Question about Sharp AL 1631 Copier
Not copying There are no error lights. TD and Drum cartridge are good. Scan Head locking switch is unlocked. Light is working. I unplugged it, waited and then replugged, still no copies. It is running, sounds okay, appears to be copying, but nothing happens. Help!!!!!
    Sniper:
  • 67 Answers
Let the machine run they will cycle a long period of time trying to add toner, if you let it run you'll probably get the toner lite to come on.
Posted on Apr 15, 2009
All the lights are flashing. I have put in a new cartridge, unplugged and turned off the machine, I cleaned it with the air duster. It will not work
Try the following tricks:
Disconnect any USB cables attached to the printer and remove any memory cards from drive bay. Restart the computer. Unlock the ink cartridge locking clips. Remove all ink cartridges. Lock down the ink cartridge locking clips. Close the main printer door Turn the printer off with the Power button and wait for the printer to shut down. Unplug the printer AC adapter from the printer and the wall outlet or surge protector. Wait approximately fifteen to forty-five seconds to allow all current to dissipate from printer. Re-plug only the AC adapter into the wall outlet then into the printer, but do not plug in the USB cable. Wait for the appropriate missing ink cartridge error to verify that printer can recognize this error. Re-insert one ink cartridge only, to minimize confusion in case one of the cartridges is defective, and print an internal test page. If no errors are found, insert the other ink cartridge(s) and ensure that they are functioning by performing internal test pages or calibration pages. If an error occurs due to a defective cartridge, perform the appropriate steps for Resolving Ink Cartridge Rejections. After returning to the main Windows screen, reconnect the USB cable to the computer then to the printer. Good luck. Thanks for using FixYa.
Jun 01, 2010 | HP LaserJet 1012 Printer
Display flashes e2 alarm light blinking won't print or copy
E2 mean reload the paper correctly and press Black or Color key from panel board.
Dec 01, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
I JUST CHANGED THE TONER AND THE COPIES ARE PRINTING OUT WITH A HEAVY THICK LINE ON THE SIDES
Indication Cause and remedy Page
Drum replacement
required indicator
Steadily
lit
Replacement of drum cartridge will be needed
soon. Prepare a new cartridge. 70
Blinking Drum cartridge must be replaced. Replace it with
a new one. 58
TD cartridge
replacement
required indicator
Steadily
lit
Replacement of TD cartridge will be needed
Blinking TD cartridge must be replaced. Replace it with a
new one. 57
Misfeed indicator Blinking
A misfeed has occurred. Remove the misfed
paper referring to the description of "MISFEED
REMOVAL".
63
SPF misfeed
indicator Blinking
An original misfeed has occurred in the SPF.
Remove the misfed originals referring to the
description of "D: Misfeed in the SPF".
67
Power save indicator is
steadily lit.
The unit is in the preheat mode. Press any key to
cancel the preheat mode. 54
The unit is in the auto power shut-off mode.
Press the start ( ) key to cancel the auto power
shut-off mode.
54
The paper tray indicator is
blinking.
The paper tray is not installed properly. Push the
tray into the unit securely. –
"CH" is blinking in the
display.
The TD cartridge is not installed. Check if the
cartridge is installed. 57
"CH" is steadily lit in the
display.
Side cover is open. Close the side cover
securely by pressing the round projections near
the side cover open button.
"P" is blinking in the display.
The paper tray or multi-bypass tray is empty.
Load paper. 15, 17
A misfeed has occurred in the paper tray or
multi-bypass tray. Remove the misfed paper. 63
A letter and a number appear
alternately.
The scan head locking switch is locked. Unlock
the scan head locking switch. 9
alternately.
The unit will not function. Turn the power switch
off, remove the power cord from the outlet, and
contact our Technical Assistance Department at
1-(630)378-3590 in the USA or 905-568-7140 in
Canada.
May 13, 2009 | Sharp Office Equipment & Supplies
Locked up AL-1642CS with blinking Drum Light
the clear key may be stuck which seems to lock up your machine. The procedure to reset the drum lite is clear, auto (exposure setting), clear, auto when hit in a timely manner the display will go blank. Enter 24 then press the start key, then enter 07 and press the start key again. If you can't get the keys to work the circuit board may have cold solder joints.
Good luck
Bob
May 03, 2009 | Sharp AL-1642CS Copier
I have 2 model al-1540cs copiers that are producing blank copies. The scanner doesn't seem to be moving and is in the unlocked position. I am getting no error messages, the paper is facing in the right...
When [L1-00] appears, the scan head
locking switch is locked. Turn off the
power, release the scan head locking
switch, WAIT 10 SECONDS and turn the power back on.
Dec 04, 2008 | Sharp AL-1540CS All-In-One Laser Printer
Older Sharp AL copiers will go on working with the drum light blinking, but yours will not. Newer models do stop working when the drum reaches its limit. Now keep in mind that just as almost every copier in the market, these units count the copies they make in order to determine toner & drum life. So it is possible to reset the drum counter if you inspect the unit and see no markings or visible wear & tear. Also keep in mind that the toner & drum units have been the same for all AL units through time, so there are plenty of good replacements in the market (not recycled, but re-manufactured or brand-new compatibles).
As for your unit, if the drum is Sharp original or a good quality replacement, you should have to do nothing after installation, for the internal chip in the drum will tell the copier to reset the counter and begin working automatically. However if that is not the case, or should you want to reset the counter on your existing drum, this is the correct sequence to do so.
  1. Identify the buttons used for adjusting exposure (darker or lighter copies), amount of copies, clear copies and start copying.
  2. Now press the following sequence of buttons: [CLR], [EXPOSURE], [CLR], [EXPOSURE]
  3. Your unit should turn off the numbers in the panel.
  4. Now press 24 as if asking for 24 copies and press [START].
  5. Press 07 as if asking for 7 copies and press [START].
  6. Your unit should restart by itself and start working normally.
Be blessed.
Nov 07, 2008 | Sharp AL-1641CS Laser Digital Copier
Replacing Drum Catridge
Hello, Here are the steps involved in replacing the drum assembly as copied from a users manual:
DRUM CARTRIDGE REPLACEMENT
The useful life of the drum cartridge is approximately 18,000 copies. When the internal counter reaches approximately 17,000 copies, the drum replacement required indicator will light up indicating that replacement of the drum cartridge will be needed soon. When the indicator begins to blink, the unit will stop operating until the cartridge is replaced. Replace the drum cartridge at this time.
1 Remove the TD cartridge (Toner Cartridge). Hold the drum cartridge handle and
gently pull the cartridge out. Dispose of the old drum cartridge in accordance with local regulations.
3 Remove the new drum cartridge from the protective bag and remove the protective cover from the cartridge. Then gently install the new drum cartridge.
When closing the covers, be sure to close the front cover securely and then close the side cover. If the covers are closed in the wrong order, the covers may be damaged. Do not remove the protective cover on the drum portion (black paper) of
a new drum cartridge before use. The cover protects the drum against external light.
Do not touch the surface of the drum (green portion) of the cartridge. Doing so may cause smudges on the copies.
4 Gently install the TD cartridge. Close the front cover and then the side cover by pressing the round projections near the side cover open button. The drum
replacement required indicator will go out and the start indicator will light up.
Aug 15, 2008 | Sharp AL-1217 Copier
Flashing "L1" error
A letter "L"  and a number "1"  appear alternately = The scan head locking switch is locked. Unlock the scan head locking switch.
Hope this helps. Good luck.
Jul 29, 2008 | Sharp AL-1217 Copier
Copier Locks up L1 Error Code
there is a locking dial under the left side of the machine that maybey holding the scanner in home position.... be sure its unlocked.
Dec 09, 2006 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
47 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
