Question about Radio Communications
TS-450S Noise Blanker, No 1 & No 2 neither has any effect on noise
  • 7 Answers
The noise blanker settings on the TS-450S (and S/AT) are true noise blankers and should not be thought of as a DSP device or something that they are not, like a notch filter or IF shift and etc. They will do a fine job of eliminating ignition noise as well as eliminating the electric mixer or blender noise from the kitchen...... however they will not remove static crashes or quieten those atmospheric noises on 75 meters during summer time thunderstorm season activity.
Hope this helps!
Posted on Jun 26, 2009
CB Plays out PA Speaker
Are you following the user manual that came with the radio?
NB-ANL/CB/PA SWITCH: When the switch is in the NB/ANL position, the Noise Blanker (NB) and Automatic Noise Limiter (ANL) circuits are activated.
The Noise Blanker is very effective in eliminating repetitive impulse noise such as ignition interference. In the CB position, the PA function is disabled and the radio will transmit and receive on the speaker that is connected. In the PA position,
the radio acts as public address amplifier. Your voice will come out of the speaker that is plugged into the PA. SP. jack on the rear panel. The radio does not operate when you are in the PA mode.
When you plug a speaker into the ext. jack does it kill the radios internal speaker? It should until you unplug it; if not and you are following the about you may have a wiring issue with the jacks.
May 04, 2014 | Radio Communications
Kenwood ts 450s
Have you tried downloading a PDF of the service manual? I found several sites with Google: "kenwood ts-450s service manual"
Jan 10, 2014 | Radio Communications
What is a voic box on a cobra 29 ltd? What is a good antt combo four a 29 ltd?
Cobra's LTD 29 model Citizen's Band radio features the full 40 channels allowed and a heavy-duty microphone. The radio provides 4 watts of AM radio frequency output with a switchable automatic noise limiter and noise blanker. Other features include Cobra's Delta-Tune function. Making a Cobra LTD 29 hear and receive better involves making changes to the radio's settings, including the settings specific to this brand.
M/F Turn the switch labeled "NB/ANL, ANL, OFF" to the "ANL" position and try the transmission again if noise is affecting reception. "ANL" is an automatic noise limiter function and reduces noise caused by the vehicle's electrical systems and electronics.
M/F Switch to "NB/ANL" to activate the noise blanker, which may also reduce noise if you continue to have problems. It's an RF noise filtration function and will help with ignition noise.
M/F Adjust the "RF Gain" knob by turning it clockwise to increase gain in weak signal areas if you have problems hearing radio traffic.
M/F Set the "Delta-Tune" function to capture a more listenable signal and get rid of adjacent channel noise. Rotate the knob labeled "Deltatune" to the center position for best tuning. Try micro-adjustments to the left or right as well.
M/F Turn the volume up if you still can't hear and as with any CB radio, adjust the squelch if the radio is noisy when there's no traffic. Turn the knob labeled "Squelch" all the way to the left to receive all signals, including noise and turn the control clockwise until the background noise stops. You will be able to hear the strongest transmissions without having to listen to weak signals and noise.
The service manual can be found here
Jan 23, 2013 | Lands Phones
When I connect the Mackie 1642-vlz3 from the "direct outs" to the line level inputs of the D3200 there is noise/hum (except for channel 1). There is no noise/hum in the XLR inputs. I have two...
Make sure ALL of the interconnected equipment is powered from the SAME receptacle to avoid ground loops due to the safety ground. DO NOT Use two wire power or use ground lifting plug adapters. Make sure you use balanced lines, either XLR or TRS cables. Do NOT use TS cables.
Jun 01, 2011 | Korg D3200 Digital Studio
What exactly does the anl nb/anl button do on my cobra 29 wx nw st
ANL stands for "Automatic Noise Limiter" and NB stands for "Noise Blanker".
The ANL gets rid of a lot of interference noise caused by mechanical noise from motors and other electronic components in a car.
It also gets rid of noise from other sources of interference.
The NB is for extreme cases of noise, but can slightly lessen your receive sensitivity.
Basically both functions help decrease interference noise.
Nov 24, 2010 | Cobra 29 WX NW ST 40-Channels Base CB...
Kenwood TS-450S won't load on new 20M dipole.
Surely you've checked connections, etc.----could balun have gone bad? Also are you using an external tuner? Lots of MFJ tuners will "screw up" once in a while. Open it up and inspect it
Dec 31, 2008 | Radio Communications
NB-ANL buttons what are there funtion?
NB-Noise blanker this helps elemenate noise in the receive.ANL-Automatic noise limiter wich does about the same thing as the Noise blanker.
Nov 06, 2008 | Cobra 29 LTD CB Radio
Delta force magnum radio
Herman, one thing that should help is turn on the NB and also TONE .
Feb 08, 2008 | Magnum DeltaForce CB Radio
Radio Communications Logo
242 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
