Question about Intuit QuickBooks Premier 2009 Full Version for PC
Using my HP 1000 I try to print a check and the page comes out black. Only the checks
Quickbook 2009 version, suddenly when printing a check it print total black over the paper. I can print reports but can not print a check. I am using the HP 1000. Never had this problem. I reloaded drivers, still nothing. A black sheet of paper comes out.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 205 Answers
You need to update your printer drivers or contact your printer manufacturer
Posted on Apr 16, 2009
My HP C4780 PRINTER WILL PRINT A TEST PAGE BUT NOTHING ELSE. How do I get it to print?
Check the settings in Windows Print Manager.
Make sure that the paper quality matches what is in the printer. If set to glossy, minimal ink is deposited on the page. Also, check the print quality - draft quality provides a minimal amount of ink as well.
Jan 17, 2015 | HP PS C4780 All in One InkJet Printer
Self test is printing but system print is not printing
Dear there is no control panel switch on printer how you got self test?. it might be engine test.. Was the printer recognised by the system?.. if no replace "POD" cable then check..
if yes check for drivers,.Test page is coming from system but print is not coming, do virus check for files, create fresh word page then try..
Sep 18, 2011 | HP LaserJet 1000 Printer
Printing check error code 7224
Using Quicken Premier 2009 on Windows 7 x64 with HP OfficeJet 7310.
My check wouldn't print and was booted out of Quicken. Validated data (was OK), reinstalled Quicken Premier 2009 (per instructions above), checked printer and driver (was-OK), I still could not print checks (error code 7215 and quicken closed).
SOLUTION: I deleted the transaction I was trying to print, the re-entered it. It printed fine.
Feb 13, 2010 | Intuit Quicken Premier 2009 for PC
Printing check from Quicken 2009 Deluxe
All Printers have this issue printing from quicken you would need to download the older version of quicken from oldversion.com
Then uninstall the new version and install the old version.
all lexmark/canon/epson/brother/hp.....printers have this problem with the new quicken.
Or try calling in to us at 1800-474-6836 and provide us with a remote session with your computer we may be able to fix this issue with a basic driver.Let me know if you have connected the printer thru usb or ethernet and I will give you a resolution that works 70% of the time with the new quicken
Jun 16, 2009 | HP OfficeJet 6310 All-in-One Printer...
Printer won't print black
When you go to print check to see in your print preferences settings to see if color or black and white is checked. Could also be the specific program's print options you are using to print the pages.
May 25, 2009 | HP DeskJet 5550 InkJet Printer
HP D7360 prints in magenta instead of black. Both cartridges are
Check your other colours. Anything other than a True Type Font is printed in colour shaded with black, so it sounds like you have a problem with yellow and cyan. Either the ink cartridges are out or the print heads have a blockage.
If the cartridges are not empty or v low, try sitting the print head over a folded paper kitchen towel damped with hot water for 10 minutes. Remove it and try your diagnostic again.
Dec 11, 2017 | HP Photosmart D7160 InkJet Printer
Hp laser jet 1000 series
try giving printer test page from the pc.if that comes properly then its the problem of tally software.if the test page comes with same block then its printer driver problem.delete the driver and reinstall the printer driver.
thanks.
Sep 19, 2008 | HP LaserJet 1000 Printer
HP 2420 sudden prints pages in all black
Most likely to be the toner cartridge is it OK on other programs such as the web explorer? If not change the toner cartridge you can also print out the configuration page by pressing the green tick and then using the up and down arrows select information press green tick to enter then move to "Print Configuration" and select using the green tick. If the page comes out OK then the print cartridge if fine if not try changing it. Also there maybe in the driver you have under printing preferences negative mode make sure that is not checked.
Failing this reinstall the print driver from HP Online if this still doesn't work then change the data cable if still not working then I suggest that the printer formatter board is faulty.
I do hope this helps you and please rate me
Thanks J
Dec 30, 2007 | HP LaserJet 2420 Printer
Won's print pdf files
Trouble with the HP Laserjet printed output may be solved by using the following settings (or similarly named ones): "Use raster Graphics" (instead of "Use vector graphics"). This may fix the problem of "reversed" text (white on black background) not printing, as well as other problems. "Download TrueType Fonts as bitmap soft fonts" (select "bitmap" instead of "outline" or "graphics"). This may remove the overlapping of text on the printed document. "Graphics dithering" select "coarse" or "fine" (instead of "none"). This selection may improve the quality of images contained in the document. You can find all these settings in your printer properties. Go to File, Print, click Preferences, in Printing Preferences, click one by one all the top options, and change one of the top solutions, one at the time, checking your printing output. Always check if you have the latest version of Adobe Reader Program. If not download the latest version from Adobe, it's free. Is this the first time that you have the problem? or with the same printer (HP 4si), did you were able to print PDF files in the past?
Sep 10, 2007 | HP LaserJet 4si Printer
Intuit QuickBooks Premier 2009 Full Version for PC  Logo
318 people viewed this question
Top Intuit Computers & Internet Experts
Alun Cox
Chris Larocque
Mike
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
