Question about HP OfficeJet 6110 All-In-One InkJet Printer
Paper missmatch I keep getting paper missmatch everytime I receive a fax. I remove paper, put it back in, press enter and sometimes it works and sometimes i doesn't until I get the next fax and it continues to show the problem... what can I do?
  • 25 Answers
Cause The HP all-in-one has a media sensor that checks the type of paper loaded before printing a fax. If the sensor detects that the paper is not plain paper, this message will display. The message may also display when the correct paper is loaded in the all-in-one, but the media sensor cover is displaced, distorted, or covered by debris. For more information and how to resolve this issue click here.
Posted on Apr 23, 2009
How do i send fax where do i put the paper
Paper inright hand side tray, at top , Must not put paper in Printing unit at the front. To send Fax , use Fax mode, enter receiver Fax phone Number , Press any Black ot Colour button to send
Mar 14, 2015 | Canon PIXMA MX340 Wireless Office...
Having problems with our 7820N fax printer. Paper is getting stuck almost everytime we copy or receive a fax. It usually is in the back of the machine and the paper needs to be pulled out and then is...
Hi!
It is best to have someone check your printer for blocks or anything that may have caused the paper getting stuck. Another thing to do is to fan the stack of paper that you load. Do not load it straight away. Sometimes paper get stuck to each other and cause some loading issues.
Feb 11, 2011 | Brother MFC-7820N Printer
Our fax machine is sending faxes fine, but will not print in coming faxes. It keeps asking for paper (which is in the fax machine), then it sounds like it's working, then stops. We turned it off to see...
The paper isn't properly loaded. remove the paper then there should be a lever near the paper loading section that you push or pull to let the paper enter the feeding area. put in paper and return the lever to the proper position. check your owners manual. to get a manual try www.sharpusa.com .
Dec 16, 2010 | Sharp UX B700 Plain Paper Inkjet Fax
Not receiving any incoming faxes
Is the phone line working? Do you have any devices connected to the phone line that pick up before the fax machine? Make sure the machine has paper and is set to FAX or AUTO. Is there a Memory Full error? Clear the memory (Setup > Memory Clear then press Start/Enter. Use the left and right arrows to select the items to remove. Press Start/Enter twice (second time to confirm the choice). Repeat until all memory is cleared that you wish to clear. Then press Stop to exit.)
If you are using the ANS/FAX mode and have an answering machine connected to the extension port, disconnect the anwering machine and switch to FAX or AUTO. Check if the machine receives faxes. Sometimes the extra device causes interference. Call the fax machine from a different phone number and see if you hear the fax tones.
Check that the Junk Fax barrier is off, if the incoming call is from a machine that is not listed in your speed dial database. If you have a distinctive ring, make sure that the Fax machine has learned the ring by pressing Setup go to DRPD. Choose Set and call the fax machine from another phone. The LCD will say Waiting Ring until it gets that call and then once the ring is learned will say END DRPD Setup
I hope these ideas help.
(If you have a phone company voice mail service, the faxes may end up stuck in that box. It depends on how many rings the fax is set to wait before picking up versus when the voice mail opens to take the call.)
Jul 16, 2010 | Samsung SF-515 Plain Paper Laser Fax
How to register number has been delete. How do you put them back in a Pansonic Panafax UF-55o machine. The fax machine work just the long distance number that was register are going. Need to know how to...
press
function 72
set
press 01 on the soft key pad enter fax number
set
enter name with the letters on the soft key pad
set
continue with 02 as above or press stop
press
function
62 set to print diectory
Mar 24, 2010 | Panasonic Panafax UF-550 Plain Paper Laser...
Press enter to align cartridges message comes into the window of my HP combo machine and won't change. I reset the cartridges in their holders, turned machine off/on, no go. The machine still prints out...
You should load paper and press enter to align, The message will keep coming back until you let it do alignment or press enter and option buttons at the same time.
Jul 24, 2009 | HP PSC 2210 All-In-One InkJet Printer
Check paper error
Check paper can also sometimes mean a jam. Remove the drum unit from the machine and check for a piece of paper inside the machine.
Also with this machines feed path it can mean that a foreign object can fall down the back and obstruct the paper.
Mar 11, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
Paper
If you see this message on the front panel of the HP PSC 2210 when you are receiving a fax, check that the paper size is set to match the paper size in the paper tray. (You cannot receive a fax on 4 x 6 paper or on an envelope.) Checking the paper size setting
  1. Press Setup .
  2. Press the right arrow until you see 3: Basic Fax Setup .
  3. Press Enter .
  4. Press the right arrow until you see 4: Paper Size .
  5. Press Enter .
  6. Press the right arrow until you see the paper size that matches the size of the paper in the paper tray.
  7. Press Enter .
Aug 28, 2008 | HP PSC 2210 All-In-One InkJet Printer
Canon pixma mp530 all-in-one printer set up
Receive Mode Setting
On the operation panel, press the following buttons to select the appropriate receive mode.
  1. Press <Fax>.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode set], then press <OK>.
  4. Press the right or left arrow button to select the receive mode that best suits your needs, then press <OK>.
    FAX ONLY MODE: When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only.
    MANUAL MODE: When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually.
    ANS MACHINE MODE: When you want to receive voice messages on your answering machine and receive faxes automatically.
    FAX/TEL AUTO SW: When you want to receive faxes automatically as well as voice calls.
    DRPD: When you have subscribed to a DRPD service with your telephone company.
  5. Press <Stop/Reset> repeatedly to return to fax standby mode.
Solution: Changing the TX report MP530
Change the TX Report 1. Press the <Menu> button to display [FAX SETTINGS].
2. Use the [ left.gif] or [ right.gif ] to select [TX SETTINGS] then press <OK>.
3. Use the [ left.gif] or [ right.gif ] to select [TX REPORT] then press <OK>.
4. Use the [ left.gif] or [ right.gif ] to select [PRINT ERROR ONLY] or [PRINT FOR EACH RX] then press <OK>.
5. Use the [ left.gif] or [ right.gif ] to select [YES] or [NO] for [ATTACH TX IMAGE:] then press <OK>.
6. Press <Stop/Reset>.
Changing the Paper Size, Type and Source
Changing the Paper Source
Before printing, confirm that the location where you have loaded paper is selected as a paper source. Press <Feed Switch> to change the paper source.
(A) Auto Sheet Feeder Lamp
(B) <Feed Switch>
(C) Cassette Lamp
Note: Press <Feed Switch> so that the Auto Sheet Feeder Lamp lights when loading paper in the
Auto Sheet Feeder and the Cassette Lamp lights when loading paper in the Cassette.
You can also select the paper source with the printer driver when printing from the
computer.
Changing the Page Size and Media Type
Note: The asterisk <* > on the LCD indicates the current setting.
1 . Press <Paper>.
When you do not need to change the page size, press <OK> to proceed to step 4.
2 . Use leftright.gif to select the page size: A4 / B5 / A5 / 4x6 / 5x7 / C-CARD / 8.5x11 / 8.5x14
sizetypelcd.gif 3 . Press <OK>.
4 . Use leftright.gif to select the media type: PLAIN / PHOTO PRO / PHOTO PLUS / MATT PHOTO / GLOSSY
Note: In order to obtain optimal quality print results, when copying photographs, use Canon-recommended Photo Paper Pro or Photo Paper Plus Glossy.
5 . Press <OK>.
Entering the Date and Time Note: When your machine is connected to a computer with the MP driver installed, even if the date and time are entered from the Operation Panel of the machine, the date and time will be read from your computer every time you start the computer, turn the machine on, or disconnect and connect the USB cable. When using your machine connecting to your computer, set the date and time on your computer precisely.
The date and time will be reset when you disconnect the power cord or there is a power failure. In this case, you can set it again on the machine. Alternatively, it can be read from your computer and set on the machine by connecting the machine to your computer with the MP driver installed.
1. Press [FAX], then press [Menu].
2. Use [ left.gif] or [ right.gif] to select <USER SETTINGS>.
3. Press [OK] two times.
datetimeset.gif 4. Use the numeric buttons to enter the date and time (in 24-hour format). Enter only the last two digits of the year.
Note: If you misentered the date and time, use [ left.gif] or [ right.gif] to move the cursor under the number to enter the correct number. Three formats of date are available.
5. Press [OK].
6. Press [Stop/Reset].
I hope it helps!!!
Nov 25, 2007 | Canon PIXMA MP530 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
