all of u out with ur unit!
Nov 30, 2012 | Panasonic SC-HT40 System
Panasonic AV Control Receiver SA HE7 error code F70
solution about f70 on my amplifier to remove
Jun 07, 2011 | Panasonic SA-HE7 Receiver
I need the kie soo thad i can get the hol program to reagt
Beim Einschalten des Receivers SA HT07 kommt die Fehlermeldung F76 und der Receivers stellt sofort wieder ab. Alle Lautsprecherverbindungen sind ok! Wo liegt das Problem ?? vielen Dank für die Hilfe
Mar 28, 2011 | Audio Players & Recorders
Dec 04, 2009 | Technics SA-AX530 Receiver
WHAT DOES THE ERROR MESSAGE F76 MEAN?
1/ check overheat stat 2/ check fan esp the little hose at the fan area for pinhole best of luck
Sep 28, 2009 | Noritz 6.9 Gallon Residential Tankless...
Error Code "F76"
spoke to a friend at an authorized servicer and he said he has never heard of that code but from what yourm describing its eather the outputs the speakers or the power supply Oh and a sevice manual is availiable at the partstore.com or from the panasonic web site as I've been there. good luck
Apr 10, 2006 | Panasonic SC-PM08 Shelf System
 Grubhead
Grubhead
