Question about Kenmore 23822 Top Load Washer
Kenmore 110-91564100 Top Load Washer Problem
Had this washer since 1995 & operated without problem. Problem has developed suddenly as follows: 1) Very slight leak ( maybe 4 oz ), seems to be from rear of machine, when filling on wash cycle. 2) When agitating, the tub runs slightly off center, accompanied by a thumping sound and slight visible deflection of the front cabinet panel. 3)When wash cycle drains, a substantial leak ( more than a quart )occurs beneath machine. Most water pumps out the drain hose. No noise on spin. 4) Rinse cycle fills tub, but again some leakage beneath machine, perhaps a quart. I'm guessing some sort of bearing / seal problem. Is it worth fixing ? Any ideas will be appreciated ? Thanks Much !
    Scholar:
  • 136 Answers
Sounds like my 91 Geo Merto LOL! Anywho when it washes the pump spins one way and water is basically thrown back into the tub, then when on spin it spins in the opposite direction and if there is a hose leak past the pump or the pump itself leaks it will come out of the drain system. As for the thump, check under the unit for anything that shouldnt be under there getting caught up in the mechanics. Let us know :-)
Posted on Sep 15, 2007
Lights keep flashing and door locks without finishing cycle
Kenmore HE2 Plus Front Load Washer Keeps unlocking ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
flashing prewash and add garment lights My HE2 Plus will fill with water, but when ...Kenmore HE3 2plus wont finish cycle Washer wont finish the last1 minute of cycle. ...We ran a load twice and it still did not unlock. du is the code for cannot ... Why does the door keep unlocking and locking in between the drum rotating?
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following symptoms: Not Completing all Cycles ...
Washing machines - Ariston
Jan 05, 2016 | Washing Machines
I need a procedure to remove the washer top so as to remove rust that has developed on the edge and underside.
See the following for an illustrated description of how to release the console and remove the cabinet :
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=e65c6f729b24400c8e4428078da6b686
Oct 22, 2010 | Kenmore 24032\24036 Top Load Washer
Hi - how do I test my lid switch? I have what is apparently a fairly common problem with my Kenmore 90 Plus Series washer (which we bought new in 1998). Doesn't properly spin the clothes dry at the end,...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
You won't get fried.....
Just make sure to disconnect the power to the washer before opening the console.
Plug the short wire in and then plug the washer in.
If it is the switch, follow the illustrations for how to remove the cabinet. You should be able to see where the switch mounts and be able to replace it yourself.
Apr 10, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
I am looking for a service manual for kenmore waching machine model # 110.26944503
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.26944503
To the right of the Components page is a section where you can get PDF documents of their operation and installation guides.
Following is the location of a PDF for the Whirlpool / Kenmore top load, direct drive washer installation and service manual.
Following is the Whirlpool parts list for their commercial washers although the consumer models use the same parts.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Oct 30, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 27841 Top Load Washer has developed a water leak
Hi, Check the pump. Tip the washer back after the load finishes and see if the pump is dripping. The pump is located on the front side of the motor. If the leek seem to be in the front center of the washer, it is probably the pump. I hope this helps. Please let me know if I can assist you further.
Vic
Jun 27, 2009 | Washing Machines
Water problem
Apr 01, 2009 | Washing Machines
Kenmore washer just stopped
Open and close lid, listen for 'clicking' sound. If no 'clicking' sound, check/replace lid switch. Also try tightening the lid hinge screws on the left side. if these screws come loose, the machine will not operate
Jun 14, 2008 | Kenmore 24642 Top Load Washer
Kenmore 70 series won't turn on
Sounds like the fuse may be gone. If your front panel comes off it may be in there.
Jun 01, 2008 | Kenmore 22422 Top Load Washer
Kenmore 23822 Top Load Washer Logo
261 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
